07-19-2006, 04:15 PM | #1 |
Member#: 63060
Vehicle:0005 RS, 92X silver, red |
Need UTEC map for STI w/20g and fmic
Im looking for a map for my '04 STI with 255pump, 850 injectors, td06 20G turbo and Turbo XS fmic. I just need something so I can drive the car to get it dyno tuned. Anybody have one or know where I can get one?
07-19-2006, 10:27 PM | #2 |
Member#: 37617
Vehicle:2007 |
How far's the drive? Do you have a laptop? You should be able to just rescale the injectors and drive nice (keep it under 4000, light throttle) on the stage II map to the tuner.
07-19-2006, 10:50 PM | #3 |
Member#: 63060
Drive is about 45 minutes. I do not have a laptop and didnt plan on doing any of my own tuning. I have headers and full 3" exhaust, would that change things?
07-19-2006, 11:37 PM | #4 |
Member#: 37617
Vehicle:2007 |
So you were going to pull the UTEC out of your car and hook it to your desktop to load a map? Or borrow someone else's laptop? Headers will change the final tune, but again, you could just drive nice on stage II. I had a 40 mile drive to my tuner when I went from stage I to stage IV, and had no problems just driving on the stage II map with rescaled injectors.
07-19-2006, 11:54 PM | #5 |
Member#: 63060
Just looking to pull the UTEC and download a map. Gonna make the drive by myself so I wouldnt need a laptop fpr the drive. Thats why I was looking for a map that was close to my setup, is a stage II REALLY that close to my setup?
07-20-2006, 12:02 AM | #6 |
Member#: 37617
Vehicle:2007 |
No, but you've basically installed what I installed... And I drove on the stage II map just fine. Obviously don't go WOT....
Even if someone gives you a map, you're still going to have to rescale the injectors unless they give you their parameters file also. And that might not be a good idea. |
07-20-2006, 12:06 AM | #7 |
Member#: 99745
Vehicle:2018 Forester 2.5i P Quartz Blue Pearl |
subscribed
07-20-2006, 12:14 AM | #8 |
Member#: 63060
Whats wrong with using their parameter files? I figured i'd be good cause Id only drive for a few hours without going over @4k rpms the whole time??? Am I gonna have to have my car flatbedded to the shop?
07-20-2006, 12:19 AM | #9 |
Member#: 37617
Vehicle:2007 |
Their parameters file may have completely different settings for MAP calibration, scaling, boost gain, etc. I just wouldn't do it. No you don't have to have your car flatbedded to the shop. I've already told you what to do.
07-20-2006, 04:26 PM | #10 |
Member#: 63060
I do appreciate your help but, I dont know anything about scaling injectors or tuning myself. What would I need aside from the laptop? TurboXS tuner? Would I have to be driving the car while doing it?
07-20-2006, 04:48 PM | #11 |
Member#: 99745
somewhere in the parameters file is an option for scaling injectors. you just need to be connected to the utec to do it. don't drive the car while making changes. only the igition needs to be on to connect to the utec. since you don't have a laptop, you could use the supplied 9v adapter and use the home pc, then reinstall the utec.
the turbosxs tuner is required for tuning, but you are not going to tune your map, someone else is, so don't worry about that part. |
07-20-2006, 04:56 PM | #12 |
Member#: 63060
How would I know what to set the (values/ratios/whatever) to when scaling?
07-20-2006, 05:29 PM | #13 | |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
I took the liberty of changing the boost map so you dont get into too much trouble.
