09-27-2014, 05:51 PM | #17476 |
Member#: 330830
Vehicle:2010 Impreza2.5i 5dr Obsidian Black Pearl |
So I finally brought my car into a mechanic friend and got it on the lift to check out my clunky swaybar issues. 3/4 bushings are loose and need replacing, my 2 front endlinks are completely **** and one of my wheel studs broke off because the place that put on my tires tightened the lug nut way to ****ing much.
Anyone know a good place to get these for cheap? (Keep in mind they are larger Rallitek swaybars). And I finally saw my frame and the scraping it took the last 2 years haha. Sent from my iPhone using NASIOC
09-29-2014, 04:20 PM | #17477 | |
Member#: 296643
SWIC
Vehicle:2008 Impreza 2.5i SS |
IMHO Last edited by bluesguyej25; 09-29-2014 at 04:23 PM. Reason: ....IMHO... |
09-29-2014, 04:46 PM | #17478 | |
Member#: 366085
RMIC
Vehicle:2010 Impreza 2.5i PE DGM |
How do you got about replacing the studs? I want to get some 10 or 15mm ISC or Grapple wheel spacers but am hesitant to spend over $150 on good spacers and have my studs give out. Are they expensive? |
09-29-2014, 04:48 PM | #17479 |
Member#: 262503
Vehicle:2008 Impreza 2.5i |
Finally going to buy some dedicated snow tires. Probably get them mounted within the next two weeks.
09-29-2014, 04:49 PM | #17480 |
Member#: 366085
RMIC
09-29-2014, 04:51 PM | #17481 |
Member#: 262503
I'll be buying new wheels and summer tires for next season.
What winter tires are you getting? The weather here was 85° yesterday and a high of 55° today. Not trying to ride them in warm weather but it is basically October already. |
09-29-2014, 04:59 PM | #17482 |
Member#: 296643
SWIC
All it takes is some strength and a good sledge to hit them out. Spray them with PB or wd40. Let them sit then hit them out. They are just a press fitting. If you get some extended studs, they will probably screw in first. Anti size them and good to go!
09-29-2014, 07:58 PM | #17483 |
Member#: 253642
NESIC
Vehicle:2008 Impreza 2.5i SSM |
Its good to be back
The subaru: My New Toy: |
09-29-2014, 08:02 PM | #17484 |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
An old convertible RX-7? Wow that's an odd choice.
09-29-2014, 08:07 PM | #17485 |
Member#: 253642
NESIC
09-29-2014, 08:14 PM | #17486 |
Member#: 367167
Vehicle:2010 Impreza OBS Silver |
[quote=daigledangle8;42585458]Its good to be back
The subaru: Is that a modified stock grille or is that a WRX/sport grille? It looks good! Sent from my iPhone using NASIOC |
09-29-2014, 08:20 PM | #17487 |
Member#: 253642
NESIC
09-29-2014, 08:21 PM | #17488 |
Member#: 236305
Sport grill is something different.
09-29-2014, 08:41 PM | #17489 |
Member#: 366085
RMIC
08 2.5i
09-29-2014, 09:33 PM | #17490 | |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
Get the wheel studs from your dealership (they're fairly cheap). As others have said, they are pressed in so just knock it out with a hammer. Use the washer method to pull the new wheelstud all the way flush with the hub. +1 for rallysportdirect. Holy mother of scrape. I would spray some undercoating overthat before winter starts hah |
09-29-2014, 10:10 PM | #17491 | |
Member#: 330830
My friend (the mechanic with a lift) and I will be doing the stud and replacing swaybar and endlinks stuff soon. That scrap-age has gone through 2 winters so far with no problem haha barely any rust yet. I miss scraping :'( Sent from my iPhone using NASIOC |
10-04-2014, 02:39 PM | #17492 |
Member#: 403167
Vehicle:2008 Impreza 2.5i blue |
I just got me a nice blue impreza 2.5i back in march, needless to say have had good luck with it so far.
10-04-2014, 05:40 PM | #17493 |
Member#: 366085
RMIC
10-04-2014, 05:44 PM | #17494 |
Member#: 366085
RMIC
Just to clarify, I've forgot if they do or not, 2009 WRX coilovers will fit a 2010 impreza correct? Thinking of getting some BC racing coils beginning of next year.
10-04-2014, 05:56 PM | #17495 |
Member#: 403045
Got an 08 2.5i back in the spring. Anybody know what mud flaps would look like on it?
10-04-2014, 06:40 PM | #17496 | ||
Member#: 262503
Direct fit. Quote:
It will look like any other Subaru with mud flaps. Browse this thread or Google it. |
10-04-2014, 06:50 PM | #17497 | |
Member#: 366085
RMIC
Hatch or sedan? This is what my hatch looks like with V2 rally armor flaps on. Just don't hit a curb when backing your car in. I learned the hard way, ripped one flap off. [IMG] |
10-04-2014, 07:05 PM | #17498 | |
Member#: 236305
Stock suspension. 17x8 wheels. |
10-04-2014, 08:45 PM | #17499 |
Member#: 366085
RMIC
10-04-2014, 09:49 PM | #17500 |
Member#: 344260
NESIC
Vehicle:2009 Impreza OBS Sage Green |
Might be getting a Subaru job while in school!
08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 10 | 08-22-2017 12:30 AM |
Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
