09-09-2016, 08:17 AM | #1 |
Member#: 332757
Vehicle:2012 WRX Plasma Blue |
Stage 1 - 2012 WRX - Fine Knock Learn Consistently
Hoping for some feedback on some recent logs. My Fine Knock Learn is consistently reading -0.7. This is from the time I start the car to the end of my drive. The only time I've seen it go back to 0 was while I was logging a WOT for this thread but it returned back to -0.7 after I let off. The WOT run doesn't show any Feedback Knock correction, hit just shy of target boost, and little AF Learning. The -0.7 is true across two different tanks of 93 from two different stations.
The car: 2012 WRX 26,7xx miles COBB Stage 1 93 Map (v3.1x I believe) Stock intake Nameless axleback No other mods It was a hot day when I logged this data but the -0.7 Fine Knock Learn was there on recent cooler days as well. Map has been on the car for a few years now and I typically see no, or very little, fine/feedback knock and hit target boost. 3rd Gear WOT ~90 degrees out https://docs.google.com/spreadsheets...it?usp=sharing Cruising/Trying to hit a few different ranges - High 80s this day - Noticed some Feedback Knock but at pretty low load - More AF Learning in this one https://docs.google.com/spreadsheets...it?usp=sharing Any ideas/suggestions would be much appreciated. Let me know if additional information is needed - thanks!
09-11-2016, 07:36 AM | #2 |
Member#: 453831
First your only hitting 15psi. Cobb is really messing up. Check this.
Go to the torqued performance website. I got a AP V3 and loaded in cobbs stage 1 91 oct map and was stuck at 15psi as well. Was kinda disappointed. Found out about TP and bought his accessport stage 1 91oct map for $99. Immediately i was hitting an 18psi target with peaks of 19psi. He also e-tuned me 7 revisions to get me running great. All for the $99 i paid for the map. 3psi more. E-tuned? Yes please sir. |
