12-23-2010, 04:26 AM | #1 |
Member#: 252646
SCIC
Vehicle:2002 stage2 wrx aspen white |
only getting 8.7 psi after uppipe/ downpipe install
New problem: only Hitting 8.x psi on ots Cobb stage 2
The shop that installed it said one of the vacuum lines snapped and they replaced it After Christmas I'm going to get all the vacuum lines replaced with brand new ones and see if that solves the problem If not what else might the problem be? It was reaching peak boost perfectly before the install on a stage 1 tune edit:had vacuum lines replaced and it didnt fix the problem Old problem:solved ok so today i had my new perrin uppipe and cobb catted downpipe installed at a shop and i had all new gaskets for them except for the donut gasket which i told the shop to just use the one already on the car they said sure that wouldnt be a problem when they finished my car they said that my downpipe wasnt sealing with my midpipe correctly or something and there was a leak and its loud and sounds like crap they said i needed a donut to flat flange adapter? anyways when i got home and took my stock pipes out of my truck i noticed the donut gasket was still on the stock downpipe -_- when i emailed the shop they responded with "that one doesnt work that well bro" i emailed them back asking if they put a different one on but didnt get a response, which is understandable because it was after they closed do you guys think that they really could have not even put a gasket on at all between the downpipe and the mid pipe? how hard would it be to just put in the donut gasket myself? and how bad is it to drive the car without it?
12-23-2010, 06:31 AM | #2 |
Member#: 59465
South East
Vehicle:2003 Bugeye G8RH8R |
I have the oem donut on my cobb catted down and it fits without any leaks. It is just two spring bolts and you can put it on yourself. You can do it with ramps if you have a set. Should take you thirty min. What are you using for your catback?
12-23-2010, 10:00 AM | #3 |
Member#: 193989
South East
Vehicle:2007 Stormy Blue Blown Roadster |
Not trying to be a dick here, but a little reading goes a LONG way.
There are FAQs that answer a lot of the questions you will have, and keep you from making mistakes like this. Most aftermarket downpipes use a flat 2-bolt 3" flange, while the factory catback (and some aftermarket) use a donut gasket to allow for a 'flexible' joint so that there isn't a lot of stress on the turbo or entire exhaust when the turbo torques. A flat 2-bolt flange doesn't mate to the donut gasket joint flange, and you will have fitment issues and an exhaust leak. You can either buy a 2-bolt 3" flange and have it welded in, or you can buy an adaptor to work. The adaptor you are looking for is similar to this: http://www.maperformance.com/cnt-rac...11400-wrx.html You will also want to check out the FAQs and the Search function next time before you decide to do anything else, trust me, it will help out in the long run. http://forums.nasioc.com/forums/show....php?t=1169980 |
12-23-2010, 10:54 AM | #4 |
Member#: 252646
SCIC
Yeah that's what I though
I just couldn't believe a shop that claims to specialize in subies overlooked something like that And not to be a dick or anything But I did The Cobb downpipe tapers to 2.5 inches after the cat so it can hook up to the stock midpipe with no problems I assumed that was common knowledge My bad And yeah I've read all of the "hey read this first!!!" threads and rules and such I'm not new to online communities in general and though I am relatively new here, despite my low post count, I have been reading a lot of stuff on here and I understand how easily it is to ask a question get just get a reply that says "search for it" or "read the sticky" I couldn't find any threads about a shop forgetting to put on a gasket during an install and I wanted to know if anyone thought this could actually be the case |
12-23-2010, 11:14 AM | #5 |
Member#: 232418
Vehicle:2002 WRX Wagon WRB |
Disconnecting the two pipes is very easy. Jack it up and take a look. I just put a new stock donut gasket between my HKS downpipe and STI cat back. It sealed well and has no leaks.
12-23-2010, 11:28 AM | #6 |
Member#: 215454
Vehicle:2005 9-2x Aero Black |
I used 2 gaskets from Autozone.
