Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2024
Old 12-25-2012, 04:30 PM   #351
SpicyPeaNut
Member#: 43310
1978 Brat
Originally Posted by pre0wned View Post
Does anyone know the dimensions of the T-piece that is supposed to come with the Defi boost gauge (and maybe where I could get one)? I purchased the gauge for the holidays and it is missing the T-piece.
I don't have the exact dimensions but don't buy just a regular T-connector. The part that the defi underhood unit plugs into has a smaller hole than the others.
SpicyPeaNut is offline   Reply With Quote
Old 12-26-2012, 11:37 PM   #352
Half Crazed
Member#: 321842
08 460/420w 08 STi
17 Stock WRB WRX
Thank you for the guide. Used a few steps to get mine in as well. Result below:
Half Crazed is offline   Reply With Quote
Old 12-26-2012, 11:42 PM   #353
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Can you post pics of how you T'ed off of the BPV? I'm looking for a cleaner solution than mine
JSchell1309 is offline   Reply With Quote
Old 12-27-2012, 09:25 AM   #354
scapone4
Member#: 299063
2011 WRX TP Stage 2
DGM Sedan
How much that set up run you? Thats exactly what im lookin at.
scapone4 is offline   Reply With Quote
Old 12-27-2012, 11:45 AM   #355
Half Crazed
Member#: 321842
08 460/420w 08 STi
17 Stock WRB WRX
I'll get pics soon (I need to cleanup my work as well )
Expect to pay around $440 for the SMY cluster and the two digital aem's
Old 12-29-2012, 04:19 PM   #356
Half Crazed
Member#: 321842
08 460/420w 08 STi
17 Stock WRB WRX
Hi All,
as promised, here's the wiring for my uego and boost gauge:
Close up of BPV T Connector
BPV T connector - made sure there's no kinks - did not need to cut OE BPV tube. Also loosly zip tied it to another hose
UEGO connector with adapter. I added wire tubing over the wires
From these pics it looks like my intercooler is shot .. must be angle of the camera
Old 12-30-2012, 05:15 PM   #357
Jellynuts
Member#: 305774
2007 STi
CGM
Originally Posted by ChesterWRX View Post
Just a quick question: Do you guys solder these connections, or just twist and cover?
Jellynuts is offline   Reply With Quote
Old 12-30-2012, 05:30 PM   #358
scx89
Member#: 269388
2011 Impreza WRX
obp
Crimp it with a connector
scx89 is offline   Reply With Quote
Old 12-30-2012, 05:40 PM   #359
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
i did both for the most part. i was too lazy to heat shrink... so i soldered and crimped for the boost gauge. eventually, i'll crack them back open and re-solder and heat shrink them.
ChesterWRX is offline   Reply With Quote
Old 12-30-2012, 06:17 PM   #360
MG rex
Member#: 341359
2013 WRX Hatch
I like the fuse tap idea. Trying to install defi control unit right now. If i follow what you did adding the fuse tap and just connect them to the fuse box, would it work? How about the ground?
Also i see on my Stock fuse box there is a fuse cap/ tap on some of the slots that i need. Is it fine to remove these or is it being used to power something? Electrical noob here.
MG rex is offline   Reply With Quote
Old 12-30-2012, 06:25 PM   #361
SpicyPeaNut
Member#: 43310
1978 Brat
You need to also have the ground wire attached to a bare metal piece somewhere under the dash. Otherwise bad things will happen. Make sure you hook up the ground wire.
Old 12-30-2012, 07:37 PM   #362
MG rex
Member#: 341359
2013 WRX Hatch
Constant 12v - Fuse # 3 - DOOR LOCK
Switched 12v - Fuse # 26 - IG2
Illumination/Dimmer - Fuse # 16 - ILLUMINATION
So the defi orange wire gets fuse #3. White #16 Red gets #26 and black is ground?
