11-17-2012, 04:57 AM | #1 |
Member#: 315748
Tri-State
Vehicle:2017 wrx sti ice silver metallic |
how long you guy warm your car for?
is it detremental to let your car warm to the pont where the coolant is a few notches above the "c", or will a minute suffice and let it ride on idle and keep it under 2k rpm in 1-3? does not warming your car harm your engne?
11-17-2012, 05:19 AM | #2 |
Member#: 280392
Vehicle:2003 Jetta TDI Wagon 6 Speed |
It gets warmer faster if you floor it.
11-17-2012, 05:20 AM | #3 |
Member#: 292699
MAIC
Vehicle:2011 WRX Sedan DGM Stg1+ SF |
I usually let it sit in the garage until the temp needle starts to move and then baby it out of my neighborhood. By the time I get to the road shes almost to full temp
11-17-2012, 05:35 AM | #4 |
Member#: 105104
VIC
Vehicle:1979 BRAT / 01 RSTI 99 2.5TS (DEAD) |
~15 seconds to let the oil circulate around then casual light foot until it starts to warm up.
But you do not need to sit there idling for minutes for it to warm up. Waste of gas... This is also climate specific but in general you can go pretty well right after startup. |
11-17-2012, 06:04 AM | #5 |
Member#: 134527
International
Vehicle:05 STi9 type UK Urban Grey |
I usually start mine and let it idle till I open my gates, then drive it on light throttle till oil tem is up to 70 degrees centegrade
11-17-2012, 06:18 AM | #6 |
Member#: 334322
Vehicle:2013 Impreza Sport Ice Silvef |
Warm Up
I've got a 2013 Impreza 2.0 with the CVT transmission. When started COLD it takes 3-1/2 minutes before the idle comes down to 1000 rpm or so. When first started, the engine revs at 1800 for about 2 minutes...then drops to 1500 rpm for a minute...then slowly levels off to 1000 rpm or so. This is my first CVT transmission and I've been wondering if it is OK to just let it run for 30 seconds or so and then drop it into gear...anyone doing that or ?
Currently I let it run for the 3 minutes before I put it into gear... Any suggestions on what others are doing would be appreciated...thanks! |
11-17-2012, 07:12 AM | #7 |
Member#: 94283
NESIC
Vehicle:'19 Ascent |
I let mine warm up for an hour with the heat cranked so when I get in it feels I'm in Hawaii. It's like a mini vacation.
11-17-2012, 07:26 AM | #8 |
Member#: 270910
South East
Vehicle:2006 WRX Tr WRB |
^^You crack me up, man! You should get one of those tropical drinks from Sonic to top the experience off.
11-17-2012, 07:38 AM | #9 |
Member#: 92003
SCIC
Vehicle:04 bicycle! |
as long as it takes me to put my seat belt on, and adjust the radio
drive lightly until the needle makes 1/4 up the way |
11-17-2012, 08:02 AM | #10 |
Member#: 141672
I never let my car warm up. I park my car in an attached garage and don't deal with scraping windows.
Regardless if it sits out at work and it's 8F, I start and immediately drive gently until it's warmed up. Letting your car sit around and warm up causes fuel dilution which isn't an ideal lubricant. Look at UOA's with high fuel dilution and the higher wear numbers that often go with it. I've owned my WRX since new, long been stage 2 and has 118k miles of trouble free service. |
11-17-2012, 08:09 AM | #11 |
Member#: 167739
Tri-State
Vehicle:15 Forester NA dat gas mileage |
11-17-2012, 08:16 AM | #12 |
Member#: 81247
South East
Vehicle:2005 PSM WRX TD04L-19T Stage 2ish |
11-17-2012, 08:17 AM | #13 |
Member#: 273906
NESIC
Vehicle:2005 Lexus Grandpa |
11-17-2012, 08:24 AM | #14 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
11-17-2012, 08:31 AM | #15 |
Member#: 329543
South East
Vehicle:2003 WRX Wagon Sonic Yellow |
So from the few legit posts I've read about this topic, does it make a difference if it's say: 20*F outside? I will start my car >10 minutes before I leave in the mornings so it's warm inside and the temp gauge is at normal level. I live right off a busy highway, sometimes I have to "gun" it to pull off and get up to 55-60mph speedlimit. There are also mountains and hills on my way to work and it can be hard to stay out of boost unless I want to be in say 3rd going 40+mph..
11-17-2012, 09:26 AM | #16 | ||
Member#: 167739
Tri-State
jak pls |
11-17-2012, 09:36 AM | #17 |
Member#: 329344
South East
Vehicle:2008 Forester XT DGM |
2-3 minutes
11-17-2012, 09:38 AM | #18 |
Member#: 167739
Tri-State
To answer the question OP, you don't need to. The only thing you should be worried about is high RPM/high throttle positions until it's at running coolant temperature for around 10 minutes(Oil usually reaches operating temperature around that time)
I've had my car for 90k miles(150k total milage on car) and I rarely ever warm it up. |
11-17-2012, 09:56 AM | #19 |
Member#: 163058
MWSOC
Vehicle:'20 WRX '16 BRZ Limited |
I only warm it up when it's 20F or lower outside. If I had to warm up every time I left work, that would just be dumb.
11-17-2012, 10:26 AM | #20 |
Member#: 329344
South East
If my drive to work everyday was longer than 10 minutes I probably wouldnt let it run as long. Just trying to get the oil to operating temps for short trips.
11-17-2012, 10:33 AM | #21 |
Member#: 325031
Vehicle:2014 Forester XT |
11-17-2012, 10:40 AM | #22 |
Member#: 226864
Start it, wait about 5 seconds, then start driving. I try to keep it around 2.5k until it's hot. No higher than 3k. Once she's fully warmed up I open it up. Maybe I'll go to 4k as it's warming up but not 100%
Oil circulation is much more important than thermal expansion and other things that happen when the motor is hot. Oil circulation takes almost no time at all, it happens right when the car is started. |
11-17-2012, 10:53 AM | #23 |
Medium Frank
Moderator Member#: 140114
MAIC
Vehicle:2020 Subaru Outback |
11-17-2012, 10:58 AM | #24 |
Member#: 307359
South East
Vehicle:'05 STi Stage II OBP |
I let my Sti idle for a minute, then drive for the first five minutes staying under 3K rpms and out of boost. Or at least until the temp reaches the first notch.
11-17-2012, 11:01 AM | #25 |
Member#: 248202
MWSOC
Vehicle:2013 WRX Sedan SWP |
Run the piss out of it when it's cold.
Less heat soak |
