05-28-2009, 04:41 AM | #1 |
Member#: 189118
PRSIC
Vehicle:2003 S.Yellow WRX 2008 BMW 335i |
3M Headlight Restoration Kit
** I don't have any sort of affiliation with 3M or this product i just used it and it kicks ass!** I wanted to give some JDM Bugeye headlights I just bought a freshening up. Although they weren't very bad to start with they did have some pitting, a lot of light scratches, swirlmarks and dullness. I tried some hand products like some blue magic lens restorer that i had already, and some other polishes and waxes, and althought the dullness was reduced, the headlights weren't "show worthy". I went to the local auto zone and stumbled across the 3M kit, and after using it i can truly say it is amazing how well the lights look, not one single scratch or pit on them and they are glistening. I highly recommend this product to anyone that wants a straight up, all included kit that really gets the job done, without any type of hassle or mediocre feel afterwards. If you are very picky like me and only demand top notch, this is good stuff, it'll put a smile on your face when you see how ridiculously good your lights look. I have read all the posts about clearing headlights and i can honestly say that this kit is every good advice..... but in a box... and a price tag. And the good thing is that the kit brings so much stuff you can probably do it again to your foglights or wives car, if you do it right the first time, which is not very hard to do. So, FYI, if you need your headlights to rock... get this, and don't look any further. HERE'S a video i found after i already did it , it's helpfull
05-28-2009, 03:17 PM | #2 |
Member#: 193949
South East
Might have to check this out. My dad's Jetta lights are like after the 600 sanding
05-28-2009, 03:37 PM | #3 |
Member#: 4718
VIC
Vehicle:I gotz a Subaru again |
That was the best 5 minutes and 21 seconds of my day so far.
Awesome product. I need to pick that kit up. Today. |
05-28-2009, 04:39 PM | #4 |
Member#: 171611
BAIC
Vehicle:2014 FiST Blk |
This product is indeed a SOLUTION to a problem. It scuffs, polishes, and buffs.
Use it on my headlight lenses when I cleared them, they look almost as good as new, better than when I got them for sure. |
05-28-2009, 06:52 PM | #5 | |
Member#: 189118
PRSIC
It definitely is. I changed up the first part a little by misting the lens with water when i used the lower grit, but then i didn't change anything else. At the end i also added a few coats of nuba wax to seal the deal. |
05-28-2009, 09:56 PM | #6 |
Member#: 184472
Vehicle:04' WRX WRB |
I used this kit before to remove haze on my headlight. It worked perfectly, removing scratches in the process then buffed to a super clear see through finish.
This kit rox, I used it about ,well 2 years ago, it attached to any drill, I'm surprised this hasn't been brought up yet. |
05-29-2009, 12:35 AM | #7 |
Member#: 162932
NWIC
Vehicle:2020 Tacoma TRD Bro Super White |
Dammit, I ordered this thing and UPS "delivered" it.
Sigh, guess I'll go order another one. |
05-29-2009, 01:59 AM | #8 |
Member#: 196742
VIC
Vehicle:2000 Impreza 2.5rs Silver |
I need something to fix glass -_-
05-29-2009, 02:06 AM | #9 |
Member#: 99802
SCIC
Vehicle:2002 Blue WRX/16G 1975 Porsche 914 |
05-29-2009, 02:39 AM | #10 |
Member#: 189118
PRSIC
It seems the answer to the great question comes packaged by 3M....
05-29-2009, 03:14 AM | #11 |
Member#: 156347
Vehicle:1997 Milano EK 2004 Platinum Wrex |
amazing product, i suggest using it highly. Ive used this on a few cars and they came out perfect.
05-29-2009, 09:10 AM | #12 |
Member#: 193949
South East
05-31-2009, 06:34 AM | #13 |
Member#: 212757
Awesome, got this ordered, will post up my own results soon.
06-01-2009, 11:41 AM | #14 |
Member#: 129199
South East
Glass polishing is going to take a very long time. For the 3m kit is it the Best OTC option to me. You can also use a buffer and some compound. The key after you restore is to maintain. The hazing comes about because the uv coating has worn off the housing and is now trapping contaiminants. Keep the surface polished, sealed, and waxed and it wont be coming back for a while.
06-01-2009, 12:09 PM | #15 |
Member#: 193949
South East
Where did you find this. The two autozones near me don't have it. Looks like I'm going to every one of them in the triangle area.
06-01-2009, 12:14 PM | #16 |
Member#: 129199
South East
Amazon carries it for a good price if you cannot find it locally.
06-01-2009, 06:37 PM | #17 |
Member#: 95516
SCIC
Vehicle:2011 WRX DGM |
my friend tried this stuff and it came out really well. it was kinda ridiculous how the headlights before and after pics were so different. +1 for a good product.
06-01-2009, 07:57 PM | #18 |
Member#: 163578
Going to go look for this at auto stores nearby. I've tried the hard way wet sanding then rubbing compound then polish. This way seems a lot easier and more effective
06-08-2009, 08:41 PM | #19 |
Member#: 140643
South East
Vehicle:04' PSM Limited Wrx 371whp/344wtq E85 |
The 3M kit works AWESOME. the headlights on my 02 bugeye were horribly yellow, faded, scratched, and just downright nasty. It took bout 45 min to do both properly and the results were amazing. I'll let the pictures do the talking.
drivers side already done passenger side not done(obviously) just to compare Mask it off with two layers of tape Sand it till yellow is gone with 500 grit resand with 800 grit wet sand with 300 grit Polished finish product! All done with the 3M Headlight Restoration kit. I found it at autozone |
06-15-2009, 07:08 PM | #20 |
Member#: 214166
this is like magic..
06-18-2009, 06:03 PM | #21 |
Member#: 13815
SCIC
Vehicle:02 GCRally prepped 277TQ 281HP 19PSI |
Any suggestions for Morettes? It looks like I can do the same process but the lenses are much smaller than OE.
06-18-2009, 10:11 PM | #22 |
Member#: 202312
The product seems to work quite well! The down fall is that once you do all the sanding to remove the haziness there is no clear coat left on the headlights!!! So guess what........ The haze will return!!!
06-18-2009, 10:33 PM | #23 |
Member#: 214491
Vehicle:2005 Forester XT OBP |
^^ I was skeptical too, but it's been months and still no haze on mine. I thought I was going to have to buy new headlamps as mine had a thick coating of yellow haze, but now they're like new! Highly recommend the system.
06-18-2009, 11:57 PM | #24 |
Member#: 9090
Vehicle:09 Forester Gump 02WRX->04STi->09Gump |
Do plastic headlights really have a clearcoat?
06-19-2009, 01:32 AM | #25 |
Member#: 147065
if you sand with 500, then 800, then 300 isnt that going backwards making it more rough?
3M Headlight Restoration System | mmiller2002 | Car Part Reviews | 14 | 06-06-2013 07:50 PM |
3M Headlight Restore kit....it freaking works | CoolRex | Interior & Exterior Modification | 10 | 01-25-2010 08:16 PM |
3M Healight Restoration kit 39008 to the Blobeye rescue! | Mike 01Hawk | Car Care & Detailing | 15 | 09-13-2009 11:30 PM |
FS: 3M Headlight Restoration Kit | PCrowlz | NWIC Private Classifieds | 3 | 07-08-2009 06:28 PM |
Headlight restoration kits | Underground Graphics | Exterior/Styling | 0 | 03-15-2007 03:25 PM |
