Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 09-10-2016, 02:34 PM   #1
vecon121
Member#: 276433
Default Access Turner race not available anymore
Hello,
I picked up a 2011 wrx with 17000 miles one it. I have been driving it for a few months now. I realized the other day I was only getting 8lbs max of boost in any gear. It had a stage 1 91 Oct map flashed to it since I bought it. Well long story short turns out something about the map that was flashed limited it 8lbs. After a reflash it's hitting 15lbs. My issue is that I'm getting around 12 to 1 afr. I'm not thrilled about that. Can anyone provide me a copy of access tuner race? I'm trying to check if there are any logs from the previous owner and clean up the map a bit. I have no idea why cobb took it down. Also I have a v3 accessport. Ps I'm stuck at 15lbs now on either of the ots stage one maps (91 Oct and 93 Oct so I have no idea what happened)
vecon121 is offline   Reply With Quote
Old 09-11-2016, 01:10 AM   #2
vecon121
Member#: 276433
Originally Posted by vecon121 View Post
Hello,
No one has the install .exe for a 2011 wrx with a v3 accessport?
Old 09-11-2016, 07:06 AM   #3
Nito3356
Member#: 453831
Go to the torqued performance website. I got a AP V3 and loaded in cobbs stage 1 91 oct map and was stuck at 15psi as well. Was kinda disappointed. Found out about TP and bought his accessport stage 1 91oct map for $99. Immediately i was hitting an 18psi target with peaks of 19psi. He also e-tuned me 7 revisions to get me running great. All for the $99 i paid for the map. As per the 8psi? You must have been running an eco map.
Nito3356 is offline   Reply With Quote
Old 09-11-2016, 08:46 AM   #4
vecon121
Member#: 276433
I don't know that I can run 18psi. I'm already leaning out running 15. I haven't replaced the exhaust or intercooler yet either. I'd really perfer if possible away to read logs so I can see what's actually going on with my car.
Old 09-11-2016, 10:01 AM   #5
Nito3356
Member#: 453831
Around 11 is what should be the reading at WOT. You got a log?
Old 09-11-2016, 10:51 AM   #6
grafton
Member#: 187936
19 WRX & WRX STi
Is that with an aftermarket wideband or from the access port? The stock sensor cant be trusted under boost, because of the high pressure per-turbo the readings get thrown off.
You should be able to open logs from your access port in excel or open office, you just need to download them with the access port manager.
grafton is offline   Reply With Quote
Old 09-11-2016, 11:09 AM   #7
vecon121
Member#: 276433
Those wideband reading were off the stock o2. I'm looking into getting a dp and wideband soon.
Old 09-13-2016, 04:34 PM   #8
vecon121
Member#: 276433
Bumping this. Still hunting down a copy of atr. Pm me if you have it please.
Old 09-14-2016, 09:38 AM   #9
joeblow65
Member#: 453499
2014 WRX hatch
black
bump. im looking for the ATR for an 08-14 WRX as well.
joeblow65 is offline   Reply With Quote
Old 09-14-2016, 09:41 AM   #10
vecon121
Member#: 276433
It's year specific I think. I tried one for 09 and it didn't work. Try here they are missing 2010 -2014 wrx though. http://www.iwsti.com/forums/4265559-post9.html
