01-31-2005, 01:32 PM | #1 |
Member#: 60955
Vehicle:2003 wrx blue |
2000 rs...sti swap
how much would it cost to buy an sti engine w/ 6 speed transmission and ecu? and how much would the swap be, or could i do it w/ a lift, or is the transmission tough to do?
01-31-2005, 01:44 PM | #2 |
Member#: 7922
Vehicle:04 CTS-V b/b/b 99 GMC Highrider |
~$8k+ for the engine/harness/tranny/ecu I would assume. Labor could be another couple grand if you don't do it yourself.
You can do the swap with jackstands in your garage if you want. That is the way we've done it before (RS w/ WRX motor). |
01-31-2005, 01:52 PM | #3 |
Member#: 60955
does anyone got any good readings for this...the 2 door impreza 2.5 rs swapping to sti engine? and would it be best to get the transmission also?
01-31-2005, 02:18 PM | #4 |
Member#: 61845
RMIC
Vehicle:MY06 Legacy GT 5MT Regal Blue Pearl |
Check the Subaru Conversions Forum, they know what they're talking about. As far as the swap to a v7 or v8 STI, you'll have to change the rear LSD too, otherwise the rear axles or something won't be moving with the front, and you'll break everything.
The Conversions forum actually has the swap that Sport Compact Car did with a USDM WRX engine. My .02 - I'm saving for a JDM EJ205t. Can't argue with a 2.0 DOHC with 300hp, and a closed deck. It's all a matter of opinion, but the search button is a good thing. Oster |
01-31-2005, 02:29 PM | #5 | |
Member#: 23514
Vehicle:2006 WRX Wagon San Remo Red |
The ratios of your 2.5rs tranny would be in a word, hyper mated to the USDM STi engine. You would get some awesome 0-60 times though, but on the highway it would drive like absolute crap. I would expect that this setup would be not streetable, your rear diff whould have to change anyways, ans you're already spending a bucket of money, might as well make it work well too. So yes, you would need a new transmission. I would not recommend driving a stick 2.5 tranny on an engine that produces an extra 135 hp. |
01-31-2005, 02:36 PM | #6 |
Member#: 61845
RMIC
You'd need a new clutch anyway. The process of engagement between the 2000RS and WRX are opposites. One is a push engagement, and the other is a pull engagement. But, other than that, I think the tranny will actually hold the extra power, at least that's what I've heard. Most performance packages you can purchase actually come with the clutch and tranny though.
Oster |
01-31-2005, 02:39 PM | #7 | |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
It would also be torn to shreds if you tried to get any of those 0-60 times. |
01-31-2005, 02:47 PM | #8 |
Member#: 60955
i did not notice the conversion forum ill check it out...sorry
02-01-2005, 12:20 PM | #9 |
Member#: 6271
Vehicle:2001 2.5RSTi 2007 Legacy Spec B |
I have the usdm sti motor. I've had the motor for a lil over 2 months now.
If you respect your transmission it will take care of you. But yea, if you try to get those 0-60 times, they might not last long . Otherwise, the gearing is great for the highway, IMO. It's the same as before, same rpms/mph on 5th except when I want to pass, the car takes off faster on 5th than on 4th on the stock engine and i'm goin from 60-100 in no time! And yes, a new clutch would be needed. I'm using exedy clutch and flywheel. Remember, the RS tranny is shorter than the wrx but we do have an extra 1k rpms to play with with the wrx or sti motor. I don't know how high my 1st gear goes, I just hold on tight when i'm on that gear. 2nd gear can finally hit 60mph! 3rd goes up to 80+, 4th gets to 100 and 5th, i dunno... haven't gone that fast . If you want to replace your tranny to the usdm sti 6spd you will have to do a few things: replace your rear diff. If you replace the rear diff you'd need the axles, which is i believe longer than the RS axles, then you'd need the lateral links. So you'd be switching suspension parts around. Whie you're at it you should just get the brembos too. Another thing if you want DCCD To work, according to kevin (www.garagetuning.com) you'd need to replace the whole ABS system since the DCCD works with the sti ABS system... sooo, yea..it seems to be a lot of work and it will not be cheap. That's why I didn't go that route . www.garagetuning.com did my swap. Last edited by cRayZee; 02-01-2005 at 12:28 PM. |
FS : CT: 2000 Impreza RS STI swapped Caged/Flared/race ready | SubyImprezaRS-T | Private Vehicle 'For Sale' Classifieds | 58 | 06-22-2011 02:38 PM |
Feeler. FS/T: 2000 RS, WRX swapped | darksc00by | Private Vehicle 'For Sale' Classifieds | 6 | 09-04-2009 01:27 AM |
2000 Rs Sti $7400 | IdenityCrisis | MWSOC Private Classifieds | 0 | 11-12-2007 05:21 PM |
2.5 RS T or 2.5 RS Sti swap | V3rdug0 | Newbies & FAQs | 3 | 03-09-2006 02:44 PM |
2.5 rs sti swap | stiinside02 | Subaru Conversions | 48 | 10-30-2004 07:26 PM |
