03-09-2011, 02:33 PM | #426 |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
Not hardly. Probably more like a C4 Vette with 187,000 miles. In Michigan.
03-09-2011, 02:38 PM | #427 |
Member#: 147637
International
Vehicle:HJ's Ask Hobbs. He knows. |
I've been in a C5 with that many miles, and it was still fun with an idiot behind the wheel... so I think you're okay.
03-11-2011, 09:19 AM | #428 |
Member#: 197077
SWIC
Vehicle:2001 Honda S2000 Berlina Blaque |
03-11-2011, 10:41 AM | #429 |
Member#: 120273
SWIC
I got my 1 piece driveshaft yesterday. IT seems to fit perfectly. Seems lighter than both a stock 5MT DS and a 6MT DS, but I don't have any specific figures until I get it on a scale tonight at Mark's house. That is the final part of the drivetrain I was waiting on. A rough list of what needs to be buttoned up for the car to be driveable (not complete, but driveable):
Drivetrain: -Install 1 piece DS -Fill Tranny -Reconnect NPS and RPS -Install clutch hydraulic system Brakes: -Install master cylinder brace -Bleed system Engine: -Finish evap system (just need to get the canister installed) -Reinstall intercooler setup -Oil Change -Misc Vacuum lines Suspension: -Set ride height -Alignment -Tighten all pivots/bolts -Make spacers and install new endlinks -Have Erik teach me how to tuck tires Body: -Install rear bumper -Install front clip -Install STi aero parts under car -Install fender liners Looks like I'll be busy this weekend. |
03-11-2011, 11:35 AM | #430 |
Member#: 14732
SWIC
get busy then
03-11-2011, 11:49 AM | #431 |
Member#: 214964
SWIC
Vehicle:2011 WRX Premium Spark Silver |
Sounds like someine needs to do more wrenching and less typing
03-11-2011, 12:13 PM | #432 |
Member#: 120273
SWIC
03-11-2011, 04:38 PM | #433 |
Member#: 23123
SWIC
Vehicle:15 WRX 6MT 07 Legacy SpecB |
if u need a hand, call me...
03-11-2011, 04:42 PM | #434 | |
Member#: 107352
SWIC
Vehicle:Not Respectable |
03-11-2011, 04:44 PM | #435 |
Member#: 197077
SWIC
Win!!!
03-11-2011, 05:07 PM | #436 |
Member#: 120273
SWIC
Thanks dude. It's mostly one man jobs from here on out. Dude, I totally forgot the trans jack last night! We can meet up this weekend if you still need it.
I feel cheated on. Quit surfing NASIOC and process my last parts order. |
03-14-2011, 03:50 AM | #437 |
Member#: 211224
RMIC
Vehicle:2005 Saabaru Who knows |
bump i need updates son!
03-14-2011, 03:57 AM | #438 |
Member#: 256810
Starting to think my car will be done before yours now.
Did kermit get trapped under the car or something? |
03-14-2011, 04:07 AM | #439 |
Member#: 168774
SWIC
03-14-2011, 04:12 AM | #440 |
Member#: 147637
International
I thought the car drove off a cliff last weekend...?
03-14-2011, 11:44 AM | #441 |
Member#: 120273
SWIC
Well, good news. I started the car this weekend. It took a long time to get hr started, but she finally did. Since the intercooler wasn't installed, I ran her with the MAF unplugged.
Additionally, I completed everything but the following: Endlinks - Need to cut spacers. Intercooler - Need to install and do some additional cutting. Front Fenders Bumper Headlights Alignment Then she'll be road worthy at the very least. Anyway, here are a few scattered pictures of things I worked on this weekend: Clutch system installed. I bled it on the bench and then installed it. I added the rubber hose to protect the aluminum AC line from the braided line. Al lines tend to rub through quickly. There shouldn't be much movement between the two, but just in case. It's just a piece of fuel injection hose split down the side and zip-tied into place. |
03-14-2011, 12:07 PM | #442 |
Member#: 120273
SWIC
I also had a one piece driveshaft made to replace the two piece STi one. I've read many good things about single piece shafts and the responsiveness they add to the car, but I didn't have the money for an aluminum one ($500) or a carbon fiber one ($1200) so I opted for a steel unit made locally. The advantage to the steel unit is that while it weighs marginally more than the aluminum or carbon units, it is significantly cheaper than the other two, fits much better than the aluminum one, and has a smaller diameter than the aluminum one.
