10-08-2003, 10:22 PM | #1 |
Member#: 145
Anyone using the speedo cable on their WRX swap?
Just wondering if anyone is using the speedo cable instead of the VSS. I'm trying to see if the ECU is dependent on the VSS to receive inputs from to calculate various engine settings besides the speed...
Anyone using the older style tranny without VSS(vehicle speed sensor)?
10-08-2003, 10:39 PM | #2 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
The mechanical systems have the cable that goes to the gauge cluster. From there, it is converted into the needed voltage signal and outputted and passed to the ECU where it can do its thing with it.
A swap should work by simply tapping off the gauge cluster and retaining the mechanical speedo. I believe HomemadeWRX did this. I'll be going to the VSS setup for mine. -Jon |
Anyone using the Perrin Intake on 08 WRX ? | xaznxeclipsex | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 07-29-2008 12:47 AM |
Anyone painted the side skirts on their WRX? | nos | Interior & Exterior Modification | 19 | 05-16-2006 10:13 AM |
Is anyone using an Apexi ITC on their WRX? | kenshiro | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 17 | 05-01-2003 01:51 PM |
anyone has the Rota Attack on their WRX? | rayw1128 | Brakes, Steering & Suspension | 3 | 05-28-2002 01:32 PM |
anyone here got the CE light on their WRX? | jacklock | New England Impreza Club Forum -- NESIC | 1 | 05-07-2001 08:26 AM |
