12-28-2012, 12:28 AM | #201 |
Member#: 309754
Vehicle:2012 Impreza Sport L Ice Silver Metallic |
yes, I am sorry about the repetitive posting on your thread JDMSTA. I will start another thread under the Impreza forums for the SMD halo questions and install if I go that route. I am leaning towards the SMD's around the round part of the headlight, instead of around the projector itself, more like the E55 BMW, or some E46 have them installed the same way. Thank you for your help and input advise, well appreciated.
12-28-2012, 04:27 PM | #202 | |
Member#: 310615
Vehicle:1213 12'Sport+13'STi Satin White Pearl |
01-11-2013, 04:43 PM | #203 | |
Member#: 342279
Vehicle:2012 Impreza Sport DGM |
01-11-2013, 06:08 PM | #204 |
Member#: 310615
01-11-2013, 08:29 PM | #205 |
Member#: 342279
^ happy to hear that! Did u need the "decoder" that is offered to go with some of the bulbs out there? I'm considering getting some similar LEDs to make my DRLs yellow. I never use my high beams anyways..
01-12-2013, 01:06 PM | #206 |
Member#: 310615
nah, no decoder of some sort needed. the only thing I needed was some in line spliced resistors for the blinkers since I've upgraded those to some cree leds as well.
02-04-2013, 07:28 PM | #207 |
Member#: 345444
Vehicle:2013 Impreza 5-door White |
Hello,
Can you please tell me what you used for the eyebrow light? I don't know what to buy to change it. |
02-05-2013, 09:53 AM | #208 | |
Member#: 330797
Vehicle:2012 Impreza 5dr Prm Satin White Pearl |
hey, didnt get a chance to retrofit the fogs with HID if that is what you are asking. All I've done was add the fogs to the car....getting the car back from the shop soon since the accident, so I'll be able to work on it more. However, I am afraid I won't be adding HIDs to the fogs because I don't want the housing to melt and catch fire like an STI that was posted previously. The front bumper caught fire bc of HIDs in the fogs. |
02-09-2013, 07:58 PM | #209 |
Member#: 343343
VIC
Vehicle:2014 Impreza 5dr Ltd SWP |
Excellent thread, I just finished reading it all. Subscribed! I'm also interested in retrofitting my fogs so keep us up to date.
03-15-2013, 07:35 PM | #210 |
Member#: 350309
Vehicle:2012 Impreza White |
I love this are you still doing the retrofit for other subaru owners?
03-16-2013, 09:26 PM | #211 |
Member#: 310615
I just do it as a side job right now. whenever something comes up that is.
03-17-2013, 08:50 PM | #212 |
Member#: 310615
Alright guys, I've decided to put my fogs back to factory and just use LEDs on it and mod it to use as DRL. Reason being, I only use my fogs in bad weather like rain and especially snowy nights. Well after a couple of snowy nights driving. My retrofitted fogs are pretty much useless. All the snow and slush just piles up against the fogs which pretty much makes it useless. That's why now I've decided to do a quad setup instead using the tiny Morimoto Matchbox projectors in place of the high beam area and use that as my fogs instead. Well enough talking, now onto pictures. Sorry for the daytime pictures being kinda crappy because I took it with my camera phone.
How ya'll like my "switchback" LED strips? Close up of the cutoff lines |
03-17-2013, 09:19 PM | #213 |
Member#: 342279
Those led strips look glorious! do u have both amber and white strips installed? I'm not sure what I'm looking at... it almost looks like ur turn signals are on too.
03-18-2013, 06:22 AM | #214 |
Member#: 310615
yeah I kept the original blinker since its more brighter in the daytime. The strips I used are these http://www.exledshop.com/universal-l...ver2-copy.html and they're not that bight in the daytime. Its more of an aesthetic than anything. I also wired leds inside the Matchbox projectors as amber blinkers as well. I hardly use the fogs like I said, only in bad weather so I figured I go that route.
03-18-2013, 08:16 AM | #215 |
Member#: 271928
Vehicle:2014 WRX Limited Crystal Black Silica |
I'd wait for Trs to start carrying the x.strip, they're the same leds as the xbaleds which are very bright
03-18-2013, 10:13 AM | #216 |
Member#: 310615
I dunno, the way the XBALED rings voltage regulators failing like crazy. I'd wait even longer for them to release a fix for that.
03-18-2013, 10:21 AM | #217 |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
JDMSTA,
did you do wire your fogs to run independent of the headlights? how did you do that? |
03-18-2013, 10:47 AM | #218 |
Member#: 310615
Oh its not wired to be independant. I just did quick mod to run it as DRL instead of the high beam. That pic there with the fogs and inner projectors on is just with the e-brake down to activate the DRL.
03-18-2013, 11:46 AM | #219 |
Member#: 314216
03-18-2013, 02:43 PM | #220 | |
Member#: 315353
Vehicle:2012 Impreza Sp Prem 5MT OBP/DGM |
I would like to get some bright LEDs for the "eye brow" lights and make them my DRLs. |
03-18-2013, 03:20 PM | #221 | |
Member#: 310615
03-18-2013, 04:22 PM | #222 | |
Member#: 342279
Will this wiring mod keep whatever u wire as DRLs on when the low beams are on?
03-18-2013, 04:28 PM | #223 |
Member#: 315353
03-18-2013, 04:29 PM | #224 |
Member#: 310615
03-18-2013, 04:38 PM | #225 |
Member#: 315353
He has his low beams and fogs on at the same time in his pics tho... is that because the fog switch will override the DRLs?
Similar Threads | ||||
[Mini Review] Traded 2011 Impreza Outback Sport for 2012 Impreza Sport Premium | tornado542 | General Community | 22 | 01-11-2015 01:28 PM |
Help with JBL MS-8 install on 2012 impreza sport premium | gobells12785 | Car Audio, Video & Security | 9 | 03-23-2012 09:56 PM |
I finally got a chance to drive a Sprinter. | upnygimp | Off-Topic | 49 | 03-02-2008 01:32 AM |
Finally got a chance to snap some pics | ElDuderino | Member's Car Gallery | 19 | 08-04-2002 03:30 PM |
('93-'01) Finally I got the chance to max out my car. | Chode_boy | Impreza Forum | 11 | 05-22-2002 03:41 PM |
