07-04-2014, 04:48 PM | #1 |
Member#: 378421
Vehicle:2005 Cobb Stg2+ Wrx Platinum Silver |
any1 use Cobb stage 2+ ebcs maps?
Hello Nasioc, I was wondering if anyone is using the new Cobb stage 2+ ots maps on their car yet.
http://www.cobbtuning.com/Subaru-Acc...tock-SF-Intake As you can see, Cobb now offers stage 1+ ebcs and stage 2+ ebcs ots maps through their accessport v3. I always wanted to upgrade from my AP v1 to the new v3 AP, and kind of want it more now. Just wanted to see what everyone else thought. As of now I have a 2005 Wrx premium sedan with Cobb sf intake/box/post maf hose, Perrin turbo inlet, Samco intercooler/bpv/tb hoses, Cobb up pipe, Cobb down pipe and Cobb Ap v1 with 93 octane stage 2 tune. Everything has been more than perfectly fine for a while, but very curious about adding the Cobb 3 port Ebcs and the new Ap v3 with stage 2+ ebcs map. Users? Comments? etc?
07-09-2014, 11:54 AM | #2 |
Member#: 378421
So none of yall are using the stage1+ or stage2+ ebcs maps from Cobb?
I've been very happy with my ApV1 stage 2 ots map from Cobb, and very curious about their 3 port Ebcs and their new ApV3 stage 2 + ebcs map. |
07-10-2014, 09:09 AM | #3 |
Member#: 275260
Vehicle:17 Dodge Charger |
I should be getting my EBCS in the mail today from cobb, I went from V1 to V3 recently aswell and the updated tune alone is already running better just underboosting on HWG still. Hoping the EBCS will fix that
07-10-2014, 09:19 AM | #4 |
Member#: 328769
NESIC
Vehicle:2005 WRB WRX 2007 UGM 2.5i |
I was wondering this too. I've been wanting to get an EBCS for awhile but never got one because it wasn't supported in the maps.
07-10-2014, 01:01 PM | #5 | |
Member#: 378421
Do you plan on using the Cobb stage 2+ map with their Ebcs, or a custom tune? Please keep me updated on the Cobb Ebcs and new map. I am very interested in this. |
07-11-2014, 08:20 AM | #6 | |
Member#: 275260
Right now im just going with stage2 + ebcs, protune later on So far on my test ride to work after installing the ebcs + map is i gained 1psi, before i was hitting about 15.25 now i'm at 16.28 and it is normal to go 1psi less from what i read. The boost kicks in alot quicker too and holds better. Hope this helped |
07-20-2014, 07:40 PM | #7 |
Member#: 378421
Anyone else have experience w these maps. Tryibg to decide if I want to spend 700 for the new Apv3 and 3 port ebcs.
07-25-2014, 12:46 AM | #8 |
Member#: 397188
Vehicle:2008 USDM STI Aspen White |
I am running the stage 2 + ebcs on my 2002 wrx with the version 2 ap. I am having issues with underboost now after the install, ( see my other post) still looking for help on that issue. other then the underboost, i love it! day and night difference..
07-28-2014, 10:57 AM | #9 |
Member#: 378421
Are there hwg and lwg stage2+ebcs maps you can use?
Really hope you get that problem figured out. |
07-28-2014, 05:13 PM | #10 |
Member#: 397188
Yeah there is hwg and lwg maps but they didn't help any, I found out I am leaking a lot at the injectors, bought a generic injector repair kit and changed the seals a while back and I guess they aren't thick enough. Will get that fixed this weekend when i receive all new oem orings grommets and seats for the injectors.( expensive for some little pieces of rubber...) I expect to regain the 2 to 3 psi lost. Its weird that the OEM ebcs held the boost even with the big boost leak. Even with the leak, its a night and day difference with the 3 port, I would recommend it.
07-30-2014, 04:48 PM | #11 |
Member#: 261114
Vehicle:2003 wrx wagon silver |
I think the wgdc map may be conservative so you don't get any big spikes. The maps run quite a bit of boost
Sent from my iPad using NASIOC |
08-17-2014, 11:17 PM | #12 |
Member#: 378421
Anyone else using Cobbs newer stage 2+ ebcs maps?
I would love to hear everyones input that is or has used this map, and how it compares to there stage 2 map. |
09-29-2014, 06:42 PM | #13 |
Member#: 378210
I think it's a certain improvement over the standard stage 2. I'm just curious now what the difference between OTS and protune is with this setup.
09-29-2014, 07:33 PM | #14 |
Member#: 318368
Vehicle:2007 WRX sedan WRB |
I'm using it now but am having boost issues. I don't reach peak boost and am only running on wastegate pressure. Not sure what is going on because everything is hooked up and tight.
Sent from my iPhone using NASIOC |
12-06-2014, 06:32 AM | #15 |
Member#: 407956
Vehicle:2004 sti white |
suprised
Im suprised more people havent chimned in on this. I just got my sti and this was a mod im veey interested in but want some user reviews first
12-06-2014, 08:29 AM | #16 |
Member#: 181717
Vehicle:12 sti hatch w r b |
im running stage 2+ with no ebcs. been researching the ebcs and havent decided yet
power over stock with ots map was insane. im getting used to it now, so like any addiction, im looking for my next fix |
12-07-2014, 10:43 PM | #17 |
Member#: 385446
BAIC
Vehicle:2004 WRX JBP |
i just put my cobb 3 port in and am running the stage 2+ebcs map.
the 3 port fixed my boost issue. |
12-08-2014, 09:07 PM | #18 |
Member#: 181717
i've been interested in a 3 port but just dont understand it enough.
10-02-2015, 07:00 PM | #19 |
Member#: 369601
NESIC
Vehicle:2002 Wrx wagon Black |
I'm running the stage 2 +ebcs on my 02 wrx after running the stage 2 for a long while before that and the difference is impressive I went from boosting 14 to 17. Much less over boost and the gain is really quick . Plus it's a breeze to install
10-08-2015, 11:26 AM | #20 |
Member#: 431718
Any been having problems with boost spikes? I've had mine spike up to 24psi on the stage 2+EBCS. Just installed my mine last night and had it spike over 20psi twice. And just cruising I can't spool more then 9psi.
10-08-2015, 03:17 PM | #21 |
Member#: 353788
South East
Vehicle:1997 Cherokee Tuned by AlanSnackbar |
they dont make the maps for 2010+ cars.
10-08-2015, 03:18 PM | #22 | |
Member#: 353788
South East
you've hit boost cut then and now its in WG mode. Reset ECU and log the car. Was the 24PSI in 4th gear? |
10-11-2015, 05:11 PM | #23 |
Member#: 431908
how safe is the stage 2 tune
10-12-2015, 03:44 PM | #24 |
Member#: 431961
Cobb has certain maps that adjust to your wastgate... There are options when you download the stage2+ebcs map that account for under boosting or over boosting
03-15-2016, 08:39 AM | #25 |
Member#: 442592
