10-07-2004, 10:44 PM | #1 |
Vendor Sales Rating: (8)
Member#: 60836
SCIC
Vehicle:2006 Mod Class STI TIMEATTACK!! |
Espelir JGT500 Exhaust (Pics Added)+ Active Super Down Springs + Active GT Springs
We just became the official Espelir dealer in the South Bay for springs and exhausts products. For those of you who aren't familiar with Espelir, Espelir is a Japanese based development and manufacturing company. They have enjoyed incredible success in the JGTC over the years, primarily in their works Supra. Espelir's exhaust and suspension components are of the highest quality available. All exhaust systems feature gorgeous machine and hand welds, excellent polishing, extra strong brackets, and full stainless construction. Espelir JGT500 Catback Exhaust for WRX '02+ - 80mm (3.1") Piping - N1 Style Muffler - Resonated Center Section - Removable Silencer - Best Fitment in the Industry - 3 Year Warranty List = $560 Introductory Special = $540 Shipped!! Call for special install special and pickup pricing! Here are pics on an '05 STI: Espelir Springs are available in two different styles. Active Super Down (Mild) '04+ WRX/STI - 35mm Lowering Front and 20mm lowering Rear (~1.3" F, .8" R) - 4.5kg front and 3.5kg rear spring rate - Stocklike Ride Quality List = $280 Introductory Special = $259.99 shipped! Call for local pickup and install special! Active GT (Aggressive) '04+ WRX/STI - 30mm lowering front, 20mm lowering rear (~1.1" F, .8" R) - 5.0kg front and 4.1kg rear rates - Aggressive Spring Rates for Improved handling and response List = $320 Introductory Special = $259.99 shipped! Call for local pickup and install special! For more information, see Espelir's site here Please call to order (310-618-0284). For directions, click here. We also have Eibach for those with pre-04's on blow out! Parts are immediately available for pickup OR same day shipping! Take advantage of our free installation special! Thanks, Logan www.harmanmotive.com
10-08-2004, 09:59 PM | #3 |
Member#: 60836
SCIC
Eric,
Thanks for your interest, please see revised pricing which includes shipping. Please call us to order, 310-618-0284 Thanks, Logan |
10-09-2004, 04:41 AM | #4 |
Member Sales Rating: (9)
Member#: 36234
SCIC
Vehicle:2005 WRX STi CGM |
Do you stock the Active GT springs? Rumors exist that these springs may have slight fitment issues which can cause noise/clunking etc. Have you installed any ?
Also, do you have Helix non-catted downpipes in stock? If so, please PM me with shipped total for springs and DP for So.Cal delivery. Thanks |
10-09-2004, 06:20 PM | #5 |
Member Sales Rating: (2)
Member#: 51537
Vehicle:2004 WRB WRX STI 62 Corvette/11 Cherokee L |
I have them, they do have slight fitment issues, but they handle killer. I think a couple of things remedy this, particularly how the end of the metal sits in the rear struts. I would get some rubber hose and slide it on the end so it fits better and there's less rubbing metal to metal. Maybe a little dab of grease wouldn't hurt. I have no noise from the front. Handling is awesome totally flat. Definitely firmer, but I also added a perrin sway bar on full stiff. Ride is OK.
10-09-2004, 08:11 PM | #6 |
Member#: 60836
SCIC
We've installed the GT springs on 2 STIs, and 04 and 05 and on an 04 WRX. We have had no issues when any of the vehicles.
As mnavarro stated, the handling is superb. Any fitment issues can be resolved directly with us as we are an official Espelir distributor. Regards, Dan Harman Motive, Inc. |
10-12-2004, 09:07 PM | #7 |
Member#: 25775
Harman Motive, Inc.
Active GT () '04+ WRX/STI
- 30mm lowering front, 20mm lowering rear (~1.1" F, .8" R) - 5.0kg front and 4.1kg rear rates - Aggressive Spring Rates for Improved handling and response So it would be 280lbs in the front? and like 230 in the rear? Please let me know also..are these the most Aggressive springs they make? Also on the Exhuast is it a straight threw design? can you please post or send pics of what it looks like either not on the car or the pipein from under the car on a lift or something like that? thanks! |
10-12-2004, 09:45 PM | #8 |
Member#: 60836
SCIC
WRXRACER: Regarding spring rates, they vary heavily between manufacturers. You can't convert it to pounds necessarily because it may be kg per cm or other metric measurement. They are best used to compare the two Espelir springs.
Regarding the exhaust, it's as straight through as they come (as you can see in the pictures). Unlike some of the other straight systems, it doesn't hang too low. Furthermore, the placement of the muffler flange far forward of the rear differential gives this system a ton of movement space = no rattles. Let me know if you have any other questions! Thanks, Logan |
10-12-2004, 10:01 PM | #9 |
Member#: 25775
Thanks for the quick reply
The Reason im asking about the springs is that im looking for stiffer springs than the ones out there..I see the springs rates are pretty stuff just wanted to make sure that they are actually 5kg/4.1 since I've never seen springs for the WRX like these..Looks good though was thinking about putting these on some kyb AGX's. Also would you happen to have sound clips and power gains from that exhaust? I have the HKS Carbon Fiber Ti before and it was wayy to low..this look better i hated the other one over speed bumps..Also i see that small center Resonator? I was looking for a straight center section like the Invidia Race exhaust they have..but i would like to pick up those springs/exhaust the drop is good enough i dont want it to be to low hehe |
10-13-2004, 02:20 PM | #10 |
Member#: 60836
SCIC
They are certainly good and stiff. KYB would be an excellent addition and we do have a set in stock at $130 per strut.
The catback alone on a WRX is good for ~10hp. With a downpipe and uppipe, the full system ads ~30whp. We have a ton of uppipes (DC Sports, PDE) and downpipes (Helix, PDE) in stock. Give us a call and we can put a nice package together for you. Regards, Dan Harman Motive, Inc. |
11-03-2004, 12:04 PM | #14 |
Member#: 49025
NESIC
Vehicle:2004 STi Platinum |
Just had the JGT500 put on my STi by these guys this weekend (along with my Defi Amber guages), and it sounds really, really nice. I would describe it as quiet when you need it to be, loud when you want it to be. =) Plus the Harman gang are a bunch of cool guys to hang out with during the install. I def plan on doing more business with them in the future (when I save up some more cash).
Espelir Active Super Down for 02 WRX sedan | Star555 | Private 'For Sale' Classifieds | 15 | 12-28-2005 04:26 PM |
Espelir JGT500 exhaust for sale maryland | bosozoku | Mid Atlantic Impreza Club -- MAIC | 7 | 08-09-2004 02:40 PM |
('93-'01) Pic Request: Espelir JGT500 exhaust on GC8 | SnakesTwo.Five | Impreza Forum | 0 | 07-04-2004 05:04 PM |
Got my Espelir JGT500 Exhaust this weekend - Review inside. | larryloominlarge | Vancouver Impreza Club Forum -- VIC | 16 | 06-29-2004 02:58 AM |
