09-08-2006, 12:30 PM | #1 |
Member#: 89228
Vehicle:02 WRX blinding white |
Towing small trailer?
I want to tow a small open flat trailer 4'x6' with my 02 WRX sedan but the manual states towing is not recomended, but you can tow with the wagon version.
Anyone think I'll be okay towing a very light load and why can you tow with the wagon and not the sedan??
09-08-2006, 12:36 PM | #2 |
Member#: 49330
Vehicle:03 WRX Wagon Sonic Yellow |
the biggest problem you are going to have is rigging up the wiring. You can get a hitch from etrailer.com. The wagons come with a harness adapter under the cargo area floor - the sedans do not (although I believe some folks have found "surprise" wiring in their sedans - not sure what you'll find - but the wires are all in the trunk to tap into).
Don't go over 200lbs tongue weight & you should be fine. Do a search for instructions on wiring. *disclaimer* I am not responsible for stupid things you may do while towing, etc, etc, etc... |
09-08-2006, 12:47 PM | #3 |
Member#: 89228
The trailer I want is so small it doesn't even have lights! I just want to be able to take junk to the landfill and do home projects.
09-08-2006, 12:59 PM | #4 |
Member#: 24069
Vehicle:2013 Legacy Blue |
You will have no issues pulling something of that size
09-08-2006, 01:29 PM | #5 |
Member#: 53517
Vehicle:STi Outback STi |
No issues, Get the hitch from etrailer.com as stated and save yourself some money. I have pulled a 5'x8' trailer on my RS and the STi without any issues at all. The trailer load when pulling it was my bike and luggage when going on vacation.
09-08-2006, 01:32 PM | #6 |
Member#: 39142
Vehicle:Memb er#: 39142 Join Date: Jun 2003 |
I used to tow my jet ski every weekend with my 2002 WRX Sedan; no issues. The reason why it isn't recommended w/the sedan vs. the wagon is because IIRC the wagon has a slightly stiffer rear suspension.
09-08-2006, 01:44 PM | #7 |
Member#: 118209
Vehicle:2015 WRX Limitec |
the wagon is also slightly heavier and slightly narrower, both help with a trailer. (probably not enough to make any difference whatsoever, but you get enough things put together that all have a 'slight' effect, it adds up)
if you do decide to install wiring, you need a converter. subaru's (most imports) have a different turn signal bulb, so you need a converter to go from a 4 wire system to 3 wire used on trailers. (uhaul has one with LED's for $20) |
09-08-2006, 05:17 PM | #8 |
Member#: 89228
Thanks eveyone for your input.
Towing a small trailer with a 2.0L WRX | HankWest | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 27 | 07-30-2009 12:35 AM |
FS: SC Tow Race Trailer - $575, Cost $1000+ to Build, STi Towed, w/ Lockbox, Gas Can | bfarm | Non-Subaru Stuff | 14 | 12-30-2008 11:05 PM |
Where can I buy a WRX wire harness for towing my trailer? | STR8OUT | Electrical & Lighting | 2 | 05-23-2003 07:36 PM |
Looking into WRX Wagon, need input on towing a trailer | Sanderskog | Newbies & FAQs | 12 | 03-08-2003 07:56 PM |
towing a small trailer... | justaspeedfreak | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 09-18-2001 11:26 AM |
