02-22-2005, 12:41 AM | #1 |
Member#: 42232
Is this a good setup ?
Hi all
I was thinking of running a Prodrive axleback+stock midpipe with aftermarket DP and UP . I have a Cobb accessport as well. Will the stock midpipe casue any problems ? Can i run stage 2 mapping with this ? Thanks !
02-22-2005, 01:07 AM | #2 |
Member#: 36049
BAIC
Vehicle:2014 FXT Premium Silver |
yes you can run stage 2 with this setup, and no the resonator pipe will not hinder performance. If it does, it will not be noticeable at stage 2. Are you keeping your 3rd cat, or do you have a full length DP?
02-22-2005, 01:35 AM | #3 |
Member#: 42232
I was going to get either the cobb catted Dp or the Helix one. Do you think the highflow cat will make any difference ?
02-22-2005, 03:14 AM | #4 |
Member#: 54544
Vehicle:2003 WRX SEDAN WRB |
I run stage 2 with just aftermarket catless UP and full length catless DP everything else is stock. I think the biggest offenders are the stock UP/ DP. You could save some money on the axleback too (unless you like the sound ) I have not found it to be necessary.
Is this a good setup | jwhitey | Brakes, Steering & Suspension | 15 | 03-18-2009 06:48 PM |
is this a good setup? | 209.DaNk | Newbies & FAQs | 43 | 12-14-2007 11:53 AM |
Is this a good setup? | Donzo | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 05-10-2006 05:36 PM |
Is this a good setup? what kind of power? | OCrex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 03-16-2005 04:30 PM |
Utec and greddy profec b spec 2, is this a good setup? | M32WRXin3seconds | Newbies & FAQs | 7 | 09-08-2003 08:24 PM |
