08-21-2010, 12:57 AM | #1 |
Member#: 222622
Vehicle:02 Impreza 2.5 TS Dark Blue |
STS turbo?
has anyone heard of installing a sts turbo on an n/a 2.5 motor?? does it work/is it worth it?? if so can i get a link to a website that i can get one?
08-21-2010, 01:12 AM | #2 |
Member#: 60082
Vehicle:2004 Forester STI Silver |
turbo on NA = broken engine.
You need to upgrade the internals to support boost or it just fails. |
08-21-2010, 02:31 AM | #3 | |
Member#: 74907
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
Granted the wise thing to do is upgrade pistons and rods, because boost is like crack, the more you get, the more you want. ~Josh~ |
08-21-2010, 03:11 AM | #4 |
Member#: 60082
When a slew of people tell you they destroyed their stock internal forced induction upgraded na engines, you start to listen to them. As said by many people, it's not a matter of if, it's a matter of when.
08-21-2010, 10:48 AM | #5 |
Member#: 38222
Vehicle:'10 &'12 Foresters another Miata convert |
Most of what we do around here could be broken down into just a few paragraphs that can offer an idea of what you can and can't (and should and shouldn't) do to any given Subaru. The questions never change, but the answers are always varied (with incorrect material sometimes delivered like gospel), the information is mucked with filler or flaming, and the Search function get diluted with garbage.
For the OP, I offer the same question as I do every other aspiring major drivetrain modifier: How's your backup car looking? You can build an engine a million different ways. Some will be close enough. Some will be bulletproof. Some plain and simple will expire, and if that's OK, then you're headed down the right road. If you're building up a daily driver, though, and you don't have a backup machine, aren't familiar with the technology, and especially if you're on the bleeding edge of your budget as it is, you're making a mistake. |
08-21-2010, 12:02 PM | #6 |
Member#: 220259
Vehicle:09 2.5i SSM |
Turbos on NA Subarus are not worth the money and the headache.
Also, try not to make multiple threads |
08-21-2010, 01:13 PM | #7 | |
Member#: 187834
Vehicle:06 2.5i impreza Red |
^^^^^^^like he so put it if you don't have self control don't do it. Or you could stick with a manual boost controller so you have to go into the engine every time to turn it up. But a 6-7 psi will be fine assuming the tune you use is on par. I'm about to SUperCharge my 2.5i it will be the first with a centrifugal compressor with out having to cut my hood lol on 7 psi so really it will be the first SC 2.5i becuase most are only running 3 psi of boost at 6400 which is pointless really. Agian tune tune tune must be right on or even with forged pistons you'll crack a hole in one. |
08-21-2010, 10:38 PM | #8 |
Member#: 102984
Vehicle:2005 2.5RS 4EAT Platinum Silver |
Man you love posting in ever turbo topic here!
Anyway, the true issue is dynamic compression. Without better pistons it will eventually break something. Tuning helps for sure, but it tuning alone can't completely make up for the ridiculously high dynamic CR caused by the stock piston face. Pop in aftermarket forged dished pistons, and now we're talkin. Rods are the same as the stock WRX which can take up to 20 psi boost on stock internals. While I'm not saying that the 2.5RS can do the same, I am saying that the rods will be for the most part, just fine. |
08-22-2010, 06:44 PM | #9 |
Member#: 222622
sorry about the multiple posts and soundin like a huge dummy. thanks all for answerin my question, and no im not putting a turbo on an n/a....even tho its slow im not tryin to blow it up.
08-23-2010, 09:06 AM | #10 |
Member#: 201277
Vehicle:2008 08 QSM 5MT LGT QSM |
The STS remote system was fitted on a 07 Legacy 2.5i but the owner didnt go through with the build They work well but are better suited to F and N bodies (yes Cavaliers and Grand Am ) The Remote system would be far more easy to fit as you only need to mod the axleback but you would also need a decent oil pump and you need to thermo-protect the charge pipe for the length of the car.
Of all the turbo options this one would require the least engine related hardware changes. |
08-23-2010, 09:32 AM | #11 | ||
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
08-23-2010, 01:50 PM | #12 |
Member#: 1748
Vehicle:'09 Outback Sport OBP over DGM |
I never really see the topic of turboing an NA Subie as a "can you?" issue. Yes you can, there are risks (aside from what some say) that can be managed if you do it right. It can also be very expensive, at which point you have to (or at least you should) ask yourself, "Is it worth it? Or should I just spend the cash on a WRX?
