10-23-2012, 08:47 AM | #1 |
Vendor Sales Rating: (7)
Member#: 111202
South East
Vehicle:2004 STi Blue/Gold |
04 STi 6sp, suspension and brake goodies and more! MUST READ!
Will be adding more. Will try to add more pictures when we have time, but all parts are as stated. Price DOES NOT INCLUDE SHIPPING!
Used Parts Inventory Subaru 04-07 STi intake manifold 04-07 STi TMIC Y-Pipe Garrett 30r rotated mount turbo Garrett 35r rotated mount turbo 04-07 STi Whiteline Anti lift kit Hyper Flow air/oil separator Greddy Air/Oil separator HKS racing BOV Synapse BOV Ultimate Racing 2 piece Pulley-Subaru STi/WRX 02-07 Cusco Front Adjustable Camber Plates NEW 04-07 Subaru STi, 02-07WRX Cusco Rear Adjustable Camber Plates New 04-07 Subaru STi Cusco Lateral link kit rear, front side, adjustable all WRX, STi GD Cusco Lateral link kit rear, side, adjustable, all WRX, STi GD Cusco Trailing Arms, pillow ball rod end Tein Coil Overs with EDFC-one broken shock body-04 Subaru STi Enduratech Monotube racing coilovers 2 way adjustable Subaru, 05-07 STi KW RACING Coilovers, Monotube, adjustable, external reservoir, Spring rates unknown Subaru STi 05-07 Ohlins Flag Series Coil Overs low mileage, 05-07 STi Endura Tech Coilovers, Twin Tube, 04 Subaru STi 2 TD04 WRX turbos, mileage unknown, no shaft play Blitz Boost Gauge 0-2 kpa Blitz EGT Gauge 40-140c Blitz Oil Pressure Gauge 0-100 hpa STi 6 speed transmission, bad synchro Stoptech 6 piston Big Brake Kit, installed, but never used. $2246.00 Brakes are still on car. will remove when sold. Pads have not ever been on anything. FRONT KIT, no rear components Stoptech 04-07 STi Front Big Brake Kit 355X32MM with Red ST60 Calipers Slotted Rotors Pads and SS Lines Advan AVS TS5 18x8/5x114 $1650 BBS Wheels, Stock, Subaru STi 05-07, Silver Other Stock used parts may also be available i.e. bovs, UPs, DPs Domestic/Other Ford Mustang 4.6L Zeus intake manifold-BRAND NEW Ford 4.6l K&N replacement Filter-Brand New NOS Progressive Nitrous Controller (open box, NEW) Autometer Pro Lite Shift Lite No Fear Racing Shoes, size 9, blue/silver/black never warn NEW Parts Subaru ACT Streetlite Flywheel, Subaru WRX, P#600480 50ft roll of Blue exhaust wrap one inch wide Project Mu Race Pads, Brembo Brakes, Front, Subaru STi Project Mu Race Pads, Brembo Brakes, Rear, Subaru STi Go Fast Bits Manual Boost Controller Cusco Front Adjustable Camber Plates NEW 04-07 Subaru STi, 02-07WRX Cusco Rear Adjustable Camber Plates New 04-07 Subaru STi Domestic/Other 1994-2004 Ford Mustang Rear Lower Control Arm relocation kit Ford 302-351 starter Ford Mustang Energy Suspension 1044 Transmission Mount Auto Command Remote Start Kit Ford Air Breather Cap Ford Wire Looms SCT X1000 p#3000, needs to be unlocked ARP wheel Stud Kit P#300-775 STi 6sp, brake kit, suspension and more! -Ohlins Flag Series CoilOvers 05-07 STi, been installed on car but never used. $3500 coilovers are still on car. Will remove and prep when they are sold. -Stoptech 6 piston Big Brake Kit, installed, but never used. $2246.00 Brakes are still on car. will remove when sold. Pads have not ever been on anything. FRONT KIT, no rear components Stoptech 04-07 STi Front Big Brake Kit 355X32MM with Red ST60 Calipers Slotted Rotors Pads and SS Lines -04 STi 6 speed transmission, 3rd or 4th gear synchro going (dont remember) 70k miles-make reasonable offer Garrett 35r - 800 bucks, less then 1000 miles on it.