In a drivetrain system, static weight is far less important than rotational inertia. In this case, the steel shaft is 3 lbs heavier than the aluminum one, but it is 2.75" in diameter vs the 3" diameter for the aluminum unit. While I have yet to do the math, I would expect the steel unit to have the same or less rotational inertia than the aluminum solution because it has a smaller diameter and thinner wall thickness. 3lbs static weight difference is really nothing in the scheme of things, especially considering how heavy the stock shafts are. Mark and I did some unofficial measurements and compared it with other driveshaft solutions on the market. This is what we found. Stock 5MT DS: ~21.5lbs Stock 6MT DS: ~24lbs (my application) PST Carbon 6MT DS: 14.4lbs DSS Al 6MT DS: 14lbs Steel 1 piece 6MT DS: ~17lbs Additionally, unlike the stock DS, this new unit has fully serviceable/rebuildable u-joints. Here are some photos: Top to bottom: OEM 6MT, OEM 5MT, 1-piece Steel 6MT Serviceable/replaceable u-joints: Mark also had a good idea to use the stock center carrier bearing from an OEM shaft as a make-shift driveshaft loop just in case a joint broke. The tail joint of the DS is pretty well encased by a factory part, but nothing but the exhaust would really hold the front up. Since I have a ton of spare 5MT DS's sitting around, I cut one up just to try. I took this part off (cut the rubber and metal out): And was left with this: Painted up: Everything installed on the car: This is the only area where I am slightly concerned with fitment (between the DS and the t-member). There is about 0.25" between the two and very little should flex in this area, especially with the upgraded differential and outrigger bushings. Overall, the fitment was great and it was sized perfectly. It should be balanced to 7000 rpm which is a around 140mph with my final drive. The shop seemed pretty confident it would do better than that to. I guess we'll see soon. I'll be testing this to see if it has any strange vibrations or the like before I have anymore made for others. |
03-14-2011, 12:16 PM | #443 |
Member#: 120273
SWIC
Bad news for the weekend was that at some point while the steering linkage was removed, I or someone else spun the steering wheel and broke the clock spring. The clock spring is the part that allows you to turn the steering wheel, but still use the controls mounted on the wheel. This is an expensive part and breaking it resulted in no horn, cruise control, or airbag. Not cool.
Either way, since I had nothing to lose seeing as how it was already busted, I decided to open it up and fix it. I ended up finding a right up on it by a guy with a similar issue. It took a while to figure out how it worked and how to repair it, but in the end I was able to re-solder all the connections and trim the small inch long segment of torn ribbon cable (paper thin!). With the repair completed, the unit tested good and I reinstalled it. Everything appears to be operational now! The small connections at the bottom to the wire harness was where the ribbons were torn off and where I had to re-solder. Here was the small segment of broken ribbon I had to remove from the end: |
03-14-2011, 12:21 PM | #444 |
Member#: 120273
SWIC
Some suspension pictures while the lighting was decent (no endlinks installed):
03-14-2011, 12:28 PM | #445 |
Member#: 120273
SWIC
As I mentioned earlier, with the STi suspension arms installed in the narrow wagon body, the wheels are VERY close to the edge of the fender. I will need to roll the fenders just a bit to fit the wheels I think. Erik has kindly volunteered to help with this as he's a local expert on it.
I tried both the Wagon and the sedan fenders, and to be honest, I'm feeling the wagon fenders much more than the sedan. So much so that I'll probably run the wagon front end for the time being and probably look for fender flares like WagonWheel's car. Also, note the wild amount of caster (wheel pushed forward in the front wheel well). It might be too much, but I'm not sure; many people tell me there is no such thing as too much caster on these cars. This is a result of using the 04-06 STi arms AND doing the bracket flip caster mod. Sedan fender: |
03-14-2011, 12:55 PM | #446 |
Member#: 14732
SWIC
nice work ken
03-14-2011, 01:26 PM | #447 |
Member#: 63605
SWIC
Vehicle:04 Wrx Wgn TimeAtk 10 Golf TDI, 08 Stang GT |
looking really good! Can't wait to see it finished. I'm not a fan of sedan fenders either, i think rolling the stock ones is better. I have the sti arms as well, but I didn't do the bracket flip I don't think. My caster was fine.
03-14-2011, 01:52 PM | #448 |
Member#: 211224
RMIC
the caster mod feels really nice at least it did on my wrx! and that thing is looking good man! great wrok!
03-14-2011, 01:52 PM | #449 |
Member#: 146496
SWIC
Vehicle:02 WRX Wagon 2.1L Built not bought. #0003 |
Car looks great Ken! Looks like you're on the home stretch!
03-14-2011, 02:00 PM | #450 | |
Member#: 71615
SWIC
Vehicle:2002 Bugeye PSM |
Your wagon is looking more and more amazing with each update! I am impressed with your style choices and quality of work and look forward to seeing your finished product. Cheers -Ryan |
Similar Threads | ||||
I am master of Procrastination! | subySerb | Off-Topic | 13 | 04-29-2008 03:29 AM |
By Build Thread: 1991 Legacy Turbo with EJ20G Swap | livestrong14 | Member's Car Gallery | 69 | 03-14-2007 08:59 PM |
Some nice things can be borne out of procrastination [56k beware] | sherifx | Off-Topic | 6 | 01-21-2007 09:18 PM |
Tale of Two Cities: City of God and City of Lost Children | Snoopy | Off-Topic | 7 | 11-07-2005 11:03 AM |
Just sit right back and you'll hear a tale, A tale of a fateful nap... | collegedropout | Off-Topic | 4 | 08-01-2004 09:36 AM |
