03-19-2013, 03:38 PM | #5926 |
Member#: 221364
Vehicle:2002 Wrx EJ207 Ver 8 Wrb Dccd jdm 6 speed now! |
This is for an 02 jdm sti it may or may not be here
Look on this http://forums.openecu.org/viewtopic.php?f=15&t=868
03-19-2013, 05:14 PM | #5927 |
Member#: 6886
Vehicle:MY01 EJ207 HTA35r AVCS ON! |
^ you might want to take that FSM link down before getting timeout. Against the forum rules.
03-19-2013, 05:27 PM | #5928 |
Member#: 166324
NESIC
What's against the rules?
03-19-2013, 05:29 PM | #5929 |
Member#: 157692
Vehicle:2004 WRX "Big Red" |
Quick question for everyone. Converting my USDM 2004 WRX widebody with a full version 7 swap. Unfortunately the company I have planned on going through has cut the bulk connectors off of the engine harness. My question is, does the USDM engine harness swap over to the JDM engine? Could I just swap my current WRX harness over, wire AVCS and call it a day? Or are the harnesses different and I should find another motor?
03-19-2013, 05:30 PM | #5930 |
Member#: 166324
NESIC
Contact IAPerformace, they have what you need. You can talk it over with them.
03-19-2013, 05:39 PM | #5931 | |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
I'm positive you can find a motor that has the necessary harnesses uncut, but it's a matter of price and time if it's worth it. If you're paying $4k for your motor package, then it's definitely not worth it, buy one that isn't cut. If you're paying $2k then it's worth building your own harness. In the middle? Find out shipped prices from importers smart enough not to cut the harness and decide on price combined with what you value your time at. Nobody can give you a straight answer on what you "should" do here, since both ways are possible. |
03-19-2013, 05:45 PM | #5932 |
Member#: 4414
There is a TON more meat on the ringlands thanks to the shorter stroke allowing more space between the wrist pin and the top of the piston. Ringlands have never been an issue on the cast 2.0L pistons. 2.0L engines spin bearings or break rods, with rods primarily being an EJ205 issue.
03-19-2013, 05:47 PM | #5933 |
Member#: 6886
03-19-2013, 05:52 PM | #5934 | ||
Member#: 157692
I think I've figured out the plan that is in my best interest, I'll follow up accordingly. Thanks guys! |
03-19-2013, 06:18 PM | #5935 | |
Member#: 221364
these two are shielded by E1: E9 + E15 = avcs camshaft sensor left E2 + E3 = avcs camshaft sensor right E16 + E17 = avcs solenoid left E6 + E12 = avcs solenoid right |
03-20-2013, 09:17 AM | #5936 | |
Member#: 54060
Vehicle:Now: 16 FXT/04v8 207 Then:JRTuned fastest td04 |
Just curious, what happened? |
03-20-2013, 09:43 AM | #5937 |
Member#: 166324
NESIC
He spun a bearing.
03-20-2013, 10:02 AM | #5938 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
Quick inspection question: Failed cause of V8 JDM ECU in NJ
I know I can put a 02-05 WRX MT ECU in and will pass but was wondering if theres any issues I need to be aware of?? I'd have to buy/borrow a ECU and heard that the VIN# is coded into it and they can't be swapped back and forth. Can someone please shed some more light on this subject. |
03-20-2013, 10:20 AM | #5939 |
Member#: 166324
NESIC
If you put a usdm ecu in, it will throw a code for the TGVs. You need to flash a map or use romraider to take care of the usdm ecu with a jdm engine to pass inspection.
03-20-2013, 10:21 AM | #5940 |
Member#: 306719
Vehicle:2003 Sti Wagon @jn_garage |
03-20-2013, 10:26 AM | #5941 |
Member#: 321805
Vehicle:2002 Jdm v9 STI Blue |
03-20-2013, 10:27 AM | #5942 |
Member#: 166324
NESIC
Same here. I'm wondering if there's something underlining to these V9 spun bearings.
03-20-2013, 10:29 AM | #5943 |
Member#: 321805
03-20-2013, 10:32 AM | #5944 |
Member#: 166324
NESIC
I put about 5 gallons of 110 octane and then topped off with 93
03-20-2013, 10:35 AM | #5945 | |
Member#: 6886
NJ inspection just looks for any cels and looks for specific obd2 feed back to pass. The JDM ecu does not reply back on a few tests that the state computer queries about which cause you to fail. |
03-20-2013, 10:41 AM | #5946 |
Member#: 306719
03-20-2013, 10:43 AM | #5947 |
Member#: 321805
03-20-2013, 10:45 AM | #5948 |
Member#: 321805
03-20-2013, 10:53 AM | #5949 |
Member#: 166324
NESIC
Well, it's the mixture. I would have to assume though a mix of 110 and 93 would raise it to more than 93.
03-20-2013, 10:56 AM | #5950 |
Member#: 86107
E. Canada
Morning ladies,
I have my heads apart ( 207 spec c's ) and a buddy gave me BC stainless exhaust valves. Should I stick to factory valves or replace with new BC stainless exaust ones ? They actually seem heavier ( the BC's ) and are flat instead of dome shaped. |
ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-26-2011 07:29 PM |
Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 06-03-2010 04:53 PM |
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 10-17-2005 01:56 AM |
