Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 10-10-2010, 10:18 AM   #1
kansai104
Member#: 241019
2010 Impreza 2.5i
RALLY BLUE
Default is this a good setup for 2.5i?
recently i bought the K&N apollo intake and megnaflow for 2010 2.5i
i m wonderin, is this a good setup for 2.5i??? plz let me know thnx
http://www.knfilters.com/search/prod...?Prod=57A-6040
http://www.magnaflow.com/02product/s...ne=all&id=7783
kansai104 is offline   Reply With Quote
Old 10-10-2010, 11:59 AM   #2
.HaVoK.
Member#: 229726
'09 2.Slow
I would just stick with a K&N Drop in filter.
.HaVoK. is offline   Reply With Quote
Old 10-10-2010, 01:55 PM   #3
kansai104
Member#: 241019
2010 Impreza 2.5i
RALLY BLUE
So the exhaust system is not good?? I been told. That with that Apollo filter + mengaflow system isvpretty decent setup...
Old 10-10-2010, 02:16 PM   #4
GrundleJuice
Member#: 165749
the magnaflow is great quality and usually looks fairly stock, other than that it's just your opinion. K/N's oiled gauze filters are not so great for filtration and the better flow is not necessary until significantly more power than stock is going to be made. A quality stock replacement type filter is not a restriction. As far as the intake system goes that Apollo system is so completely different than the stock system and has its own MAF housing so a tune will be absolutely necessary if you want to guarantee safe AFR's and gain any HP. dont expect any power to be gained from the exhaust though. Its just for sound and looks.
Old 10-10-2010, 02:17 PM   #5
09suby
Member#: 222590
2009 Impreza 2.5i
Spark Silver Metallic
yes, the exhaust system is fine... i don't have that exact exhaust but I do have an exhaust made for a wrx, and it made a difference with throttle response, and power up top. But i also have an intake and a tune, and in my opinion the tune is the best mod I have done to my car.
09suby is offline   Reply With Quote
Old 10-10-2010, 04:50 PM   #6
kansai104
Member#: 241019
2010 Impreza 2.5i
RALLY BLUE
Sorry I m a newbi, but I m wondering where to tune the car?? Place for dyno?? how much they go for??
So what u did was that installed wrx exhaust and intake on 2.5i impreza... Do u feel lost of torque At low ref?? I heard high RPM inrease a bit of gAin right??? Sorry I have too questions
Old 10-10-2010, 06:51 PM   #7
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
The intakes definitely flow more up top. I noticed it when I installed my hybrid intake. It's nothing to write home about, but you can definitely feel it.
chazly413 is offline   Reply With Quote
Old 10-10-2010, 08:27 PM   #8
kansai104
Member#: 241019
2010 Impreza 2.5i
RALLY BLUE
so i guess is true what they say on the box....OEM filter is like car breathin through a straw.....what about wrx exhaust system.......would it help?? i know the sound is good...but other than that increase 1hp ???
Old 10-10-2010, 09:20 PM   #9
chazly413
Member#: 151079
2005 2.5RS RBP
It's not the filter, it's the piping between the airbox and the throttle body. I don't get why people think WRX or STI stuff will automatically mean more power. The only thing that will get you noticeable gains out of your exhaust are headers.
This is a hybrid intake:
Old 10-10-2010, 10:14 PM   #10
GrundleJuice
Member#: 165749
All my data showed the feeling of more power up top was only from the AFR's changing to a better ratio.
No, the OEM filter on your car flows plenty unless you start making 200+hp
Old 10-10-2010, 10:27 PM   #11
chazly413
Member#: 151079
2005 2.5RS RBP
Interesting. So, then, per williaty's data, would a more ideal AFR lead to a higher g/rev?
Old 10-10-2010, 10:58 PM   #12
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No.
I have consistently measured increased airflow on my car with the hybrid, once the MAF scaling was corrected to read "true".
And WTF is that thing in the first post? Some kind of condom for Darth Vadar?
Old 10-10-2010, 11:01 PM   #13
RaineMan
Member#: 256727
2007 2.5I Wagon
It's a K&N "Apollo" filter setup. Primarily made for racing applications on vehicles where no aftermarket intakes exist or a different filter location is needed because of modifications.
Essentially some dryer hose with a cone filter on the end.
RaineMan is offline   Reply With Quote
Old 10-10-2010, 11:06 PM   #14
XanRules
Member#: 157348
I Thlammed My
Penith in the Car Door
no, but, you already bought it, so, too late.
XanRules is offline   Reply With Quote
Old 10-11-2010, 08:22 AM   #15
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
Oiled filters have a tendency to coat the MAF I world go with an AVO panel filter and any exhaust you like the sound of, you're not making power of any usable level so it really is about the note
GEE-OTTO is offline   Reply With Quote
Old 10-13-2010, 11:14 AM   #16
kansai104
Member#: 241019
2010 Impreza 2.5i
RALLY BLUE
i m wondering, i dont attach the black hose...is it ok???
Old 10-13-2010, 11:38 AM   #17
JerseyDubbin
Member#: 260054
2004 AW WRX Wagon
VF43, Opensource Tune
If you just run straight to the filter?
JerseyDubbin is offline   Reply With Quote
Old 10-13-2010, 11:54 AM   #18
iRazor
Member#: 257035
2017 WRX/STi
Pure Red
o_O that hybrid hose looks pretty decent (chaz)... how does it run? any MAF issues?
iRazor is offline   Reply With Quote
Old 10-13-2010, 03:27 PM   #19
chazly413
Member#: 151079
2005 2.5RS RBP
It runs great. You can feel a little more kick at the higher RPMs. No MAF issues.
Old 10-13-2010, 09:29 PM   #20
archdude
Member#: 205968
that intake will make you run too lean without a tune.
archdude is offline   Reply With Quote
Old 10-13-2010, 10:29 PM   #21
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Could go either way, actually, depending on exactly how it's laid out.
A better way to say it would be "With that intake, you need a tune.".
Old 10-16-2010, 11:50 AM   #22
midwestmonster
Member#: 54390
2016 Sti w/nav
CWP
Why don't you just leave it stock? I had a 2.5i before I got a wrx. The 2.5i is slow as s**t and not worth dumping any money in. Keep it quiet and stock. It's just going to be loud and slow now. There is a reason they don't make the AP for the NA cars anymore. The gains are nearly nothing.
midwestmonster is offline   Reply With Quote
Is this a good setup for cobb accessport? bballchris24 AccessPort 9 10-13-2009 11:03 AM
Is this a good price for an 06 2.5i? lewisd Canada Region Forum 1 05-21-2006 04:09 PM
Is this a good setup ? Yenners Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-22-2005 03:14 AM
Is this a good gift for a 2.5 year old? Sharkbait Off-Topic 20 12-08-2004 12:09 PM
Utec and greddy profec b spec 2, is this a good setup? M32WRXin3seconds Newbies & FAQs 7 09-08-2003 08:24 PM
