05-15-2002, 11:05 PM | #1 |
Member#: 10627
Vehicle:2002 WRX Sedan Platinum Silver Metallic |
Fuel Pressure Question (can't search)
Sorry if this has been covered, but as you know we can't search for a while.
My plans are to wring as much as possible out of the stock turbo and fuel setup before upgrading to larger units - just to see what it can do. I have a fairly lengthy mod list, but it doesn't include any fuel mods (stock pump, injectors, rails). My list can be condensed into a full complement exhaust mods, significant intake mods (including ported turbo), and custom-mapped Unichip - along with many other bolt-on's. I have a fuel pressure gauge which I will be installing this weekend alond with some other double secret goodies. I have good information on what pressures to expect under what conditions, but my question centers around others' experience on a reasonably modified vehicle while using the stock turbo and fuel system. Has anyone with significant mods, but still running the stock turbo and fuel system, experienced fuel pressure problems from the stock pump? I am looking for experience from folks with a fuel pressure gauge or datalogging that could tell them if they have seen any limitations. Also, would I expect to overtax the stock injectors before the stock fuel pump or vice-versa? Thanks for any guidance.
05-16-2002, 09:37 AM | #2 |
Member#: 10627
Bump
Please... help... me... |
05-16-2002, 11:26 AM | #3 | |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Re: Fuel Pressure Question (can't search)
05-16-2002, 12:00 PM | #4 |
Member#: 9327
Jon - exactly - that's how it works on turbo cars. The stock regulator is 1:1, meaning it adds 1 lbs of fuel for every 1 lb of postitive manifold pressure it sees (postive manifold pressure=boost). Stock pressure at idle is betwwen 39-43 according to the specs (I haven't come accorss a car with under 43 yet, nor any over for that matter). So, at 15 psi of boost, fuel pressure should be around 58 psi.
As Jon said, if you find that at high rpms your fuel pressure trails off, then its time to upgrade the pump. Once the pump is upgraded, if at idle you then find fuel pressure to be higher than 43 psi, it's time to upgrade the regulator. Given the level of stuff you ahve planned, I think you'll be perfectly fine with the stock stuff as long as you keep to moderate bosot levels, and use the highest octane gas you can buy near you....I would also make a decent datalogger and EGT part of the mod list, just so you can routinely keep tabs on things adam Z-1 Performance www.z1auto.com |
05-17-2002, 05:47 PM | #5 |
Member#: 10627
Thanks, Jon & Adam.
I will take this to heart. With my OBDII datalogger and EGT gauge, A/F gauge and Fuel Pressure gauge with warning lights, I should be in good shape. |
fuel pressure question | QfactorRS | Normally Aspirated with bolt-on Forced Induction Powertrain | 7 | 05-26-2003 05:48 PM |
Fuel Pressure Question | Family Truckster | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 02-18-2003 04:58 PM |
Another Fuel Pressure Question! | adamsrs | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 06-03-2002 12:20 PM |
Fuel Pressure questions... | Delicious Tuning | Normally Aspirated with bolt-on Forced Induction Powertrain | 12 | 07-26-2001 04:41 AM |
turbo fuel pressure questions | bttune2.5rs | Normally Aspirated Powertrain | 5 | 03-01-2001 12:47 AM |
