Brakes & Suspension Forum sponsored by The Tire Rack |
01-26-2014, 06:49 PM | #526 |
Member#: 223668
I Got A Swapped Gc8 .. 02 Wrx
I Got A 04 Sti Front Subframe With Steering Rack Wrx Sedan Control Arms What Swaybar And Endlinks Do I Use ? Depends On The Control Arms ?
01-27-2014, 10:58 AM | #527 |
Member#: 20952
Vehicle:BRZ & Datsun White & White |
I think it comes down to the control arms.
01-27-2014, 04:59 PM | #528 |
Member#: 238564
NWIC
Vehicle:09 TP StageII WRX SSM |
Anyone know if 2011 STi end links would fit a 09 wrx?
01-29-2014, 11:58 AM | #529 |
Member#: 380102
Vehicle:02 Impreza TS Green |
02 TS Wagon replacement parts
Hi All!
Does anyone know where you can pick up either a used (but unrotted) or decent replacement front subframe for an 02 TS wagon in the New England area? I bought a wagon on Saturday at an auction house and as I tried to drive it home yesterday - I realized WHY it was up for auction...* I've been able to track down control arms fairly easily enough (http://forums.nasioc.com/forums/show...33&postcount=2), the front subframe is more troublesome. The car has 256k on it and aside from the control arms and subframe, everything else seems pretty rust-free (brakes not-withstanding). It's going to be a daily driver for our 16y.o., so I don't need anything geared towards racing (although I wouldn't complain personally... ). Any help would be greatly appreciated! Thanks! *-funny, but sad sidenote. I discovered how the authorized dealerships handled the control arm recall (which this wagon had done back in 12/11). They hit the control arm with something and see if it dents. If it does, they replace it. If not - they spray protective paint on it and call it a day... Gotta love 'em... |
01-30-2014, 02:55 PM | #530 |
Member#: 141040
BAIC
Vehicle:07 2.5i wagon UGM |
Need to add something to the 02-07 impreza section:
If you use '04STi lateral links, the sedan axles are ever so slightly too long and may bind. This should apply to any car, sedan or wagon. |
02-02-2014, 07:50 AM | #531 |
Member#: 380102
Never mind - I found a decent one a Hebert's in Goffstown yesterday. There are a few spots to weld up, but otherwise- it's in perfect condition.
02-06-2014, 08:28 AM | #532 |
Member#: 221836
Vehicle:2006 STI SGM |
I have a 2000 OBS, will the Sti front end links fit?
i have v7 control arms if that makes a difference. |
03-15-2014, 12:57 PM | #533 |
Member#: 368756
NWIC
Vehicle:2005 STI OBP |
Will 2007 sti sway bars fit my 2005 2.5rs?
03-15-2014, 02:20 PM | #534 |
Member#: 75071
Vehicle:23 Solterra,ModelY Old: 05 08 11 WRX, 18 STI |
Will 08-14 GR front and rear sway bars fit on 11+ Impreza or Crosstrek?
03-16-2014, 12:36 PM | #535 |
Member#: 20952
03-16-2014, 12:37 PM | #536 |
Member#: 20952
03-18-2014, 02:22 PM | #537 |
Member#: 360374
Vehicle:2004 Subaru WRX WRB |
so iv been deciding on either tanabe df210 or gf210 for my 04 wrx.
i want to go low with df210 but i can only find them on ebay and they say "05-07", im guessing it would still fit mine, but i was reading that the spring rates are higher on those so it would actually be higher then putting 04 gf210s on. can someone clear this up for me, thanks. |
03-18-2014, 02:32 PM | #538 |
Member#: 20952
DF210 suck in my opinion. Way too low. I helped install a set and did not like them.
Springs meant for STI will probably be too firm for your OEM WRX shocks. - Andy |
03-24-2014, 01:20 PM | #539 |
Member#: 385478
Vehicle:1999 Sti Type R |
Just out of curiosity my buddy has 4 shocks n springs from his 97 impreza coupe, my suspension is finished on my 03 wagon and was wondering if till I found a setup like I want if his setup would fit on my wagon?...
Thanks |
03-25-2014, 02:05 AM | #540 |
Member#: 363767
Vehicle:2002 WRX SRP |
So to confirm, a strut assembly (strut, spring, top hat) from an 05 WRX sedan will fit without modification on an 02 WRX sedan?
03-25-2014, 02:11 AM | #541 |
Member#: 254851
BAIC
Vehicle:2002 WRX wagon 5mt PSM |
03-25-2014, 03:00 AM | #542 |
Member#: 363767
03-26-2014, 06:35 PM | #543 |
Member#: 166324
NESIC
Will GC struts bars fit on 02-07s? That was unconfirmed.
03-26-2014, 08:55 PM | #544 |
Member#: 385478
Hey guys I jut bought a 03 2.5ts and the suspension is finished my room mate has a set of stock 97 coupe suspension lying around I was wondering if I changed the top hats would the 97 suspension give me positive camber I've heard this?.... Otherwise would there be any issues this would only be temporary till I get a set of sti suspension
Thanks |
03-27-2014, 02:04 PM | #545 |
Member#: 20952
03-27-2014, 02:05 PM | #546 | |
Member#: 20952
03-27-2014, 05:23 PM | #547 |
Member#: 166324
NESIC
03-30-2014, 12:22 PM | #548 |
Member#: 385478
03-30-2014, 12:45 PM | #549 | |
Member#: 254851
BAIC
You can put them on and see how it sits. Then decide if you need saggy butt spacers (and what size) and install them if you do need them. The spacers can be installed without removing the rear struts. Disconnect the sway bar end links, remove the three top hat to body nuts. Stand on the hub and wrestle the spacer in there, then reassemble. |
03-30-2014, 02:20 PM | #550 | |
Member#: 385478
Another "Vote for my ___ " Thread. This time, my badass dog. | Sharkbait | Off-Topic | 56 | 10-14-2009 11:46 AM |
The parting out my car feeler thread | vision.dynamix | NESIC Private Classifieds | 51 | 04-25-2009 06:00 AM |
The official "Will this part fit my car?" thread | Butt Dyno | Brakes, Steering & Suspension | 20 | 07-12-2007 06:41 AM |
The Official "Will you print my car?" thread | MeanEditor | Grassroots Motorsports Magazine Forum | 0 | 02-11-2007 10:25 PM |
