03-28-2007, 02:52 PM | #1 |
Member#: 42645
NESIC
Vehicle:2014 Audi S4 Brilliant Black |
Downpipe Install - > Torque Settings for Downpipe Bolts?
Gonna install my Invidia V3 DP soon, are there any specific torque settings for the DP->Turbo bolts?
Thanks! I searched but didn't find very much, all i could find was the other use of torque!
03-28-2007, 04:02 PM | #2 |
Member#: 44351
Vehicle:2004 Mitsubishi Evo 701whp 9.91@146 |
um...tight.
all exhaust bolts for the header and uppipe are 27ft-lbs, so that seems like a good number for the downpipe bolts too. |
03-28-2007, 11:33 PM | #3 |
Member#: 133709
Could call Invidia's US office or even Subaru and see how much they tq the stock bolts.
03-29-2007, 12:33 AM | #4 |
Member#: 144728
27ft-lbs is weak. i used that when i installed my downpipe and was getting exhaust leak. Torque MUST be at least 140-150lbs.
03-29-2007, 12:35 AM | #5 |
Member#: 142673
TXIC
Vehicle:2006 STI I've created a monster |
i dont know myself but I personlly would like proof of these claims or see the actual specs
03-29-2007, 12:59 AM | #6 | |
Member#: 92003
SCIC
Vehicle:04 bicycle! |
www.whiskeytangofoxtrot.net/hosted/down.pdf factory specs Last edited by prometheum; 03-29-2007 at 01:06 AM. |
03-29-2007, 01:00 AM | #7 |
Member#: 142673
TXIC
03-29-2007, 01:03 AM | #8 |
Member#: 144728
yes. as a matter of fact, i invented the downpipe. if it wasn't for me, your cars wouldn't have downpipes. to the OP, just shoot for 200ft-lbs and you'll be fine.
03-29-2007, 01:08 AM | #9 |
Member#: 142673
TXIC
and i built the 1st automobile....... and if you strip the bolts u wont be fine, just call subaru a get the specs to be sure
03-29-2007, 01:12 AM | #10 | |
Member#: 92003
SCIC
www.whiskeytangofoxtrot.net/hosted/down.pdf |
03-29-2007, 01:16 AM | #11 |
Member#: 142673
TXIC
oops.... skimmed right over that
03-29-2007, 01:19 AM | #12 |
Member#: 140244
Vehicle:2002 bugeye still rippin' hard |
03-29-2007, 09:30 AM | #13 |
Member#: 118209
Vehicle:2015 WRX Limitec |
your kidding, right? 150 lbs will probably come very close to stripping those things right off. 26 pounds is factory, go to 30-35 if you feel like being a little on the safe side. More importantly, use a new gasket and tighten progressively on all bolts!
03-29-2007, 09:39 AM | #14 | ||
Member#: 59692
Vehicle:2005 Impreza WRX STi WRB-Gold |
Request for ban. OP: The proper specs are 26 ft/lbs and I would suggest using new gaskets. Getting the bolts off...that will feel like 200 ft/lbs. |
03-29-2007, 10:55 AM | #15 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
....I have found that the 'stock' spec is a bit weak...by ~10-15***37;
03-29-2007, 12:31 PM | #16 |
Member#: 98961
Vehicle:2003 WRX Black |
Yeah those torque specs are pretty damn low. I notice the STI manual show slightly higher value for some of them over the 02 WRX manual.
So, you're suggesting 2-3 ft/lbs over spec? |
03-29-2007, 12:37 PM | #17 |
Member#: 16200
...well...the FSM specs seem to be for 'new' fasteners.....used fasteners do not torque the same as new.....so a bit nore torque may be necessary.....and/or re-torquing after a few heat cycles
03-29-2007, 12:39 PM | #18 |
Member#: 109531
Vehicle:2006 STI 2008 CBR1000 |
Mmmm plan to be installing on my STi pretty soon. Anyone know the STi values? I keep finding WRX ones.
03-29-2007, 12:44 PM | #19 |
Member#: 59692
Ummm....26 ft/lbs.
(a few posts above yours) |
03-29-2007, 12:48 PM | #20 |
Member#: 98961
03-29-2007, 02:20 PM | #21 |
Member#: 109531
03-29-2007, 02:41 PM | #22 |
Member#: 59692
Those specs are from my 2005 Impreza service manual...and yes, both the WRX and STi torque specs are the same. I wouldn't post WRX specs in a thread that is asking about the STi.
03-29-2007, 02:43 PM | #23 |
Member#: 109531
03-29-2007, 02:48 PM | #24 | |
Member#: 104998
Vehicle:2007 vf39 SuperWagon I haz teh bed gramers |
03-29-2007, 02:56 PM | #25 |
Member#: 92003
SCIC
anyone know the torque settings for top strut mount bolts? | scooby06 | Brakes, Steering & Suspension | 2 | 07-17-2007 09:49 PM |
Torque settings for Downpipe nuts? | Airboy | Western Canada | 7 | 07-13-2006 02:14 PM |
Torque settings for strut tower bolts | patrick smith | Service & Maintenance | 4 | 09-05-2005 12:09 PM |
Torque Settings for Downpipe | DILLIGAF Racing | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 6 | 04-15-2005 07:24 PM |
torque spec for downpipe bolts on the turbo | cre | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 09-28-2002 09:04 PM |
