Welcome to the North American Subaru Impreza Owners Club Thursday September 18, 2014
Old 05-19-2011, 04:33 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ - 2005 STI Simple Setup on E85 - 347whp/423ft-lbs!
Here is a 2005 STI I tuned last week on E85 that turned out really nice.
Event: Custom Tune/Dyno
Ambient Temp: 80 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2005 Subaru STI
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 347whp @ 5000RPM
Peak Torque at RPM: 423ft-lbs @ 3750RPM
Target Boost: 23psi peak
Fuel: E85
Engine/Power Modifications:
Catless TBE
Perrin EL Headers
Perrin Inlet
Perrin CAI
DW850cc Injectors
Walbro Fuel Pump
Hallman MBC
EQ Custom Tune
*** Standard Dyno Chart Disclaimer ***
This dyno reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock 02-05 WRX - 155-165whp
Stock 04-07 STI - 215-220whp
Stock 08-11 STI - 190-200whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
350-360whp - 120-121mph traps
-- Ed
Old 05-19-2011, 08:58 PM   #2
KpT KiM
Member#: 242422
That's some nice torque. Seems like it drops off kinda fast though.
KpT KiM is offline   Reply With Quote
Old 05-19-2011, 09:16 PM   #3
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
For a stock turbo it doesn't drop off fast at all, considering how much torque its pushing. That little vf39 is all out of breath up top. Looks like a very powerful/aggressive setup for the few mods it has. I wouldn't expect that turbo to last very long at that boost level
VladiWrX is offline   Reply With Quote
Old 05-19-2011, 09:27 PM   #4
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
At 23psi? I bet it lasts just fine. I've had customers running around at 25psi for years with no issues. Remember its only 23psi in the mid range... it tapers off to about 15psi by redline.
-- Ed
Old 05-19-2011, 11:29 PM   #5
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Rotated BW S200sx-56
I wish I had torque numbers like that. It's crazy how a different type of fuel can add 100+ lbft of torque.
DerekB707 is offline   Reply With Quote
Old 05-20-2011, 04:48 PM   #6
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep.. E85 is great stuff
-- Ed
Old 05-20-2011, 05:28 PM   #7
SomeYoungGuy
Member#: 67855
That is an amazing result for the stock exhaust. Was this kept for smog reasons?
SomeYoungGuy is offline   Reply With Quote
Old 05-20-2011, 09:30 PM   #8
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Hah.. sorry about that! Its not a stock exhaust. This car does have a catless TBE.
-- Ed
Old 05-20-2011, 11:18 PM   #9
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
Nice work! the curve looks great!
YZ86 is offline   Reply With Quote
Old 05-20-2011, 11:27 PM   #10
steve1578
Member#: 283348
Dang that's amazing.
steve1578 is offline   Reply With Quote
Old 05-23-2011, 06:32 PM   #11
JoeTX
Member#: 83069
2007 STi 302/350
UGM Wingless
Just a fantastic tune (~300ft/lb at 3K! and youve still got 123ft/lb more to go!!!) the low end response has to be downright brutal. And all on a stock turbo. And has been said many times before... E85 FTW.
Is E85 in any way easier on the internals? This is the power level where Id start getting concerned about something letting go.
JoeTX is offline   Reply With Quote
Old 03-04-2012, 07:21 PM   #12
AWDDriver
Member#: 312472
Can an STi have 400 - 500 WHP on regular gas so it can travel to anywhere and not have to located E85 gas station?
AWDDriver is offline   Reply With Quote
Old 03-04-2012, 07:23 PM   #13
AWDDriver
Member#: 312472
I need a fast STi or EVO where it can travel to anywhere on regular gas and not have to worry about E85 gas location!
Old 03-04-2012, 07:49 PM   #14
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Just get an AP and have dual tunes, make sure ure injectors aren't too big so it'll run good on pump.
smeerone is offline   Reply With Quote
Old 03-04-2012, 08:18 PM   #15
Kastley85891
Member#: 127704
2013 Hybrid
Needs an 05STI
Awesome,, easy mods great power/TRQ
Do you feel much benefit to the catless?
Kastley85891 is offline   Reply With Quote
Old 03-05-2012, 10:51 AM   #16
iMpOrTz_
Member#: 304191
2004 STI
i have similar set up but not on e85 though
iMpOrTz_ is offline   Reply With Quote
Old 03-05-2012, 10:54 AM   #17
Irv Weissmanhowerton
Member#: 278519
30r E85 STI K'biz
Phatbotti Tuning
holy stock turbo tq, wow, that is impressive for such simple mods, more people need to see what e85 can do for us
Irv Weissmanhowerton is offline   Reply With Quote
Old 03-05-2012, 12:40 PM   #18
ArSoN9
Member#: 285777
2004 STi-
Nice work EQ this really shows off the benefits from E85 and might show a few people that you dont need to swap out the stock turbo to hit these kind of numbers...Just a fuel pump and injectors..
It would make a lot more sense for those looking to get safer power while allowing the performance to be pushed further than on pump gas and meth even
ArSoN9 is offline   Reply With Quote
Old 03-05-2012, 12:44 PM   #19
stu
Member#: 25768
35R bugeye
Slowbaru
that is impressive for stock turbo. Keep up the good work.
stu is offline   Reply With Quote
Old 03-05-2012, 01:18 PM   #20
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
I'm dumb,
I was looking all through his mod list to find what turbo he was using lol
Old 03-05-2012, 10:28 PM   #21
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Fuel: E85
Catless TBE
Perrin EL Headers
Perrin Inlet
Perrin CAI
DW850cc Injectors
Walbro Fuel Pump
Hallman MBC
EQ Custom Tune
-- Ed
Dang this is my set up minus e85 and headers witch im looking into getting this summer with ewg hope my numbers are close to yours did you ever have your car at just stage 2 would like to know the difference to what ya have now not numbers but just how it drives
Coreycarlile911 is offline   Reply With Quote
EQ - 2007 STI, Blouch DOM 3XTR, E85 - 420whp at only 20psi... more to come! Equilibrium Tuning Proven Power Bragging 68 05-21-2011 08:23 AM
EQ - 2006 STI TBE, CAI, EL Headers - 295whp/338ft-lbs on 91 Octane! Equilibrium Tuning Proven Power Bragging 7 05-07-2011 05:32 PM
EQ - Bugeye JDM EJ207 Swap on E85 - 330whp/348ft-lbs! Equilibrium Tuning Proven Power Bragging 39 03-20-2011 04:23 PM
Siegal Tuned: 05 STi, VF39 on E85 - 293 HP, 386 TQ on Dyno Dynamics! NaiveRapture Proven Power Bragging 14 05-23-2010 11:28 AM
EQ Tuning: - 2009 WRX Simple Setup, Great Power! Equilibrium Tuning Proven Power Bragging 20 03-04-2010 03:07 PM
