07-26-2005, 10:52 PM | #1 |
Member#: 90353
NWIC
Vehicle:Sold '95 22T Impreza '99 EJ205 L, AE86 GVR4 |
Oil Pressure + Temp. gauge installation
Is there a common spot on the block to connect the oil sending unit from the gauge?
im not sure how to install either of these gauges, but what does it take to get them to work on my EJ22T impreza? i can figure out the power and mounting and running lines, just not sure how to hook up for a signal, thanks for any help! -nathan
07-26-2005, 11:06 PM | #2 |
Member#: 11571
RMIC
buy an oil filter sandwich adapter and you can run both sensors off of that
Greddy makes one, I got mine from Z1 Performance |
07-26-2005, 11:12 PM | #3 |
Member#: 90353
NWIC
does that just go on the filter, and it reads the oil pressure? how much $?
sorry, by temperature i meant water temp, how does that hook up? thanks! |
07-26-2005, 11:58 PM | #4 |
Member#: 11571
RMIC
Its like $50, you take off your oil filter, screw the sandwich adapter onto the engine , you then screw the oil filter onto the adapter. You then thread your oil pressure sensor that you purchased with whatever gauge you bought into one of the two ports on the adapter.
engine adapter filter just like that water temp, yeah, it won't work for that, and I honestly don't know where you place the sensor for that, but I'm sure you can find out if you searched in the forums |
07-27-2005, 04:50 AM | #5 |
Member#: 90353
NWIC
ok thanks, i saw what you meant on greddy's website, i believe the water temp sensor goes in the upper rad hose somehow..
WTB: Defi amber imperial oil pressure/temp gauge | non-ricer | Private 'Wanted' Classifieds | 4 | 12-10-2009 04:42 PM |
06 sti and installing oil pressure/temp gauge | nation1979 | Newbies & FAQs | 20 | 05-08-2009 11:09 PM |
oil pressure/temp sensor install | Kingpin | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 09-28-2006 01:21 AM |
oil pressure/temp sensor install | Kingpin | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 0 | 09-08-2006 05:38 PM |
Oil presure / Temp gauge install ? | TopKatz | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 01-31-2004 08:25 PM |