Code:
[START][MAPGROUP1][MAPGROUP] Map Name:-[20g 850CC] Map Comments:-[10.9:1, 20PSI, 93oct] Fuel Map [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [-2.1] [-0.6] [-0.2] [0.1] [0.4] [0.6] [0.6] [0.6] [0.6] [0.6] [0.6] [-1.8] [-0.6] [-0.2] [0.1] [0.4] [0.6] [0.6] [0.6] [0.6] [0.6] [0.6] [-1.5] [-0.6] [-0.2] [0.1] [0.4] [0.6] [0.6] [0.6] [0.6] [0.6] [0.6] [-1.2] [-0.6] [-0.2] [0.1] [0.4] [0.6] [0.6] [0.6] [0.6] [0.6] [0.6] [-0.9] [-0.6] [-0.2] [0.1] [0.4] [0.6] [0.6] [0.6] [0.6] [0.6] [0.6] [-0.6] [0] [0.4] [0.7] [0.6] [0.8] [0.6] [0.6] [0.6] [0.6] [0.6] [-0.3] [0.4] [0.5] [0.8] [0.9] [1.2] [1.3] [1.3] [1.3] [1.3] [1.3] [0] [0.4] [0.3] [0.6] [0.9] [1.2] [1.3] [1.3] [1.3] [1.3] [1.3] [0] [0.4] [0.3] [0.6] [1.2] [1.4] [1.3] [1.3] [1.3] [1.3] [1.3] [0] [0.4] [0.2] [0.4] [1.1] [1.5] [1.5] [1.5] [1.5] [1.5] [1.5] [0] [1.8] [1.8] [1.5] [1.8] [1.9] [1.9] [1.9] [1.9] [1.9] [1.9] [0] [1.8] [1.7] [1.6] [1.6] [1.8] [1.8] [1.6] [1.6] [1.6] [1.6] [0] [1.8] [1.9] [1.9] [1.9] [1.9] [1.9] [1.9] [1.9] [1.9] [1.9] [0] [1.9] [2.3] [2.2] [2.5] [3.1] [3] [3] [3] [3] [3] [0] [0.1] [-0.1] [0.1] [0.6] [0.6] [0.6] [1.1] [1.1] [1.1] [1.1] [0] [-0.1] [-0.2] [0.3] [0.6] [0.6] [0.6] [1.1] [1.1] [1.1] [1.1] [0] [0.3] [0.2] [0.8] [0.6] [0.3] [0.3] [0.5] [0.5] [-0.2] [-0.2] [0] [0.3] [0.2] [1] [0.6] [0.3] [0.3] [0.5] [0.5] [-0.2] [-0.2] [0] [-3] [-2.6] [-2.2] [-2.2] [-2.2] [-2.2] [-2.2] [-2.2] [-2.2] [-2.2] [0] [-2.7] [-2.3] [-1.9] [-1.9] [-1.9] [-1.9] [-1.9] [-1.9] [-1.9] [-1.9] [0] [-1.9] [-1.8] [-1.8] [-1.8] [-1.8] [-1.8] [-1.8] [-1.8] [-1.8] [-1.8] [0.2] [-1.8] [-1.4] [-1.5] [-1.5] [-1.5] [-1.5] [-1.5] [-1.5] [-1.5] [-1.5] [0.5] [-2] [-1.6] [-1.5] [-1.5] [-1.5] [-1.5] [-1.5] [-1.5] [-1.5] [-1.5] [0.4] [-1.7] [-1.2] [-1] [-1] [-1] [-1] [-1] [-1] [-1] [-1] [0.4] [-1.6] [-1.2] [-0.8] [-0.8] [-0.8] [-0.8] [-0.8] [-0.8] [-0.8] [-0.8] [0.5] [-1.5] [-1.1] [-0.7] [-0.7] [-0.7] [-0.7] [-0.7] [-0.7] [-0.7] [-0.7] [0.5] [-1.4] [-1] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [0.5] [-1.4] [-1] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [0.5] [-1.4] [-1] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [0.5] [-1.4] [-1] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [0.5] [-1.4] [-1] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [0.5] [-1.4] [-1] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [0] [-1.4] [-1] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [-0.6] [0] [-1.1] [-0.7] [-0.3] [-0.3] [-0.3] [-0.3] [-0.3] [-0.3] [-0.3] [-0.3] [0] [-1.1] [-0.7] [-0.3] [-0.3] [-0.3] [-0.3] [-0.3] [-0.3] [-0.3] [-0.3] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] Timing Map [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [12] [15] [27] [25] [22] [19] [16.5] [15] [14.5] [14] [-100] [15] [18] [27] [25] [22] [19] [16.5] [15] [14.5] [14] [-100] [18] [21] [27] [25] [22] [19] [16.5] [15] [14.5] [14] [-100] [19] [22] [23] [25] [22] [19] [16.5] [15] [14.5] [14] [-100] [20] [26] [23] [25] [22] [19] [16.5] [15] [14.5] [14] [-100] [24] [26] [23] [25] [22] [19] [16.5] [15] [14.5] [14] [-100] [26] [26] [23] [25] [22] [19] [16.5] [15] [14.5] [14] [-100] [29] [26] [23] [24] [22] [19] [17.5] [16] [15.5] [15] [-100] [32] [25] [23] [21] [19] [18] [16.5] [15] [14] [13.5] [-100] [35] [25] [20] [20] [18] [17] [15.5] [14] [13] [12.5] [-100] [35] [25] [20] [19] [17] [16] [14.5] [13] [12] [11.5] [-100] [35] [25] [20] [18] [16] [15] [13.5] [12] [11] [10.5] [-100] [35] [25] [20] [18] [16] [15] [13.5] [12] [11] [10.5] [-100] [35] [25] [20] [18] [15] [14] [12.5] [11] [10] [9.5] [-100] [35] [25] [20] [20] [16] [14] [13.5] [12] [11] [10.5] [-100] [35] [25] [20.5] [20.5] [16.5] [14.5] [13] [12.5] [12] [11.5] [-100] [35] [25] [21.5] [21.5] [17.5] [14.5] [14] [13.5] [13] [12.5] [-100] [35] [25] [21.5] [21.5] [17.5] [15.5] [15] [14.5] [14] [13.5] [-100] [35] [30] [25] [23] [19.5] [18.5] [17] [16.5] [15] [14] [-100] [35] [30] [25] [23] [19.5] [18.5] [17] [16.5] [16] [15] [-100] [35] [30] [26] [24] [20.5] [19.5] [18] [16.5] [16] [16] [-100] [35] [30] [26.5] [24.5] [21] [20] [19] [17.5] [17] [17] [-100] [35] [30] [27] [24.5] [21] [20] [19] [18.5] [18] [17] [-100] [35] [30] [28] [25] [21.5] [20.5] [19.5] [19] [18.5] [17.5] [-100] [35] [30] [29] [26] [22] [20.5] [19.5] [19] [18.5] [17.5] [-100] [35] [30] [29] [26] [22] [20.5] [19.5] [19] [17.5] [17] [-100] [35] [30] [29.5] [26.5] [22.5] [21] [20] [19] [17.5] [17] [-100] [35] [30] [29.5] [26.5] [22.5] [21] [20] [19] [17.5] [17] [-100] [35] [30] [29.5] [26.5] [22.5] [21] [20] [19] [17.5] [17] [-100] [35] [30] [29.5] [26.5] [22.5] [21] [20] [19] [17.5] [17] [-100] [35] [30] [29.5] [26.5] [22.5] [21] [20] [19] [17.5] [17] [-100] [35] [30] [29.5] [26.5] [22.5] [21] [20] [19] [17.5] [17] [-100] [35] [30] [29.5] [26.5] [22.5] [21] [20] [19] [17.5] [17] [-100] [35] [30] [29.5] [26.5] [22.5] [21] [20] [19] [17.5] [17] [-100] [35] [30] [29.5] [26.5] [22.5] [21] [20] [19] [17.5] [17] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] Boost Map [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [60] [60] [60] [60] [60] [60] [60] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [END][MAPGROUP][0A602][EOF] Map generated by U-LAME |
07-20-2006, 11:44 PM | #14 |
Member#: 63060
Thanks so much Aaron!
Need UTEC map for stg 2.5 | DemiSlayer | UTEC | 1 | 01-17-2007 11:58 PM |
Need UTEC map for slightly modded WRX... | m4r10 | Engine Management & Tuning | 0 | 12-19-2005 09:20 AM |
Help - need sti utec map for perrin 816 inj and large turbo | bottlediger | Engine Management & Tuning | 0 | 05-23-2005 10:31 AM |
need UTEC map for 20G and PE650cc inj. please!! | damn_4eat | Engine Management & Tuning | 4 | 06-09-2004 05:01 PM |
Need UTEC MAP for Stage 4 with 50 Shot NOS | AXA | Engine Management & Tuning | 7 | 10-31-2003 01:57 PM |
