06-30-2004, 10:22 AM | #1 |
Member#: 2604
Vehicle:1999 2.5RSt RBP |
what are good ej22t compression test #s?
what is ballpark for an ej22t with SOHC 02RS heads?
how does 125+- 5ish all around sound. to me it is good that they are all very similar. Should I take this as compression is good = engine is most likely good? I have heard this combo runs around 8.3-4 ish to 1 I was expecting higher numbers actually more like 135 or 140. please respond asap. Thanks Todd
06-30-2004, 12:11 PM | #2 |
Member#: 9861
RMIC
Vehicle:1999 2.35 RS-T w/NOS Hybrid Rally Blue Pearl |
This combo is more like 7.6-7.8:1 and those numbers are decent.
06-30-2004, 02:58 PM | #3 |
Member#: 2604
k thanks!
06-30-2004, 04:29 PM | #4 |
Member#: 25516
Was the motor warmed up? Numbers can change big time when the motor is cooled off.
07-01-2004, 01:17 AM | #5 |
Member#: 2604
i am not sure
I will find out what are ballpark #'s for cooled of and warmed up? I have a feeling those are warmed up numbers. Todd |
07-01-2004, 01:51 AM | #6 |
Member#: 41300
Vehicle:2000 New York MTA |
Errrrrrrr
The car was sitting for over 2 hours while I waited Definately cooled unless driving 20 feet is warming up |
07-01-2004, 07:49 PM | #7 |
Member#: 2604
ok good
07-01-2004, 10:09 PM | #8 |
Member#: 37196
most important thing is that each cyl is w/in 10 from the others. If you are losing compression it will most likely be in only one, maybe 2 cylinders. Chances of all 4 losing compression and being about the same is not likely.
That being said, those who dont have compression testers, who want a backyard check, do this: Disable ignition by unplugging coil pack. Crank engine for about 5 seconds straight (car wont start). Listen for what we call, even cranking. There is not points where the engine cranks faster or slower. it should be even. A trained ear can hear minor compression loss. Major compression loss is obvious. -Jake |
07-01-2004, 10:27 PM | #9 | |
Member#: 25516
07-01-2004, 11:09 PM | #10 | |
Member#: 7321
Vehicle:.... 122 IggPoints Work... ahhh... so tired. |
Yup, being close to each other matters more then the numbers themself.
http://forums.nasioc.com/forums/show...ght=ej22T+ej22 |
Similar Threads | ||||
What is the standard compression test values on a 2.5ltr with forged pistons | tino | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 15 | 11-25-2005 02:16 AM |
what is good cylinder compression on the sti? | CBRDSpeedfactory | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 9 | 04-14-2005 07:50 PM |
ej22t compression test #'s | scubydrew | Mid West Subaru Owners Club Forum -- MWSOC | 1 | 09-15-2004 09:48 PM |
What are good brake pads for my L sedan?? Suggestions?? | 96Lconversion | New England Impreza Club Forum -- NESIC | 10 | 07-27-2001 07:13 AM |
what are good tire pressures for autox? | iBlueVirus | Brakes, Steering & Suspension | 7 | 05-05-2001 07:34 AM |
