04-22-2009, 03:50 PM | #301 |
Member#: 51480
International
Vehicle:1984 AM5, 1984 AF1, 1994 BC4, 2015 Outback |
All the same as USDM EJ25D except the IAC valve itself. With MAP you mean air flow meter? Also same as USDM EJ25D (and therefore all Legacy's made since 1989 until 1998).
04-22-2009, 04:37 PM | #302 |
Member#: 189923
W. Canada
Vehicle:1993 JDM WRX Black |
Thanks. The MAP sensor I was talking about is the sensor to the left of the Factory boost controller with the vacuum line attached? I assumed it was a MAP sensor since it looks like others I have seen. Is it a Atmospheric pressure sensor?
04-22-2009, 05:22 PM | #303 |
Member#: 50167
Vehicle:1996 Subaru STI RA White |
All of the intake manifold gaskets between EJ20G/K/H/R will be the same. I'll try to dig through my order forms to find mine.
04-23-2009, 08:49 AM | #304 | |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
Its also a map sensor, just remote mounted. Its used for the boost solenoid accessories, the ecu decides fueling on the maf. |
04-23-2009, 11:52 AM | #305 |
Member#: 189923
W. Canada
Thanks I am thinking of changing mine as its one of the only sensors I haven't changed.
04-28-2009, 10:14 PM | #306 |
Member#: 123362
Vehicle:'97 E36 M3 351W FTW |
Looking for Cam and Crank sensors for a Ver 2 EJ20G. Will the '02 USDM WRX 2.0 sensors work?
04-28-2009, 11:46 PM | #307 |
Member#: 51480
International
Probably. Does your engine have the connectors on the sensor itself or on the rear side of the engine?
04-29-2009, 12:25 AM | #308 |
Member#: 123362
Connectors on the sensors. The Link G4 is showing a trigger error while cranking and IIRC these sensors are not too expensive, easy change out and possibly solve my cranking issue.
04-29-2009, 07:25 AM | #309 |
Member#: 51480
International
Then USDM WRX crank and cam sensors should fit fine!
04-29-2009, 10:11 PM | #310 |
Member#: 113060
South East
Vehicle:2000 Built GC8 10's |
04-29-2009, 10:16 PM | #311 |
Member#: 123362
05-02-2009, 05:58 PM | #312 |
Member#: 106510
VIC
Vehicle:98 Widebody 3.4L Smooth Safety Blue |
WOOO! Found the part numbers for the V4 STI Type RA valve shims!
They use the same numbering sequence as the USDM DOHC shims, except change the 'AC' to an 'AD'. They range from 13218AD060 (1.88mm) to 13218AD930 (3.24mm) an increase of 10 in the part number = .02mm in shim size eg: 13218AD120 = 13218AD060 + 60 6 * .02mm = .12mm So it's a 2.00mm shim A few valuable resources that helped me track this number down: http://www.subaru-piter.ru/_pages/subaru/index.php - It's in Russian and English, top link is for European subarus, middle is for Japanese subarus, bottom is for US subarus http://opposedforces.com/ - In English |
05-02-2009, 07:41 PM | #313 |
Member#: 106510
VIC
Bloody hell, I finally find the part number and now Japan is on vacation all next week so I can't order them
05-05-2009, 02:13 PM | #314 |
Member#: 133923
NWIC
Vehicle:03 Legacy GT wagon I love goooollllllllddddd |
05-20-2009, 10:53 AM | #315 |
Member#: 207213
Any Idea what to use for a cometic gasket?
06-06-2009, 12:23 PM | #316 |
Member#: 90611
06-06-2009, 12:29 PM | #317 |
Member#: 90539
South East
06-06-2009, 02:26 PM | #318 |
Member#: 113060
South East
I need a 1995 STi ej20g piston rings part number please.
06-13-2009, 09:22 AM | #319 |
Member#: 197989
International
Vehicle:2002 Impreza WRX STI WR Blue |
Anyone know the part number of the EJ20 CDB oil squirters???
06-14-2009, 01:55 AM | #320 |
Member#: 51480
International
They only come in a CDB they are not sold separately (partnumber does not exist).
06-14-2009, 05:31 PM | #321 |
Member#: 90539
South East
I would think the oil galleries are in the block, you'd just need to buy some squirters with the correct nozzle opening and tap the block for them.
06-23-2009, 06:31 PM | #322 |
Member#: 189923
W. Canada
1-2 shift selector(shift fork) for tranny code TY752VB3AA
Please and thank you Subaru in NA will not help me find this part |
07-23-2009, 01:46 AM | #323 |
Member#: 64147
Vehicle:1993 STi RA V LTD Green |
Doubt you can help me with such vague info, but i need the part # for the STI-RA HVAC Blower Motor
08-05-2009, 11:34 AM | #324 |
Member#: 202261
JDM 1993-1994 WRX Upper Rad Hose Part numbers or cross-referance equivalent?
08-05-2009, 03:15 PM | #325 |
Member#: 51480
International
EJ20G & EJ20K Parts | awdeclipseguy | 1993 - 2001 Impreza Specific Parts | 17 | 06-15-2009 07:04 PM |
EJ20G Gasket Part Numbers... | scoobydorift | Subaru Conversions | 13 | 02-14-2005 10:43 PM |
Official XT Oil Filter Part Number thread | BrysImpreza | Forester Forum | 8 | 10-29-2003 11:23 PM |
NAPA Part numbers- can we have a nice thread with numbers listed? | Tex-WReX2 | Service & Maintenance | 5 | 12-15-2001 09:21 AM |