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B]Tuning*Suspension*Engine Builds*Quality Performance Parts* Race Track Prep*Enthusiast Educational Classes[/B] [COLOR="Red"][B]For Draco Performance Merchandise - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/COLOR] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Draco Performance; 06-03-2013 at 02:06 PM. |
10-30-2012, 05:10 PM | #3 |
Member#: 111202
South East
fixed Garrett 30r - 750 bucks, less then 1000 miles -NEW Cusco Rear Adjustable Camber Plates *Cusco Pillowball Rear GDA **will not fit OEM style big spring setup** 2001-2007 Impreza-All submodels-$175.00 IN STOCK -NEW Cusco Front Adjustable Camber plates *Upper Pillowball Mount; Does not fit OEM Style Big Spring 2001-2007 Subaru Impreza-all submodels $175.00 in Stock -USED Cusco Lateral Links, Both Rear front adjustable, and rear side adjustable.approximately 20,000 maintained miles on them, 1 track use, all rest DD miles. $750.00 for set. Application of each -Cusco Lateral link Kit-Rear Rear Side adj. Pillowball Bushing GD (04-05 STi only) -Rear Lateral Links; Front Side; w/ Adj Pillowball Ends 2002-2007 SUBARU IMPREZA WRX;WRX LIMITED;WRX STI;WRX STI LIMITED;WRX TR Will clean and prep prior to shipping. -:USED Cusco Trailing arms, approximately 20,000 maintained miles on them, 1 track use, all rest DD miles. $350.00 1993-2000 SUBARU IMPREZA For Non-US GC8 Impreza WRX Model 2002-2007 SUBARU IMPREZA WRX;WRX LIMITED;WRX STI;WRX STI LIMITED;WRX TR H4 2.0;2.5 -We have lots of random stock parts if someone is putting something back to stock Downpipes, Blow off valves, UpPipes, boost control solonoids
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B]Tuning*Suspension*Engine Builds*Quality Performance Parts* Race Track Prep*Enthusiast Educational Classes[/B] [COLOR="Red"][B]For Draco Performance Merchandise - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/COLOR] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Draco Performance; 11-16-2012 at 07:47 PM. |
11-01-2012, 11:19 AM | #4 |
Member#: 111202
South East
FS:USED in Auto X'ing, Endura Tech Monotube Coilovers, 05-07 STi $650.00
2 TD04 Turbos, no shaft play, mileage and vehicle they came off is unknown $100.00 each Whiteline anti lift kit, minimal miles motorsports. 02-07 WRX/STi Catch Cans $75ea
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B]Tuning*Suspension*Engine Builds*Quality Performance Parts* Race Track Prep*Enthusiast Educational Classes[/B] [COLOR="Red"][B]For Draco Performance Merchandise - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/COLOR] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Draco Performance; 05-30-2013 at 08:34 AM. |
11-16-2012, 08:01 PM | #5 |
Member#: 111202
South East
added more stuff!
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B]Tuning*Suspension*Engine Builds*Quality Performance Parts* Race Track Prep*Enthusiast Educational Classes[/B] [COLOR="Red"][B]For Draco Performance Merchandise - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/COLOR] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
11-16-2012, 08:02 PM | #6 |
Member#: 111202
South East
place saver for more stuff
__________________
02-18-2013, 04:28 PM | #7 |
Member#: 111202
South East
Have a great Monday!
__________________
03-19-2013, 11:31 AM | #8 |
Member#: 111202
South East
it's track time, we have some goodies that you need!
__________________
04-05-2013, 05:13 PM | #9 |
Member#: 111202
South East
Bump for good stuff.
__________________
04-19-2013, 02:56 PM | #10 |
Member#: 111202
South East
price drop on endura-techs
__________________
05-30-2013, 08:30 AM | #14 |
Member#: 111202
South East
__________________
05-30-2013, 08:31 AM | #15 |
Member#: 111202
South East
__________________
05-30-2013, 08:32 AM | #16 |
Member#: 111202
South East
__________________
05-30-2013, 08:33 AM | #17 |
Member#: 111202
South East
Have a great day!
