11-08-2006, 08:45 PM | #1 |
Member#: 131471
help with 04 legacy
Hi I have a 04 legacy when first started the throttle is hard until it runs for a few minutes what can cause this and also what is a good repair manual to buy for this car
11-08-2006, 08:55 PM | #2 |
Member#: 115154
Vehicle:2005 Outback XT White on grey |
throttle cable either needs grease or replacing. Probably the greasing as it may be just that the old grease needs a little bit of hot air to get it to be smooth again.
Good manual...Hayes or Chiltons is the usual pick; some people have the factory Subaru manuals on CD or downloaded online. I have the latter, it's pretty helpful. |
11-08-2006, 08:58 PM | #3 |
Member#: 52324
Vehicle:2011 WRX LTD (FS) 1990 T30 miata |
I agree. before starting, stomp on the pedal a few times. does it loosen? I'd lube it and check for corrosion.
11-08-2006, 09:06 PM | #4 |
Member#: 131471
ok I"ll put some grease inside the cable and I have to wait until tomorrow to let the car cool back down I tryed the stomping on the peddle trick and it just goes back to being stuck one other question are the engines known for head gasket leaks
11-08-2006, 10:21 PM | #5 |
Member#: 22928
Vehicle:2015 Legacy Limited Lapis Blue |
Not from 2000+, so you're safe.
11-08-2006, 10:25 PM | #6 |
Member#: 115154
Phase II motors, external headgasket, but subaru makes all coolant changes be done to include their coolant conditioner (its $2 for one bottle, enough for the entire system, you can get it at the dealer if you're DIY'er or having your own mech do it for you). So far it seems to be working :crosses fingers:
11-08-2006, 10:27 PM | #7 |
Member#: 94945
Vehicle:2015 Dodge Charger AWD |
11-08-2006, 11:49 PM | #8 |
Member#: 22928
11-09-2006, 06:57 AM | #9 |
Member#: 52324
I'd check to see if the cable is bound up anywhere. Also, how is the action where it connects to the TB? There are springs there that could probably use a squirt of WD-40.
11-09-2006, 03:53 PM | #10 |
Member#: 131471
at the throttle body its hard to move by hand thats were I was thinking the problem might be at
Similar Threads | ||||
Help with my Legacy | LegacyGirl05 | NWIC Private Classifieds | 8 | 05-21-2010 02:18 PM |
Help with our Legacy | vjz | Legacy Forum | 3 | 03-27-2010 03:46 PM |
Help with '07 Legacy sway bar install | yamahito | Brakes, Steering & Suspension | 1 | 04-26-2007 08:59 AM |
Help with my Legacy Catalytic Converter | skierdood1984 | Normally Aspirated Powertrain | 2 | 12-15-2003 12:28 AM |
need help with my legacy | dojoromeo | Legacy Forum | 17 | 03-06-2003 02:25 PM |
