07-25-2016, 11:51 PM | #376 |
Member#: 243992
Vehicle:2006 WRX TR WRB |
What do you guys do for the flex fuel sensor for big fuel system guys? Since it Seems the biggest sensor is -6, are you limited to a -6 it could I say run a -8 Y to 2 -6 lines and Y to a -8
07-26-2016, 12:00 PM | #377 |
Member#: 265430
Vehicle:2005 OBP WRX STi IG/FB - seriousblacksti |
Since it's on the return side, I don't see any reason you couldn't branch off with a -6 fitting, go to the sensor, then tie it back in if you're running a -8 or -10 return.
08-12-2016, 10:04 PM | #378 |
Member#: 259831
Vehicle:2005 STi Black |
Any updates?
08-13-2016, 12:04 PM | #379 |
Member#: 428984
Vehicle:2016 Wrx 410whp JR Tuned |
08-15-2016, 07:09 PM | #380 |
Member#: 388585
Vehicle:2015 wrx base ISM |
You might want to talk to a tuner to see how they feel about that. A while back my tuner mentioned something about this kit leaving out some important parameters that he would not recommend.
09-15-2016, 12:53 PM | #381 |
Member#: 353990
TXIC
Vehicle:2016 WRX Dark Grey Metallic |
Yeah, not to bad mouth them, but they can't offer the same level of integration that Cobb does, if for no other reason, because Cobb created the AccessPort. Additionally, in order to get a tune from them, you have to use a 'Delicious authorized' tuner, which basically means your tuning options are going to be limited, and most likely expensive. If you notice, most of their monitoring stuff is done via Android; this is because the AP is a proprietary, closed source system, which does not allow them to add monitors to it. This being the case, do you really feel like adding yet another proprietary black box to your car, which can't even interact with the first one entirely, is a good idea? Oh, and you may want to call Cobb and verify that it's actually confirmed by them as being compatible with the AccessPort (pretty sure I heard from a little birdie that it is not).
09-15-2016, 01:32 PM | #382 | |
Member#: 127099
BAIC
Vehicle:02 IMPERZA WRX BLACK |
09-15-2016, 03:22 PM | #383 | ||
Member#: 4803
Our DIT Flex Fuel implementation is currently being tested on internal vehicles only. Yes, it's real and it works - we are on the home stretch. The updated timeline puts DIT Flex Fuel out within the next month followed shortly by GD Flex Fuel. Marshall@COBB |
09-15-2016, 04:00 PM | #384 |
Member#: 395439
SCIC
Vehicle:2015 WRX Crystal Black Silica |
How's the hpfp holding up in your testing? Are you going to recommend fuel treatment additives to combat any issues?
09-15-2016, 04:16 PM | #385 | |
Member#: 4803
Upon release, we will strongly encourage a blend with normal pump fuel in order to give the HPFP a fighting chance. The problem with some additives is they can affect how ethanol content is determined. Depending on how they are composed, additives may cause the ethanol content sensor to go into an error state as some include components with a relative permittivity well beyond that of Ethanol. Marshall@COBB |
09-15-2016, 04:22 PM | #386 | |
Member#: 423270
Vehicle:2015 WRX (sold) |
Any idea of the max e % we should stay below? Somebody on here was running e85 and was having the hpfp issues. switched to e70 and said the problems completely disappeared. |
09-15-2016, 04:47 PM | #387 |
Member#: 265430
Let's just forget about the woes of DIT HPFP's failing and move to something we know will work - GD FF support
09-16-2016, 04:58 AM | #388 |
Member#: 353990
TXIC
Out of curiosity, do you believe that there is a significant chance of a manufacturer releasing an upgraded pump? From the reading I've done, it looks like the precision required is prohibitively expensive, and given that (at least from what I saw) the Subaru pump is different than others, I can understand how the R&D costs would outweigh the benefits. Is there any chance that the manufacturer for Subaru (anyone know who, I can't seem to find info, but I would guess Bosch or Carter) would be amenable to such a thing, given that they've already designed and tested the part? Obviously there would be changes required (duh), but I would think they would have a huge upper hand, since the majority of the R&D work is already done. Has anyone actually tried contacting them? Maybe I'm crazy, but I don't think contacting them is going to hurt anything, at the worst, they'll tell you to go forth and multiply.
09-16-2016, 11:31 AM | #389 | ||
Member#: 68647
Vehicle:07 STI 35R 05 BMW M3 ZCP |
09-16-2016, 06:48 PM | #390 |
Member#: 440000
SCIC
Vehicle:2016 WRX / Flex Fuel CBS |
Hi Cobb, could we a sneak peak picture of the setup?
09-20-2016, 09:42 AM | #391 |
Member#: 4803
I don't see any issues with that! The below pictures were taking of our shop 2015 WRX. While this isn't a true 'production kit', the end result should be very close.
As you can see, the brain/module will likely mount in a very similar area to the already released STI kit. The ethanol sensor itself is located underneath the fuse box, just behind the battery. Marshall@COBB |
09-20-2016, 10:23 AM | #392 |
Member#: 260561
TXIC
Vehicle:2006 Impreza WRX Ltd Grey |
Hey Cobb - can you say anything about what specific GD models will be getting FlexFuel love? I heard the 04 STi ECU is a bit limited.... also, what about 06-07 WRX? THANKS!!!
09-20-2016, 02:08 PM | #393 |
Member#: 135429
Vehicle:'05 Cornfed CGM STi 94 Legacy SS |
09-20-2016, 04:11 PM | #394 |
Member#: 440000
SCIC
Thanks for the photos Cobb, I like how it still makes the car look stock. Def cant wait for this to come out...
09-21-2016, 02:05 PM | #395 |
Member#: 349901
SWIC
Vehicle:2006 Subaru STi SGM |
So ready for GD flex fuel!!
09-21-2016, 03:45 PM | #396 |
Member#: 265430
09-21-2016, 06:47 PM | #397 | |
Member#: 242700
Vehicle:2015 Impreza Wrx White |
I actually wouldn't mind mounting it exactly like the way you have in the pictures to avoid hitting my front mount intercooler piping. Can't wait to be able to run a blend of ethanol and also have the safety DTCs I've heard about that you guys incorporated! Dave PRL Motorsports Last edited by baseballdbk1; 09-22-2016 at 12:24 AM. |
09-22-2016, 03:33 AM | #398 |
Member#: 97130
SCIC
Vehicle:2004 WRB WIDE STI COBB/TIC/CUSCO/DSS/TSSFAB |
I'm dying to hear more about this GD FF Kit as well. Us 32Bit bastards are waiting!!!
Peace -TurboTod |
09-25-2016, 03:33 PM | #399 |
Member#: 395439
SCIC
Hey Cobb, if we already have a zeitronix ethanol content analyzer, can it be wired into the cobb flex fuel setup?
09-26-2016, 02:14 PM | #400 | |
Member#: 265430
Yes, the zeitronix sensor uses the entire 0-5v range though so it will not work with the diagnostics/error reporting that the Cobb sensor allows for. Once it's released I'll consider changing out my zeitronix setup for the Cobb total package depending on what it seems like I could sell the zeitronix for. |
