08-03-2004, 02:33 PM | #1 |
Member#: 67542
1988 subaru gl wagon turbo full time 4 wheel auto
hi every one i have 1988 gl wagon turbo i just changed the engine now when i put in the transmission did not want to seat at about 1/4" left so i turned the crank and bolted up when i went to start engine run and made a sound like spliens meshing and stoped also when i pulled engine the inner front shaft on trans came out with torque converter so put back in trans. thought i would say that. so when i put in gear car would not go till i reved up a bit its full of fulid and now it doesent move is it my torque converter or is there a vacume modulator on this hope some one can help a new member.
08-04-2004, 12:33 AM | #2 |
WCSS Drunk
Moderator Member#: 8914
NWIC
Vehicle:2005 Baja Sport Regal Blue Pearl |
Uhhh I hate to tell you this, but I am told that when that shaft slides out, the gears or whatever was on them back in the tranny probably moved out of alignment... so it could quite possibly be time to rebuild the tranny. Or switch to a 5 speed.
08-04-2004, 02:04 AM | #3 |
Member#: 54398
NWIC
Vehicle:1980 CB400 Hawk 1996 GrandCherokeeLimited |
While I don't know what the problem is, I will say that last week I did the same thing with the inner shaft on an auto tranny while pulling it... slid it back in and everything has been fine... Just have to make sure it really went all the way back in or you could be in trouble
08-05-2004, 12:29 AM | #4 |
WCSS Drunk
NWIC
Sounds like you got lucky Caleb... i suppose if everything was in just the right place you may get lucky and parts may re-allign.
I got lucky and it was the bad tranny I was REMOVING that had the shaft come out. The one going in (from Mark) had baling wire holding everything in... kept that wire on there until I was just about ready to mate up the bell housing. Isnt my new title cool?? |
08-05-2004, 02:10 AM | #5 |
Member#: 54398
NWIC
Actually mike, the shafts go in and out fairly easily
YOu just have to make sure its all back in correctly before installation, or you will destroy the front pump. The inner shaft has slid out of every soob auto I have ever pulled. I have sold or reused at least 5 of those with no troubles.. the rest were scrapped, usually due to diff problems |
Similar Threads | ||||
1988 Subaru GL-10 AWD Turbo - only 74K miles | Got Boost | Private Vehicle 'For Sale' Classifieds | 0 | 12-10-2008 09:01 PM |
1986 Subaru GL 4WD Turbo Wagon - SoCA | rB5 | Private Vehicle 'For Sale' Classifieds | 10 | 12-06-2008 07:37 PM |
VA: 1988 Subaru GL-10 $1,000 obo | cbbwrx | Private Vehicle 'For Sale' Classifieds | 11 | 02-28-2008 12:09 PM |
Wanted: 1988 Subaru GL XT fuel pump | Gravy66 | Private 'Wanted' Classifieds | 0 | 04-04-2006 08:57 PM |
FS: 1988 Subaru GL Wagon (Mechanic's Special - PHX, AZ) | The.Shady.Milkman | Private 'For Sale' Classifieds | 0 | 07-28-2005 07:46 PM |
