10-23-2014, 03:36 PM | #4576 |
Member#: 400510
South East
Vehicle:2015 WRX Limited CVT World Rally Blue |
by 'dope' you mean crap, right?
Good engineering... terrible application
10-23-2014, 07:30 PM | #4577 |
Member#: 378600
TXIC
Vehicle:09 Subaru WRX STi Black |
^agreed^ I really like little custom things like that and the engineering it takes to get it done but IMO that shift knob just doesn't fit. But hey props on going for it!
Sent from my iPhone using NASIOC |
10-23-2014, 08:22 PM | #4578 |
Member#: 244036
Custom GD gauge pods - fiber glass works with the factory clock pod and dash plastic trim.
I tried to make everything to look as factory as possible |
10-23-2014, 08:57 PM | #4579 |
Member#: 362505
I like it all but the different gauge styles and different colors and AP cause the wire, I would put it on the left side and hide it, other then that I really like all the clean work
10-24-2014, 06:40 PM | #4580 |
Member#: 366022
NWIC
Vehicle:2015 STI White |
10-24-2014, 06:47 PM | #4581 |
Member#: 395644
Vehicle:2004 Impreza WRX Obsidian Black Pearl |
10-24-2014, 07:12 PM | #4582 |
Member#: 237136
Vehicle:2003 WRX 6MT JBP |
10-24-2014, 09:46 PM | #4583 |
Member#: 404735
lots of great ideas!
10-25-2014, 04:59 PM | #4584 |
Member#: 139392
Vehicle:2015 WRX LE Silver |
10-25-2014, 05:48 PM | #4585 |
Member#: 167288
Vehicle:07 STI_Fpred_RaceC STI_04 Winter Beater |
10-27-2014, 10:40 PM | #4586 |
Member#: 313728
South East
Vehicle:2007 WRX STI Limited Charcole gray |
I made custom rear flares then welded, bondo and re painted and they came out great. I would post pics but it says I am not allowed
10-27-2014, 10:44 PM | #4587 |
Member#: 287794
South East
Vehicle:2015 Wrx DGM |
10-28-2014, 12:47 AM | #4588 |
Member#: 403038
Vehicle:06 STI Built SGM |
What year coolant tank is that for the evo?
10-28-2014, 12:54 AM | #4589 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
I love how people are still ripping on that knob when even the guy who made it doesn't like it.
10-28-2014, 01:24 AM | #4590 |
Member#: 362505
this thread was better in the beginning
10-28-2014, 08:47 PM | #4591 |
Member#: 79643
NESIC
Vehicle:2021 STI TE Terminal black pearl |
"Custom" diffuser. It's haggard. I'll probably make another one. #DYJH |
10-28-2014, 10:53 PM | #4592 |
Member#: 242630
SCIC
Vehicle:.. Flu shot technician. |
I like the car. Too bad you wont be able to shift.....
10-28-2014, 11:21 PM | #4593 |
Member#: 79643
NESIC
As long as I keep my wrist straight, it should shift fine.....
#DYJH |
10-28-2014, 11:44 PM | #4594 |
Member#: 195711
Vehicle:PART OUT. PM ME 02-07 Goodies |
I have wanted to contribute to this thread for a long time, finally have a worthwhile addition.
I made two things, one is a custom bracket for my FPR on the back of my short runner intake manifold, this isn't a worth while addition by itself, however I am proud of what is below. Secondly is my relocated power steering reservoir. I have had my car tore apart for 13-14 months now, just getting talented enough with tig welder to start manipulating metal effectively. Considerations for this part: Reason : Stock one sucks, trying to tidy up the engine bay where possible. Hood Clearance : Good Drainage : Nope - I will be using a squeeze ball to empty this sucker out. Vented Cap : Thought about it, will address if it becomes a problem. My plan is to get fluid hot, vent and seal the cap, then it will be at worst atmospheric pressure, ever so slight vacuum when cold. Volume : 2-3 CI more than the stock "hot" max. Stock volume at that point was 27.5-28CI, so this is a 10% safety margin which I'm okay with Mounting Have a tab on top as shown, working to land another tab below the throttle body, those two points and two hoses worth of tension will suffice. Flow : all holes were drilled out to a minimum of 1/2" ( -8 AN ). Some of the holes ended up being a bit bigger than that. The low pressure return will be a 6AN and is going to be mounted on the back side of the tank Project Duration Tough to tell since when parts would be cooling down I'd be doing other things, but 5-7 hours. Comments are welcome Last edited by Layvon; 10-29-2014 at 05:57 AM. |
10-30-2014, 01:56 PM | #4595 | |
Member#: 399739
Vehicle:2005 Subaru WRX San Remo Red |
What did you use in the center console to mount the plugs? Was it just some plastic you had laying around that just happened to fit or is it a little more custom than that? Sent from my iPhone using NASIOC |
12-20-2014, 09:00 PM | #4596 |
Member#: 15783
NWIC
Vehicle:Many 09 Fozzy 06 WRX 00 Cummins Ram, 03 WRX |
Hi, I thought I would share my custom Escort radar detector hardwire.
I started by disassembling the 12v power plug. The mute button and both the power and alert LEDs were integrated into the plug. I used a rotary bit on my Dremel and gutted part a stock Subaru dash plug. With some careful trimming and planning it will go together. I epoxied the card to the block off plate, taking care not to glue the mute button or cover the LED holes. Not much to explain. Just go slow and remove enough for the circuit board and layout the LED holes so the stock charger plug sticker will match. I found power and ran my radar detector cord into the seam of the dash and the defroster plastic. |
12-23-2014, 08:45 AM | #4597 |
Member#: 233501
Vehicle:07AD 337/335SAXWAGON 99 outback sport |
Looks good, I did the exact same thing a few years ago, but that microchip failed on me a few weeks ago.
So I'm directly re wiring it to an on off switch this time. Brought to you in part by: My Thumbs |
01-16-2015, 09:26 PM | #4598 |
Member#: 383262
Vehicle:2004 WRX Wagon Silver |
Bump. Cmon people, keep them coming!
Sent from my SM-G900V using NASIOC mobile app |
01-22-2015, 12:56 PM | #4599 |
Member#: 261307
South East
Vehicle:04 wrx wagon WRB |
01-22-2015, 03:32 PM | #4600 |
Member#: 252324
Vehicle:04 STi JBP |
Very nice...Did you take the mesh out?
Show us your unique modifications | lancewr1 | Interior & Exterior Modification | 7214 | 01-10-2012 12:09 PM |
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods | bluerex79 | Member's Car Gallery | 6 | 05-02-2011 09:02 PM |
Calling all Graphix......Show Us Your Stuff... | grnlantern1 | Member's Car Gallery | 37 | 07-16-2002 01:25 AM |
show us your wrx gauge installs. | lstepnio | Member's Car Gallery | 51 | 05-22-2002 03:43 AM |
Show us your T's (OZ Super T's that is) | Who flung dung | General Forum Archive | 11 | 02-12-2001 07:46 PM |