Turbocharging and NA car will get you a more HP. Buying a WRX will get you a more HP in a more reliable turbocharged engine and...everything else that you get with a WRX that you can't get on a 2.5i or RS. Upgrqaded suspension, bodykit, scoop, spoilers, better seats, etc. etc. Turning a 2.5i into a WRX can be a fun project, but it's never going to be cheaper than just buying the WRX to start with. |
08-24-2010, 09:25 AM | #13 |
Member#: 201277
YOU can run a Remote turbo on ANY car. Just historically NOT SUBARUS (i ****ing hate having to explain every point on this website).
Ask the Mustang and Chevelle and Camaros or other "Muscle Car" owners why they chose a remote system if you want in depth reasoning why. |
08-24-2010, 11:03 PM | #14 | |
Member#: 120
AKIC
Yes, I know. I asked why you said remote turbos are better suited to two random, rarely modded GM FWD economy cars.
For obvious reasons. All the parts to install a "normal" turbo setup on a Subaru are readily available from a junkyard or from this forum or a number of other Subaru forums. Why go through the effort of re-engineering the car when FHI's engineers have already done all the work for you? Quote:
Pat |
08-25-2010, 08:07 AM | #15 | |
Member#: 38222
And I have no idea why you'd want a remote mount on a 4 cylinder engine. It just seems ridiculously impractical, unless you're all about high end power. |
08-25-2010, 11:38 AM | #16 | |
Member#: 201277
N bodies are FWD GM COMPACT CARS J bodies are GM FWD PASSENGER CARS Both span the same production range early-mid 80's and terminate in 2005 when the Zeta and Premium bodies started. I am a long time member of the GM N and J body club in my area I think I know what I am talking about. I never ran a remote turbo on my N body I have seen one on a N Body Cavalier and one on a 2007 LEgacy 2.5i. Those two bits of info are all that needed to come out of my posting to help the OP in his quest for Remote STS turbo knowledge. |
08-25-2010, 11:39 AM | #17 |
Member#: 201277
08-25-2010, 11:47 AM | #18 | |
Member#: 201277
To acquire these parts would be costly and time consuming. |
08-25-2010, 02:09 PM | #19 |
Member#: 38222
08-25-2010, 02:44 PM | #20 |
Member#: 249172
Vehicle:2008 2.5 aye spark silver |
F-body: http://en.wikipedia.org/wiki/GM_F_platform
J-body: http://en.wikipedia.org/wiki/GM_J_platform N-body: wha? |
08-25-2010, 02:46 PM | #21 | |
Member#: 249172
N-body: http://en.wikipedia.org/wiki/GM_N_platform |
08-25-2010, 07:19 PM | #22 | |
Member#: 120
AKIC
Yes, I'm serious. Considering how many of them were produced and sold as plane Jane, grocery getter, automatic, base model cars for John and Jane Doe or a rental car company, the percentage of those cars that have been significantly modded is tiny. I can't say I've ever come across one that's modified/tuned. (And I'm not counting Altezza taillights or a Supra-esque wing as "modified".) Pat |
08-25-2010, 08:03 PM | #23 | |
Member#: 38222
08-25-2010, 10:27 PM | #24 |
Member#: 201277
The General Motors N platform (commonly called the N-body or N car) was a front-wheel drive compact automotive platform produced from 1985 to 2005. The GM N platform replaced the GM X platform.
What part about compact and GM DONT YOU GET? Cavalier compact, 2 dr Grand Am compact, Olds Alero sames as a GA. If you want to yap about GM cars when they were initially used as a reference to the topic of this thread I suggest you find a GM N body website, otherwise **** about GM body lines and which cars fall into that subset or not. |
08-25-2010, 11:28 PM | #25 |
Member#: 38222
All right, GEE. I'll take that as an admission that you're wrong or evidence that you're short of a clue and call it a day. Much thanks!
I still can't imagine why a rear-mounted turbo would fit well with a J-body Cavalier or an N-body Grand Am? At least an F-body Camaro or Firebird has some torque to get it in motion. There's got to be some hellacious lag involved with those rigs... |
Similar Threads | ||||
FS: (WA) Part out. Gold BBSes, Cobb V2, Cobb STS, AEM, Turbo XS, Rally Armor. | Legdude | Legacy Specific Parts | 6 | 10-20-2009 12:48 AM |
Any experience with a turbo for a V6 Tacoma? Sts? | macker01 | Off-Topic | 28 | 07-18-2009 11:54 PM |
new STS turbo prototype for rainy weather areas. | mattjk | Off-Topic | 8 | 10-13-2006 06:49 PM |
STS rear mounted turbo kit | b_tapper | Off-Topic | 16 | 01-10-2005 04:19 AM |
Cobb STS and OEM Sti STS | Fusionpnoy | Transmission (AT/MT) & Driveline | 7 | 05-22-2004 02:36 PM |
