01-25-2010, 01:56 PM | #1 |
Member#: 85813
South East
Vehicle:2002 E46 M3 2006 RC51 |
3M Headlight Restore kit....it freaking works
I've used Meguiars Plastix in the past and it worked ok but never to satisfaction.
So I found the 3M kit everyone talked about and bought it for $15. 3M Headlight restore kit. WORKS! Before: Mine were a LOT yellower as this pic is almost a year old. The Passenger side was a lot worse and almost had a green hue to it. Passenger light fixed...
01-25-2010, 02:05 PM | #2 |
Member#: 132365
Vehicle:'02 WRX EPL B5 S4 & B6 USP |
Hmm, Ive used the Meguires product myself and results were so-so. Definitely an improvement, but I might have to check this out. Looks great, and sweet retrofit.
01-25-2010, 02:07 PM | #3 |
Member#: 85813
South East
Yes this will freak you out at first but it sands out the crap. 4 steps of sanding/polishing.
All you need is a drill (used my Craftsman cordless), painters tape, and a spray bottle of water. 30 mins to 1 hour and you are done. So easy. |
01-25-2010, 03:06 PM | #4 |
Member#: 145069
W. Canada
Vehicle:Keep It Sleazy |
I f'd mine up.
I wanted to get every single gash out so i used like 500 first then i took so much time wet sanding the rest with like 1000, 1500, 2000, 2500. Then I bought some 3M cut and polished them but they are hazier then when I started . I've tried redoing them but they didn't come out much better. Anybody wanna offer me some guidance? CoolRex, what did you use on the end of your drill? what? |
01-25-2010, 03:10 PM | #5 |
Member#: 85813
South East
I used the thing the 3M kit came with. You must have used regular sandpaper.....the 3M kit comes with EVERYTHING minus the drill, tape, and water.
01-25-2010, 03:21 PM | #6 |
Member#: 145069
W. Canada
Ah I bought another name brand kit...It uses wet sandpaper but you have to sand by hand
So even though I used non-wet 500 grit can I still fix them? |
01-25-2010, 03:33 PM | #7 |
Member#: 85813
South East
01-25-2010, 04:16 PM | #8 |
Member#: 177880
South East
Vehicle:2002 Wrx Wagon 6sp Where can I get some cake |
01-25-2010, 04:25 PM | #9 |
Member#: 145069
W. Canada
Yeah I got a big bottle of 3M cut...So I just keep buffing and keep putting the cut/polish on until its crystal clear?
By buffer...I can use any ordinary orbital buffer right? |
01-25-2010, 07:16 PM | #10 |
Member#: 82147
SCIC
Vehicle:2005 WRX Sedan Aspen White |
Orbital buffer will work fine. I used my Meguiars G110 to polish out my headlights and it works great. Just make sure it uses small pads. I used 4" pads on mine. |
01-25-2010, 08:16 PM | #11 |
Member#: 138641
International
Vehicle:2002 STi w/'07 body Black |
Only thing is that you cannot create too much heat when you buff. If you do, the plastic will irrepairably haze from the inside. I believe there is some kind of anti reflectivity coating on the inside of the headlight, and it doesn't like too much heat.
3M Headlight Restoration Kit | guru_method | Car Care & Detailing | 118 | 12-17-2013 08:40 PM |
3M Headlight Restoration System | mmiller2002 | Car Part Reviews | 14 | 06-06-2013 07:50 PM |
3M Healight Restoration kit 39008 to the Blobeye rescue! | Mike 01Hawk | Car Care & Detailing | 15 | 09-13-2009 11:30 PM |
FS: 3M Headlight Restoration Kit | PCrowlz | NWIC Private Classifieds | 3 | 07-08-2009 06:28 PM |
Headlight restoration kits | Underground Graphics | Exterior/Styling | 0 | 03-15-2007 03:25 PM |