__________________
06-03-2013, 09:20 AM | #18 |
Member#: 111202
South East
if there is something used in particular you are looking for and don't see it in this list for 2004-2007 Subaru STi, then shoot me a pm. We have alot of stuff. Have a great day.
__________________
06-06-2013, 10:27 AM | #20 |
Member#: 111202
South East
__________________
07-08-2013, 04:14 PM | #22 |
Member#: 111202
South East
__________________
07-10-2013, 07:24 PM | #23 |
Member#: 111202
South East
Subaru · 04-07 STi intake manifold · 04-07 STi TMIC Y-Pipe · Garrett 30r rotated mount turbo · Garrett 35r rotated mount turbo · 04-07 STi Whiteline Anti lift kit · Hyper Flow air/oil separator · Greddy Air/Oil separator · HKS racing BOV · Synapse BOV · Ultimate Racing 2 piece Pulley-Subaru STi/WRX 02-07 · Cusco Front Adjustable Camber Plates - NEW 04-07 Subaru STi, 02-07WRX · Cusco Rear Adjustable Camber Plates - New 04-07 Subaru STi · Cusco Lateral link kit - rear, front side, adjustable all WRX, STi GD · Cusco Lateral link kit - rear, side, adjustable, all WRX, STi GD · Cusco Trailing Arms, pillow ball rod end · Tein Coil Overs with EDFC-one broken shock body-04 Subaru STi · Enduratech Monotube racing coilovers 2 way adjustable - Subaru, 05-07 STi · KW RACING Coilovers, Monotube, adjustable, external reservoir, Spring rates unknown - Subaru STi 05-07 · Ohlins Flag Series Coil Overs - low mileage, 05-07 STi · Endura Tech Coilovers, Twin Tube, 04 Subaru STi · 2 TD04 WRX turbos, mileage unknown, no shaft play · Blitz Boost Gauge - 0-2 kpa · Blitz EGT Gauge - 40-140c · Blitz Oil Pressure Gauge 0-100 hpa · STi 6 speed transmission, bad synchro · Stoptech 6 piston Big Brake Kit, in stalled, but never used. $2246.00 Brakes are still on car. will remove when sold. Pads have not ever been on anything. FRONT KIT, no rear components Stoptech 04-07 STi Front Big Brake Kit 355X32MM with Red ST60 Calipers Slotted Rotors Pads and SS Lines · Advan AVS TS5 18x8/5x114 $1650 · BBS Wheels, Stock, Subaru STi 05-07, Silver · Other Stock used parts may also be available i.e. bov's, UP's, DP's Domestic/Other · Ford Mustang 4.6L "Zeus" intake manifold-BRAND NEW · Ford 4.6l K&N replacement Filter-Brand New · NOS Progressive Nitrous Controller (open box, NEW) · Autometer Pro Lite Shift Lite · No Fear Racing Shoes, size 9, blue/silver/black - never warn NEW Parts Subaru · ACT Streetlite Flywheel, Subaru WRX, P#600480 · 50ft roll of Blue exhaust wrap one inch wide · Project Mu Race Pads, Brembo Brakes, Front, Subaru STi · Project Mu Race Pads, Brembo Brakes, Rear, Subaru STi · Go Fast Bits Manual Boost Controller · Cusco Front Adjustable Camber Plates - NEW 04-07 Subaru STi, 02-07WRX · Cusco Rear Adjustable Camber Plates - New 04-07 Subaru STi · Domestic/Other · 1994-2004 Ford Mustang Rear Lower Control Arm relocation kit · Ford 302-351 starter · Ford Mustang Energy Suspension 1044 Transmission Mount · Auto Command Remote Start Kit · Ford Air Breather Cap · Ford Wire Looms · SCT X1000 p#3000, needs to be unlocked · ARP wheel Stud Kit P#300-775
__________________
08-01-2013, 11:05 AM | #24 |
Member#: 111202
South East
still available
__________________
