03-16-2008, 01:19 PM | #1 |
Member#: 146137
Vehicle:06 WRX R.I.P. 06.06 - 10.08 |
oil change ? jack or flat
when i go to take out the drain plug and fliter, i will have to jack the car up to get under there, but should i put it back down while the oil is draining?
also, in the subymods how-to, they said to take of the oil filter first, let the oil drain and then do the drain plug. would it be a problem if i did the drain plug first and then the filter? it seems doing the filter first would make much more of a mess. |
03-16-2008, 01:54 PM | #2 |
Member#: 140244
MWSOC
Vehicle:2002 bugeye still rippin' hard |
I drive up on rhino ramps, take out the drain plug first, wait, than take the oil filter off. Been doing that way for 7 years, and almost 50 oil changes.
03-16-2008, 02:32 PM | #3 |
Member#: 119532
Vehicle:2006 WRX |
I run my car up on some 2x6 pieces and it is high enough to get under
my driveway also has a slight slope to it so i park with the nose downhill and it is just fine |
03-16-2008, 04:34 PM | #4 |
Member#: 146137
so i guess it really does not matter, flat or lifted on an angle. i have the option to do either so which would u recommended?
03-16-2008, 07:02 PM | #5 |
Member#: 41070
Vehicle:2005 Black Tiger (Black Turbo Baja) |
It really doesn't matter. I recommend doing whatever works out easier for you.
03-16-2008, 11:42 PM | #6 |
Member#: 155411
Vehicle:2006 Miata 2015 WRX |
I jack up the car to get the plug off, then lower the car after a while to increase the flow. If the flow doesn't change i just leave it up.
03-17-2008, 08:45 AM | #7 |
Member#: 171713
NESIC
Vehicle:2000 Impreza 2.5RS Silverthorn Metalic |
I'm able to get under there with a pan without taking the car off the ground. I love it. Easy oil changes ftw!
03-17-2008, 09:54 AM | #8 |
Member#: 73043
MWSOC
Vehicle:2019 STI/370Z/Jeep Black/Black Cherry/Green |
Just make sure that if you don't use ramps and use a jack that you use jack stands also. Just had a friend lose his son last week when the jack he used gave way and crushed him. He just got under it quick to check his oil filter to see if it was lose. RP
03-17-2008, 12:17 PM | #9 |
Member#: 26770
South East
Vehicle:'02 WRX midnight black |
Thats horrible, sorry to hear that.
If you are not sure if your car is supported well enough, then it isn't. Jack stands are the best assurance you can have (on a solid surface). I've used ramps for years and have never had a doubt about their safety tho. On the '02 wrx, the pan plug is towards the rear, so raising the front IMHO is better. In reality, flat or front raised, not much of a difference. |
03-17-2008, 08:53 PM | #10 |
Member#: 145108
Vehicle:2002 Impreza TS Aspen White |
I can reach the drain plug just fine without ramps, but I have monkey arms. The filter, on the other hand, is in the absolute worst possible place, and getting to it without ramps (or jacking it) is a gigantic pain.
Just leave the car up while it drains, don't bother moving it until you're done. Check the level when it's flat, not on the ramps, of course. |
03-17-2008, 09:58 PM | #11 |
Member#: 155411
while we're on topic of rasing cars, where should i put the jack when raising it?
03-18-2008, 07:52 AM | #12 |
Member#: 171713
NESIC
Check your service manual when in doubt.
If you want to do one wheel at a time the jack points are just behind the front wheels and just infront of the rear wheels. You can also use the rear diff if you want to raise the back of the car, or the front cross member if you want to jack up the front. ALWAYS USE JACKSTANDS scroll down through this thread to see a good diagram of the jackpoints for your scooby: http://forums.nasioc.com/forums/show...ght=jack+point |
03-18-2008, 08:15 AM | #13 |
Member#: 155411
thanks, i know about the jackpoints next to the wheels, but i was thankinging that it would be better to jack it up somewhere in the middle and a front cross member would be perfect for that. yes i always use jackstands.
03-18-2008, 10:30 AM | #14 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
I left the undertray off and can change my oil/filter with the car on the ground, no problems.
03-18-2008, 12:33 PM | #15 |
Member#: 129743
TXIC
Vehicle:2009 335i Jet Black |
i have a fumoto drain valve, so not i only change the oil on flat ground, but i dont need any tools either.
03-18-2008, 12:34 PM | #16 |
Member#: 64485
SCIC
Vehicle:2004 GGA |
i go up some 2"x6", then i jack it up, place ramps underneath, move the jack to the drivers side and have it up as back up...then i remove the splash guard and do the oil change.
be safe |
Similar Threads | ||||
Gear Oil Change??? | wickkerr82 | Newbies & FAQs | 6 | 06-04-2010 01:35 PM |
Jack or Ramp for oil change? | FreytheViking | Newbies & FAQs | 33 | 07-09-2009 08:42 PM |
05 STI, First Oil Change 1k or 3k? | ixusracing | Service & Maintenance | 20 | 02-04-2005 09:55 PM |
Oil Change (FUD or not)? | Arcanum5 | General Community | 13 | 07-22-2004 07:14 PM |
1st oil change - 1K or 3K | wuckers | Forester Forum | 6 | 07-24-2003 01:10 PM |
