06-25-2005, 09:01 AM | #1 |
Member#: 26607
Vehicle:2002 wrx wagon |
gonna order a walbro pump. Do I need the "kit" or just the pump itself for install?
06-25-2005, 09:06 AM | #2 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
just the pump.
gss342 take everything off your oem setup, transfer it to the new setup, replacing only the pump. hth ken |
06-25-2005, 09:14 AM | #3 |
Member#: 27021
Vehicle:2015 WRX |
You don't NEED anything in the kit, but it's nice to have some of the extras in case you lose/damage something (albeit unlikely). For instance, if you lose or damage the retaining clip that holds on the strainer on the stock pump, it's nice to have another sitting in the bag. Plus, the hose clamps that come with the kit are better as well.
06-25-2005, 09:27 AM | #4 |
Member#: 60324
Vehicle:1998 RS |
did anyone else not be able to fit that rubber gromet on on the bottom of the FP assembly once the walboro was in?
06-25-2005, 09:58 AM | #5 |
Member#: 27021
Vehicle:2015 WRX |
If you're reusing the stock rubber bottom, you must trim it to fit the Walbro. If you have the install kit, a new one is supplied that fits perfectly (another advantage of the install kit).
See Step 9 on this page for a picture of what to trim: http://www.wrxfanatics.com/index.php...l+pump+install |
06-25-2005, 10:02 AM | #6 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
At the "top" of the Walbro, just like stock, there is an output nipple for the fuel being pumped. It connects to another nipple via a rubber hose. I had to trim the non-Walbro nipple to get everything to fit properly.
"Ran into only one small problem during the fitment of the new pump. The pump outlet stem/nipple is about 3mm longer than the stock one. In the diagram below, the pump’s nipple is labeled ‘B’ and it meets up with a hard line that pokes out the top of the top plate (far left). I took a grinding stone to the end of ‘A’ (poked into the hose in the picture) and trimmed about 2mm off of it, then blasted the pipe and everything else with carb cleaner really well. It works. shrug" |
06-25-2005, 10:09 AM | #7 |
Member#: 60324
Vehicle:1998 RS |
I just left it off
06-25-2005, 06:42 PM | #8 |
Member#: 32792
NESIC
jeff are those your fuel lines in the background of that pic?
06-25-2005, 08:16 PM | #9 |
Member#: 8512
South East
Ken: They were. Sold em 2 months ago. Unnecessary.
do all wrx's suck in the rain or just mine | jclarkwrx | General Community | 93 | 06-18-2008 05:40 PM |
2007 STI Stage2 Protune Do I need Bigger Injectors or Fuel Pump? | Destroy | AccessPort | 4 | 03-17-2008 03:24 AM |
Brake fade in the rear or just the front? | chimchimm5 | Brakes, Steering & Suspension | 7 | 05-24-2007 02:48 PM |
i just ordered greddy turbo timer, do i need a wrx harness? | GregBolby | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 02-24-2004 04:09 PM |
installing my built engine in my garage in feb, need some help or just hang out | STEALTH-WRX | Southern California Impreza Club Forum -- SCIC | 30 | 01-30-2003 11:33 PM |