Old 12-30-2012, 09:28 PM   #363
Half Crazed
Member#: 321842
08 460/420w 08 STi
17 Stock WRB WRX
For gauges just needing power (no illum), I would suggest buying a fuse tap and tap it into the radio's tap... and use a 5amp fuse for the gauges (it's not recommended to go >10amp).
Afterwards, ground can be tapped to the metal plate on the fusebox. Works really well and powers on/off with ignition.
Old 12-31-2012, 01:29 PM   #364
JSchell1309
Member#: 321321
Tuxedo Black
Just picked up a Defi Oil Pressure gauge. One question, is there any advantage to choosing the galley plug under the alternator as opposed to the one under the TMIC? I think removing the TMIC and installing there would make for a cleaner look.
Old 12-31-2012, 01:42 PM   #365
b1aze
Member#: 284003
2010 Alpine 135i
The one under the alternator is the OEM oil pressure sender. The one under the Intercooler is just a blank. I did have quite a bit of trouble with the one under the Intercooler and ended up rounding the hex off, forcing me to use the one under the alternator, however there's plenty of wiring looms that run right to there to hide your gauge wiring. The alternator comes off easily also.
b1aze is offline   Reply With Quote
Old 12-31-2012, 01:48 PM   #366
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
this ^ -the consensus i read was the location under the alternator is more accurate... no need for the idiot light as you have a real time reading.
http://forums.nasioc.com/forums/show...2&postcount=53
http://forums.nasioc.com/forums/show...6&postcount=94
Old 01-02-2013, 06:14 PM   #367
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Has anybody had any problems pulling the oem dash out? Idk if im grabbing it wrong or what but the only part i can get a good grasp on is the inside liner of the dash. I read the smy instructions on there sight on how to pull it out and its not working. Does anybody have any tips this is driving me nuts, it should be such an easy task but it wont come out!!!!
ryblair is offline   Reply With Quote
Old 01-02-2013, 06:22 PM   #368
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
do you have a plastic trim removal tool or two? i used those.
otherwise, yank the **** out of it.
*assuming you don't want to damage your OEM cowl. i could sell you mine if you do.
ETA: they look like this. various flavors.... Pep Boys, Auto Zone, Cruchfield
http://www.griotsgarage.com/product/...FSpnOgodgRcAQA
Old 01-02-2013, 08:08 PM   #369
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
I got it! and yes i did have to yank the **** out of it! Aem uego wideband going in my empty one next week along with protune thanks for your suggestions!
Old 01-02-2013, 08:24 PM   #370
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
check the clips... read back earlier.. but the smy don't need them.
good job.
Old 01-02-2013, 10:03 PM   #371
Half Crazed
Member#: 321842
08 460/420w 08 STi
17 Stock WRB WRX
Yes, the dash is a bitch to get out... but you also have to man up and yank it pretty hard, if you know what I mean. Ha!
Old 01-02-2013, 10:08 PM   #372
GA scooby
Member#: 229518
2011 STi
Fantastic write up.
GA scooby is offline   Reply With Quote
Old 01-07-2013, 02:54 PM   #373
sinalm
Member#: 290725
2009 impreza wrx sti
Gray
Nice work and well write-up...
I'm trying to sort out my '09 STi the same way; but my 09 STi has the OEM Subaru STP Boost Gauge already installed and was wondering if I can use the OEM Subaru STP Boost Gauge wiring already in place and just switch out the gauge with Defi racer boost gauge. Thanks
sinalm is offline   Reply With Quote
Old 01-08-2013, 11:32 PM   #374
gmhracer
Member#: 267343
2006 STI
for people who have done this on a 02-07, where did you run your wires in through the firewall? what grommet did you use?
gmhracer is offline   Reply With Quote
Old 01-09-2013, 12:15 AM   #375
SpicyPeaNut
Member#: 43310
1978 Brat
Theres a small grommet just behind and above the pedals. I ran mine through there
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
