12-25-2012, 04:30 PM | #351 |
Member#: 43310
SCIC
Vehicle:1978 Brat Silver |
I don't have the exact dimensions but don't buy just a regular T-connector. The part that the defi underhood unit plugs into has a smaller hole than the others.
12-26-2012, 11:37 PM | #352 |
Member#: 321842
Vehicle:08 460/420w 08 STi 17 Stock WRB WRX |
Thank you for the guide. Used a few steps to get mine in as well. Result below:
12-26-2012, 11:42 PM | #353 |
Member#: 321321
Vehicle:2010 Ford SVT Raptor Tuxedo Black |
12-27-2012, 09:25 AM | #354 |
Member#: 299063
Vehicle:2011 WRX TP Stage 2 DGM Sedan |
12-27-2012, 11:45 AM | #355 | |
Member#: 321842
Expect to pay around $440 for the SMY cluster and the two digital aem's |
12-29-2012, 04:19 PM | #356 |
Member#: 321842
Hi All,
as promised, here's the wiring for my uego and boost gauge: Close up of BPV T Connector BPV T connector - made sure there's no kinks - did not need to cut OE BPV tube. Also loosly zip tied it to another hose UEGO connector with adapter. I added wire tubing over the wires From these pics it looks like my intercooler is shot .. must be angle of the camera |
12-30-2012, 05:15 PM | #357 | |
Member#: 305774
W. Canada
Vehicle:2007 STi CGM |
12-30-2012, 05:30 PM | #358 | |
Member#: 269388
SCIC
Vehicle:2011 Impreza WRX obp |
12-30-2012, 05:40 PM | #359 |
Member#: 328794
Vehicle:2012 WRX Premium Ice Silver Metal |
i did both for the most part. i was too lazy to heat shrink... so i soldered and crimped for the boost gauge. eventually, i'll crack them back open and re-solder and heat shrink them.
12-30-2012, 06:17 PM | #360 |
Member#: 341359
SCIC
Vehicle:2013 WRX Hatch DGM |
I like the fuse tap idea. Trying to install defi control unit right now. If i follow what you did adding the fuse tap and just connect them to the fuse box, would it work? How about the ground?
Also i see on my Stock fuse box there is a fuse cap/ tap on some of the slots that i need. Is it fine to remove these or is it being used to power something? Electrical noob here. Thanks |
12-30-2012, 06:25 PM | #361 | |
Member#: 43310
SCIC
12-30-2012, 07:37 PM | #362 |
Member#: 341359
SCIC
Constant 12v - Fuse # 3 - DOOR LOCK
Switched 12v - Fuse # 26 - IG2 Illumination/Dimmer - Fuse # 16 - ILLUMINATION So the defi orange wire gets fuse #3. White #16 Red gets #26 and black is ground? |
12-30-2012, 09:28 PM | #363 |
Member#: 321842
For gauges just needing power (no illum), I would suggest buying a fuse tap and tap it into the radio's tap... and use a 5amp fuse for the gauges (it's not recommended to go >10amp).
Afterwards, ground can be tapped to the metal plate on the fusebox. Works really well and powers on/off with ignition. |
12-31-2012, 01:29 PM | #364 |
Member#: 321321
Just picked up a Defi Oil Pressure gauge. One question, is there any advantage to choosing the galley plug under the alternator as opposed to the one under the TMIC? I think removing the TMIC and installing there would make for a cleaner look.
12-31-2012, 01:42 PM | #365 |
Member#: 284003
Vehicle:2010 Alpine 135i |
The one under the alternator is the OEM oil pressure sender. The one under the Intercooler is just a blank. I did have quite a bit of trouble with the one under the Intercooler and ended up rounding the hex off, forcing me to use the one under the alternator, however there's plenty of wiring looms that run right to there to hide your gauge wiring. The alternator comes off easily also.
12-31-2012, 01:48 PM | #366 | |
Member#: 328794
http://forums.nasioc.com/forums/show...2&postcount=53 http://forums.nasioc.com/forums/show...6&postcount=94 |
01-02-2013, 06:14 PM | #367 |
Member#: 309638
RMIC
Vehicle:2011 wrx premium dark metallic grey |
Has anybody had any problems pulling the oem dash out? Idk if im grabbing it wrong or what but the only part i can get a good grasp on is the inside liner of the dash. I read the smy instructions on there sight on how to pull it out and its not working. Does anybody have any tips this is driving me nuts, it should be such an easy task but it wont come out!!!!
01-02-2013, 06:22 PM | #368 | |
Member#: 328794
otherwise, yank the **** out of it. *assuming you don't want to damage your OEM cowl. i could sell you mine if you do. ETA: they look like this. various flavors.... Pep Boys, Auto Zone, Cruchfield http://www.griotsgarage.com/product/...FSpnOgodgRcAQA |
01-02-2013, 08:08 PM | #369 | |
Member#: 309638
RMIC
01-02-2013, 08:24 PM | #370 |
Member#: 328794
check the clips... read back earlier.. but the smy don't need them.
good job. |
01-02-2013, 10:03 PM | #371 |
Member#: 321842
Yes, the dash is a bitch to get out... but you also have to man up and yank it pretty hard, if you know what I mean. Ha!
01-02-2013, 10:08 PM | #372 |
Member#: 229518
South East
Vehicle:2011 STi DGM |
Fantastic write up.
01-07-2013, 02:54 PM | #373 |
Member#: 290725
Vehicle:2009 impreza wrx sti Gray |
Nice work and well write-up...
I'm trying to sort out my '09 STi the same way; but my 09 STi has the OEM Subaru STP Boost Gauge already installed and was wondering if I can use the OEM Subaru STP Boost Gauge wiring already in place and just switch out the gauge with Defi racer boost gauge. Thanks |
01-08-2013, 11:32 PM | #374 |
Member#: 267343
Vehicle:2006 STI White |
for people who have done this on a 02-07, where did you run your wires in through the firewall? what grommet did you use?
01-09-2013, 12:15 AM | #375 | |
Member#: 43310
SCIC
Similar Threads | ||||
NOAH is a tool....and I can proove it (Post here if you want points!) | madcatz | Mid West Subaru Owners Club Forum -- MWSOC | 14 | 05-02-2011 06:47 PM |
Tell us how Subiefest went when you get back tonight & pics if you have them | KB'izzle | Southern California Impreza Club Forum -- SCIC | 361 | 10-30-2009 07:57 PM |
ssr professors, post pics if you have them | streko | Member's Car Gallery | 2 | 07-22-2004 04:27 PM |
Anyone put WRX stock rims on an RS? Pics if you have them... | Samirr76 | Interior & Exterior Modification | 2 | 07-21-2001 03:15 AM |
