02-03-2013, 11:09 AM | #1 |
Member#: 170439
Vehicle:I <3 Lamp |
EJ255 Shortblock with SOHC EJ22t Heads?
I'm in the process of building a car that is based off a lotus 7 chassis (see; locost, caterham, donkervoort) and I want to fit a subaru engine however a dohc will not fit without major changes to the chassis, I've done some measurements and have found that if I put sohc heads on they allow the engine to fit with only pushing the firewall back around 3-4 inches.
The block I am using is an ej255 out of a 2010 wrx, the heads are sohc ej22t heads off of some unknown car. Basically all I need to know is this. 1. Stock ej22t compressed hg size 2. ej22t combustion chamber volume. 3. If I used wrx or sti headgaskets do I need to make any modifications to the block or heads to run this combination. 4. I noticed the ej22t heads have the intake ports spaced out more for the spark plug hole, will these interfere with the stock ej255 pistons?
02-03-2013, 07:48 PM | #2 | |
Member#: 216984
Vehicle:1996 Impreza outback Green |
02-03-2013, 09:54 PM | #3 |
Member#: 170439
Vehicle:I <3 Lamp |
I'm going to stay with the ej22t heads. I can get them cheap and in good condition. Plus it will be naturally aspirated. If I ever turbo it ill run wastegate pressure on a td04
Thanks for the info |
