04-11-2012, 11:42 AM | #76 | |
Member#: 289606
Vehicle:06 WRX white |
I
04-11-2012, 11:42 AM | #77 |
Member#: 256810
NWIC
It would not be hard to punch a hole. I have seen it before. Just pour some oil in the hole. Then thread the stud in. The oil with push the bottom right out like lindsay lohan.
Just depends on which hole you use. Some have some meat behind them. I'm glad that MAP has stepped up to correct this issue. I have bought parts from them in the past and will in the future. |
04-11-2012, 11:43 AM | #78 |
Member#: 256810
NWIC
04-17-2012, 01:33 PM | #79 |
Member#: 202736
SCIC
Vehicle:2002 WRX- 6spd - MBP 1992 Civic VX 40MPG |
so i contacted MAP. they said they would give a refund if I wanted. Is it really that big of a problem missing those threads???
they said to just finger tight them |
04-17-2012, 03:07 PM | #80 | |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
04-17-2012, 03:16 PM | #81 |
Member#: 295975
Yep, but it has worked without issue time and time again.
04-17-2012, 03:27 PM | #82 |
Member#: 232430
SCIC
Vehicle:555 XTi 1 AW & 1 CGM |
Wow good find! Glad Ive always used ARP products! Hard not to trust them since they have been around for so damn long!
04-24-2012, 10:52 PM | #83 |
Member#: 76729
Vehicle:2004 WRB WRX 2.7L S400SX3, PPG, AEM, 701whp |
Interesting read...
04-24-2012, 10:53 PM | #84 |
Member#: 76729
Has anyone actually did the math on minimum thread engagement? or are we just guessing at how much thread is actually required? I'm particularly interested in that .200" of thread that is missing from the previous bolt version that is still floating around out there.
04-24-2012, 11:17 PM | #85 |
Member#: 206851
Vehicle:56 Belair Pro Street |
bump for fuji's expertise!
04-25-2012, 01:00 AM | #86 | |
Member#: 127745
NWIC
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
Bottom line: If the manufacturer incuded 20 threads in a design, then 20 threads need to be engaged for application of the full intended clamping force. |
04-25-2012, 02:01 AM | #87 | |
Member#: 71875
minimum thread engagement is a function of fastener diameter: http://www.engineersedge.com/thread_...engagement.htm It is actually not much and the reason the threads are so long is to keep them from ripping out of the block and not failure of the stud. So you would need to do the math on internal aluminum studs as well as the stud itself (which I don't feel like doing right now because of this bottle of wine). I would think if you have the studs that bottom out you could just thread them into the block until they stop, go back a touch, and be fine. |
04-25-2012, 11:20 AM | #88 |
Member#: 18960
South East
Vehicle:02 WRX MBP It lives! ; ) |
I once snapped a BBC ARP head stud in the bottom of the blind-hole bore. Panicked, I asked a PhD Physicist I worked with the best method to extract it.
He smiled and said "Back it out with a long, sharp awl". I went home and did just that. There is a reason stud installation does not require torque on installation. IMO, the "dog point" is just marketing hype...in this case, gone wrong. |
04-25-2012, 12:18 PM | #89 | |
Member#: 76729
04-30-2012, 03:49 PM | #90 |
Member#: 191432
Just wanted to add my experience so its documented.
I had these installed for the break in of a fresh block and re-worked heads. While tuning the car started pushing coolant and needed new headgaskets. Upon disassembly some of the stud nuts came off with much less effort than others. The studs themselves were the same way, some were finger tight, and a few needed a bit more convincing. The places where the headgaskets were failing happened to be directly under the more easily removed head studs. |
06-16-2012, 06:58 PM | #91 |
Member#: 188705
Vehicle:GD Widebody STI Lexus Pearl White |
Any news from Maperformance? Is the new design coming out?
02-20-2013, 12:32 PM | #92 |
Member#: 191941
Vehicle:2007 STI SWP |
Digging this up from the depths but did anyone else notice that in the first picture it appears that the ARP stud is smaller in diameter (once you get above the threads) than the MAP studs?
02-20-2013, 01:25 PM | #93 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
The studs have been revised.
02-20-2013, 01:40 PM | #94 |
Member#: 191941
02-20-2013, 01:41 PM | #95 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
^would you use them in a build?
02-20-2013, 01:45 PM | #96 |
Member#: 108089
02-20-2013, 01:47 PM | #97 |
Member#: 191941
05-24-2013, 05:51 PM | #98 |
Member#: 299687
RMIC
Just purchased new MAP headstuds today for my Track car. I have been hearing a lot of good stuff!
05-24-2013, 09:09 PM | #99 |
Member#: 256615
Are the MAP headstuds mfg'd by K1? Last shop I worked at was investigating producing there own head studs and had several mfg's studs sent out for strength testing/hardness/etc.. and analysis done. Oem head studs broke at various points and psi. The K1 headstuds broke at a higher psi but surprisingly a few broke below the psi of the oem head studs. Arp headstuds broke at the same point everytime and at the same psi. They were the most consistent in the tests and strongest. Somewhat shocking when we got the tests back and saw the findings of the K1 studs.
05-24-2013, 09:44 PM | #100 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
Not K1... A1. (as indicated with the picture in the first post, which they also show on their site)
Arp 2000 head studs | builtsubie | Built Motor Discussion | 2 | 07-06-2011 03:20 PM |
ej20 manley h beam rods, arp ej20 head studs, ej20 built heads | hybridpatient95 | Engine/Power/Exhaust | 98 | 01-30-2010 10:26 PM |
Arp sti head studs | RichWRX | Engine/Power/Exhaust | 3 | 01-28-2010 05:35 PM |
ARP DOHC Head Studs! | Wedge | Engine/Power/Exhaust | 2 | 11-26-2009 03:02 PM |
FS: (NY) ARP DOHC Head stud kit (>20k miles) | mtcs | Engine/Power/Exhaust | 2 | 04-15-2009 06:47 PM |
