02-23-2008, 09:59 AM | #1 |
Member#: 158033
Vehicle:2010 Fozzie X Prem Camellia Red Pearl |
HELP!!!! possible rod snap or floating valve.....
ok so during some fun last nite in the snow my car developed a hellacious loud clanking noise in the #1 cylinder, i got it home barely and it was sluggish as all....anyways when i got it home i pulled the spark plug and it was fouled to no end, completly black all around. Anyways it will not start but i have great electrical voltage and everything else, i did notice that there was a sign of oil leakage around the spark plug boot area at the valve cover, anywho heres a video my buddy shot right as the problem arouse..
http://www.youtube.com/watch?v=zND0mM8oZ34 please help!!!!! its urgent
02-23-2008, 10:15 AM | #2 |
Member#: 155358
Vehicle:2008 Forester Steel Silver |
Sound like you spun a rod bearing.
02-23-2008, 11:10 AM | #3 |
Member#: 160840
Vehicle:2007 impreza urban gray scoooped |
that def does not sound good im going with thrown rod sounds really bad take it to subaru asap just out of curiosity does it even idel at all ?
02-23-2008, 11:21 AM | #4 |
Member#: 158033
no it doesnt idle, it doesnt even start...
02-23-2008, 11:31 AM | #5 |
Member#: 158033
i dont know if this will help at all but i went and pulled off the intake manifold earlier and by looking down at the ports of the #1 cylinder, i can see that both valves are still connected but there is a build up of carbon and moist oil on the port.
02-23-2008, 11:39 AM | #6 |
Member#: 160840
take it to Subaru or some other mechanic you trust if it doesn't start then you might have snaped a rod and its fallen down into your oil pan thus its wedged and stopping things from moving a saw some similar sound in a forester forum a while back also is it the belts just wondering don't think so thought i would ask
02-23-2008, 11:43 AM | #7 |
Member#: 158033
no all the belts are tight and what not....the car sounds like when you have a dead battery and it only cranks about a 1/4 turn then stops.....and no its not a dead battery....
02-23-2008, 12:02 PM | #8 |
Member#: 117980
Vehicle:2005 sti wr blue |
wanna sell it pm me
02-23-2008, 12:04 PM | #9 |
Member#: 158033
ill let ya know...ive gotta get another motor to swap in there first, but if i do, youll be the first to know
Similar Threads | ||||
Race Short Blocks / Rod and Piston Combos / Valve Train Packages / Timing Kits | Built Industries | Engine/Power/Exhaust | 2 | 12-16-2009 01:00 PM |
rod knock or valve knock | Zerogravity | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 32 | 06-01-2009 12:28 PM |
sink or float? | yashuone | Off-Topic | 7 | 03-12-2009 04:51 PM |
FS-Cosworth Hi/Capacity Oil Pan Kit, Cos. Rod/Main Bearings, BC Valves/Spring/Ret | blackacres | Engine/Power/Exhaust | 22 | 02-14-2009 03:16 AM |
WTB: V7 EJ207 Rods+crank, or AM rods+05 revised crank | 5hif73r | Private 'Wanted' Classifieds | 0 | 12-28-2008 01:16 PM |