A stock 2.5 inch donut gasket and a 3inch flange gasket. slapped 'em together and it works perfect. cost about 20ish. Might try something similar mating a donut and a flange gasket. I had to take all the hangers off to get the exhaust system to line up right but was an easy fix to an exhaust leak that sounded horrid |
12-23-2010, 12:06 PM | #7 |
Member#: 59465
South East
12345
Last edited by 03STAGE2; 12-23-2010 at 12:22 PM. Reason: Had to figure out the right way to embarass W.H.O. |
12-23-2010, 12:20 PM | #8 | |||
Member#: 59465
South East
Let me stop you right there.... He is not putting on MOST catbacks. He is putting on a Cobb catback. I suggest you read up on them. It will save you the time in the future from typing out posts that contain bad information. Quote:
12-23-2010, 03:03 PM | #9 |
Member#: 262719
NESIC
Vehicle:02 WRX PSM with rust accents |
OP, if you're feelin ballsy you can take a file and SLIGHTLY bevel the inside of the cbe flange so it will fit around the donut. what cbe are you using?
12-23-2010, 03:04 PM | #10 |
Member#: 252646
SCIC
Thanks for the help guys
And I fixed it kinda I couldn't get the old donut gasket completely on the new downpipe because it was really tight (I think thats kinda the point) but I got it on somewhat and tightened both bolts as tight as they would go It sounds sooooo much better Haven't taken it on a pull or anything yet but idling and revving sound infinitely better Even If it isn't completely fixed, it good enough for me at least for not I'm going to buy a new gasket soon and then I'll see if I can get it on better |
12-24-2010, 01:15 AM | #11 |
Member#: 252646
SCIC
Ok so
From what I can tell, the exhaust leak is gone Unfortunately after flashing to stage 2 (I flashed right after the install before driving it) I haven't been able to hit target boost The highest it's been is 8.8 psi at wot in 3rd gear I don't exactly remember what target boost for the ots stage 2 map from Cobb is but I'm pretty sure its about double what I'm currently getting... The shop that did the install said a vacuum line snapped and they replaced it for free I'm pretty sure they said it was for the bcs I know "pretty sure" isn't ideal but it's all I have :/ anyways Since they seemed to forget to put on the donut gasket, do you think its possibly they forgot to replace the line? And if they did replace the line what might my problem be? Edit: Before the install I was reaching target boost on stage1 |
12-24-2010, 05:43 AM | #12 |
Member#: 59465
South East
LOL... Nice PM WhyHello. I should post it up to show how much of a douche you really are. You tried to flame a member without knowing anything about one of the most popular exhaust systems and failed. To be honest, it did make me feel great to smack you down off your "I am a subaru thread genius" cloud.
OP... Sounds like you are running at waste gate spring pressure. You are going to have to check the hoses and see if they damaged more than they let on. They may have put a hose on that is not the same id and it is not sealing. Also try to flash back to stage 1 and see if you get more than 8psi. My guess is that you will not and then you know its a leak. See how easy that was WhyHello? Owning a subaru is like joining a family. Dont be a dick and help your brother out. |
12-24-2010, 07:21 AM | #13 |
Member#: 248911
Vehicle:'04 WRX Waggie RIP '06 OB 5MT |
It felt good to watch (read). There's so much false information promotion going around (intentional or not), I just assume it's all false until proven otherwise. Like wikipedia. Glad to see at least some people are policing the ass-hats.
12-24-2010, 11:59 AM | #14 |
Member#: 252646
SCIC
Thanks guys
If there was a problem with the hose wouldn't i be overboosting instead of underboosting? This problem is making me very sad |
12-24-2010, 11:11 PM | #15 |
Member#: 45076
Vehicle:2004 Stg 2 wagon AT 16 BRZ. Both silver |
I just had the same issue. I used two 3 inch gaskets. So far so good. I have the donut gasket just in case. I did not like the fitment compared to two gaskets.
