05-17-2005, 02:14 PM | #1 |
Member#: 83536
How much added HP for removing the cat?
How much power gain am I looking at by removing the cat alltogether? I'm putting a 2001 2.5RS engine into a Porsche 914 (yes I know this isn't the conversion thread but its specific to the NA 2.5 engines)... Anyway, the car doesn't need to be smogged and I am definitely not putting in a cat.
The engine I bought came with an AEM cold air intake and no exhaust or headers. I've looked through the FAQ on headers and exhausts and it seems like most people are using the Borla setup. The MRT setup looks good, but I think I may try something custom with two mufflers. Any reccomendations here? -Tony
05-17-2005, 02:21 PM | #2 |
Member#: 75923
NESIC
Vehicle:2004 18g WRX Silver |
without the cat it's about a 12hp gain
05-17-2005, 02:28 PM | #3 |
Member#: 52202
Vehicle:2001 2.5RS |
When you say twon mufflers do you mean, one pipe split axle back, or 2 pipes from the engine? If the later is the case, Id talk to TWE about possibly making you a custom header. Borlas are the popular setup cause theyre cheap, and have a good quality build. If your looking for more power, I believe the equal length headers from TWE or COBB will net you more. Borlas help the engine rev faster, but the gains arent quite as great as most hope. And this is all coming from a very happy borla user.
05-17-2005, 02:41 PM | #4 |
Member#: 83536
Well, I was thinking about having two seperate headers with their own pipe going to a muffler for each side in the back. Thats how the 914s originally did it on their aircooled flat 4, but they merged the two in the back into a single muffler.
I'll see what TWE will do, equal length headers seem like a good idea. -Tony |
05-17-2005, 03:18 PM | #5 | |
Member#: 1594
Vehicle:1999 2.5 RS 2002 Legacy |
But since you're not even on a stock RS powertrain.. you could see some gains. I'd pick up a TWE header and then just bolt a turn down on it or run your piping where ever you need to from there. More than likely most off-the-shelf headers won't fit your application... just have one made, or just put a pipe going out from each exhaust port in the head. |
05-17-2005, 03:22 PM | #6 |
Member#: 815
Vehicle:2013 Boss 302 White 2008 S2000 CR ABP |
Hrm, you'd have to bolt the headers on reversed. I think this is doable, because I know you can do this with the intake manifold. Interesting... And yeah, TWE is your best bet. You will, however, have to confirm clearance with it on reversed...
05-17-2005, 05:19 PM | #7 |
Member#: 83536
Actually the exhaust will bolt on the same way it does in an Imprezza. The 914 is a mid-engine car, so the engine sits directly behind the seats in front of the transmission which sits between the rear wheels. I'm curious if there will be clearance issues though because of the low ground clearance. I'm going to be chopping the oil pan to get the engine to sit even lower.
I will have to turn the intake around and mount the alternator in another spot, but I will be removing the AC compressor and the power steering pump as well. -Tony |
05-17-2005, 05:47 PM | #8 |
Member#: 815
Got it. Yes, I would most certainly guarantee there will be ground clearance issues with the headers...
05-17-2005, 05:58 PM | #9 |
Member#: 23514
Vehicle:2006 WRX Wagon San Remo Red |
we should talk.
I'm putting a turbo EJ25 into a 1982 911SC. I bet we'll have a lot of the same issues. Where are you getting your subframe? |
05-17-2005, 06:03 PM | #10 |
Member#: 83536
I'm actually going to fabricate my own engine mounting bar. The 914 engine and 911 as well (if I'm not mistaken) mount at the front of the engine, whereas the EJ25 mounts at the output end. So for the 914 you either have to make some crazy looking subframe, or just make a large U-shaped bar that goes around the engine and mounts to the suspension console on either side of the engine bay. The 911 might be trickier, might be easier, I'm not sure.
I'll PM you with a coupel URLs since I'm such a newbie here I can't post them.. -Tony |
05-17-2005, 07:13 PM | #11 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
I am going to be doing the same swap into a '74 914 next winter. I am planning on a full custom exhaust, and actually using the turbo headers as a basis and going from there. The 225hp EJ251 that is currently in my RS should be the engine I am going to use. I am going to mate it to the 40mm Webers already on the 914. Should be a beast...
Kennedy Engineered Products makes mounts to weld in, as well as does the flywheel conversion. And this swap is going to be very different from putting one into a 911. Same concept, and a few of the same issues, but very different as well. As for the topic of this thread. 3-5hp max for going catless... |
05-17-2005, 11:18 PM | #12 |
Member#: 78118
Vehicle:2002 Corvette coupe 05 Legacy |
why would you go catless on n/a you need back pressure
05-17-2005, 11:35 PM | #13 | |
Member#: 82259
BAIC
Vehicle:1999 impreza 2.2L Brilliant Red <4EAT Club> |
05-18-2005, 11:08 AM | #14 | |
Member#: 832
RMIC
05-18-2005, 12:46 PM | #15 |
Member#: 847
South East
Vehicle:'18 Titan Crew Cab '16 Sienna XLE |
Cool project. Are there pics in the conversion forum?
05-18-2005, 12:59 PM | #16 | |
Member#: 78118
05-18-2005, 01:27 PM | #17 |
Member#: 83536
No pictures yet, but I'll start a thread over there soon.
-Tony |
05-18-2005, 06:28 PM | #18 |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
It's about getting the gasses out, wrapp the WHOLE exhaust system and have no cats and you'll see good gains.
05-18-2005, 07:59 PM | #19 |
Member#: 53992
BAIC
Vehicle:SOLD CGM 2005 2.5RS 35 PSI -- in my tires |
the stromung High Flow Cat and Catback gave an additional 12whp on the dyno...
05-19-2005, 11:14 AM | #20 | |
Member#: 832
RMIC
All of this is really mute for us 914 guys because all of the early cars were catless from the facotory, so we don't have an obligation to cat. The 1975 and '76 guys kind of got hosed because they got cats. Going catless on an RS not only has very little gains, but if you ever get popped for it, it is a federal offense with up to a $10k fine! |
05-20-2005, 08:18 PM | #21 |
Member#: 3687
Yes, you gotta go big/extreme if you want the most out of the exhaust system in an NA car. Then again you need a little back pressure, just a little so it can scavenge out.
"It's only a TEST pipe, officer!" |
05-21-2005, 12:15 AM | #22 |
Member#: 3102
NESIC
Vehicle:2018 Mazda CX-5 Storm Trooper White |
Go with either a Random Tech or Stromung High Flow cat, with my 2004 TS I felt a decent gain in power almost immediately after installing it.
How much to pay for dog/cat/cat/cat/house sitting? | jacobsen1_ | Off-Topic | 14 | 12-15-2006 09:12 AM |
how much more HP/TQ would I get from deleting the 3rd cat? | VajraTLR | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 01-12-2006 07:48 PM |
how much more hp does the vf22 put out over the vf23 | godfather2112 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 02-09-2005 07:17 AM |
How much crank HP do I have? | sorny | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 09-18-2002 05:32 PM |