12-31-2010, 02:28 PM | #16 |
Member#: 252646
SCIC
Update:
I got all the lines replaced and I'm still not getting boost past 8.7 psi I'm gonna try ordering a new restrictor pill because I don't think there is one in there now I really hope that works I'm starting to lose hope in ever feeling full boost again |
12-31-2010, 03:07 PM | #17 |
Member#: 238584
Vehicle:2002 WRX Wagon Soon to be Utec'd |
I feel your pain.....im having misfire problems everytime i get near 10psi it normally runs at 15psi. So ive been having to drive it without hardly getting out of vaccuum because it is my only car i have no choice but to ***** foot it everywhere.
12-31-2010, 03:08 PM | #18 |
Member#: 256841
BAIC
Vehicle:2004 FXT Aspen White |
There is a possibility that your boost solenoid crapped out or the flash is bad. Try flashing back to stock stage1 and see what kind of boost numbers you get. Also if you have a friend with a suby, swap out the boost solenoid and see if that fixes the boost issues.
Only two things I can think of atm. When I had a cobb, I noticed it was very picky about battery voltage being above a certain number so whenever I flashed, I always made sure I had an extra battery attached as well. |
12-31-2010, 03:14 PM | #19 | ||
Member#: 252646
SCIC
how much is a new oem solenoid? and maybe im miss understanding the function of the bcs but isnt it there to limit the boost? so if it went out my boost would be through the roof? i think im going to try taking it to the dealership and see if they can fix it i dont care if they will charge more than my usual mechanic at this point my usual mechanic is a honda/ acura specialist and i really dont like taking my subaru there |
12-31-2010, 03:57 PM | #20 |
Member#: 256841
BAIC
Its about 30$ used, not sure what it is new. Like I said if you have a friend with a suby, its very easy to swap out to see if thats the problem.
Since the problem happened after/during the work they were doing, is it possible to take it back to the shop and have them smoke test to make sure you dont have a rip in your inlet or any other hoses leaking? |
12-31-2010, 04:36 PM | #21 | |
Member#: 244034
South East
Vehicle:2003 wrx wrb vf22 |
If someone asks a question help them out not tell them to search for it. If you know the answer say it, if not don't say anything so the OP doesn't get clogged up with garbage and fighting. This is a learning and helpful forum not let's be a dick forum. |
01-01-2011, 03:22 PM | #22 |
Member#: 252646
SCIC
how do i push the wastegate open and closed?
i feel like its a really obvious answer but when i checked out my wastegate actuator and everything it was attached to, nothing seemed to budge |
01-01-2011, 04:10 PM | #23 | |
Member#: 266836
South East
Vehicle:2004 WRX WRB |
You can see if the wastegate will open or not , by taking the wastegate arm off the flapper door arm . Theirs a little "C" clipe that holds the waste gate arm onto the flapper door arm. Pull "C" clip off with some needle nose plyers and pop the waste gate arm off of the flapper door arm. You can then push/pull the waste gate arm to see if it moves or not and also check to see if the flapper door is opening as well. |
01-01-2011, 04:27 PM | #24 |
Member#: 244034
South East
^^^ exactly, you should be able to hear it open and close each time to know it's functioning properly.
01-01-2011, 04:46 PM | #25 |
Member#: 266836
South East
Yea , also pull the vacuum line off the waste gate and when your pushing/pulling on the wastegate arm , you can hear/feel air come out or being sucked in.
FS : Donut gasket, DP Gasket, Stock midpipe, WRX TMIC, Wagon Yakima Racks | subiedrewbie | SCIC Private Classifieds | 23 | 12-25-2010 01:39 PM |
FS : WRX TMIC Core, stock midpipe, DP to turbo gasket, donut gasket | subiedrewbie | Engine/Power/Exhaust | 10 | 12-20-2010 01:42 AM |
WTB Donut Gasket, AKA flex joint gasket | notjustforshow | VIC Private Classifieds | 4 | 02-03-2009 03:58 AM |
CA WTB: 3" downpipe (dp -> cat) gasket, and 3" donut gasket. | lugee | Private 'Wanted' Classifieds | 0 | 12-13-2005 03:44 AM |
What is a donut gasket? pics? | WR-REX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 07-31-2002 08:01 PM |
