06-07-2014, 10:04 PM | #426 |
Member#: 85083
BAIC
Vehicle:2015 WRX Premium World Rally Blue Pearl |
Has anyone tried this mod with the 2015 WRX?
The stock lights on the 2015 WRX are considerably better than the stock lights were on my 2004 WRX. I would still love to have HIDs.
06-08-2014, 11:42 AM | #427 |
Member#: 141373
E. Canada
Vehicle:2022 Crosstrek Sport 6MT |
It will work on any car accepting H9s - and in this case it's ~500 more raw lumens of light. You can't beat physics
As a side note, one has to remember when considering bulb upgrades is that at the, end it is (pretty much) only lumens that count. Allt he hypergigawhite 100W=10W, often seen in advertising, POS bulbs is total bovine excrement. If you can't find the output in lumens, don't buy. As for LEDs - they're still far from matching the output of fully blown halogen headlamp bulb filaments (asides from dedicated LED lamps which often use an array of LEDs). Not to mention that since many LEDs are used on one "bulb", the beam pattern becomes completely coo coo, if you do a direct replacement. |
08-05-2014, 02:17 PM | #428 |
Member#: 393998
Vehicle:/// WRx /// |
Oh thank goodness for Google I found this...just bought stock Philips H9 on Amazon, going to make this a WEEKEND PROJECT
No seriously, my dash cam would also love the much needed light output. Until I can afford a $500+ retrofit project this will do... |
08-05-2014, 04:25 PM | #429 | |
Member#: 343078
South East
Vehicle:2013 WRX Hatchback SWP |
Sent from my SCH-I535 using NASIOC mobile app |
08-05-2014, 10:39 PM | #430 | |
Member#: 393998
Do you or someone know other plug & play HID projector other than the Mini D2S that TRS has that won't require cutting? I know they're okay but was hoping to fit something else... |
08-06-2014, 08:28 AM | #431 |
Member#: 226331
South East
Vehicle:2012 WRX Hatch Poor Man's Panamera |
Any projector from an 06-14 STi will work. Bolts right up.
08-06-2014, 08:41 AM | #432 |
Member#: 393998
08-06-2014, 09:50 AM | #433 |
Member#: 393998
n/m...I guess if I go with mini D2S and a kit from TRS.
08-10-2014, 11:59 PM | #434 |
Member#: 393998
Here's the result! First night I realized that the metal tab on the H9 needed to be shaved off (which I didn't realize until today). Easy 30 second tweak and took the photos. I did meter the lighting to the stock H11, ISO800 0.3" f5.6 custom white balance to somewhat match the actual light output color and took the second shot with the H9. No post processing adjustments so it's fairly accurate.
Right away I noticed a difference in the driveway I was happy Philips H11 http://i.imgur.com/fBszJ6r.jpg Philips H9 http://i.imgur.com/yiLAGaf.jpg |
08-11-2014, 09:30 AM | #435 |
Member#: 64405
E. Canada
Vehicle:2018 STi WRB |
Nice pictures, did you leave the fogs on in the first pic or is there that much difference in the beam between the two bulbs? I am talking about all the foreground light in the first pic.
Sent from my iPhone using NASIOC |
08-11-2014, 10:43 AM | #436 | |
Member#: 393998
Made a video last night as well on the better night time recording on the dash cam. |
08-11-2014, 11:43 AM | #437 | |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
If not for that it would be the best pic I have seen of the comparison between the tow different bulbs and it is exactly what I see in my experience. At a quick glance other people might argue that the H9 isn't that much better because the fog lights skew the results. I've been running H9 only for years now. Great conversion. I even bought an adapter so the next time one burns out, I do not have to file anything down. I filed down the part in the adapter instead. |
08-11-2014, 11:47 AM | #438 |
Member#: 64405
E. Canada
H11 to H9 conversion. DIY with temps
The fogs on are a bit confusing at first but if you ignore the foreground you can still clearly see the difference where the low beam actually is, quite a bit further than where the fogs are. You could probably trim the two pics to remove the foreground, only keep the upper part of each pic and it would be even clearer.
08-11-2014, 11:59 AM | #439 |
Member#: 64405
E. Canada
I hope you dont mind I just quickly edited the pics to crop out the foreground area to show what I meant:
08-11-2014, 02:12 PM | #440 |
Member#: 236305
Yeah you can definitely ignore the fogs in the one pic..
It just throws off the results a little. I think the difference would be even more dramatic w/o the fogs in the one pic.. |
08-11-2014, 02:34 PM | #441 |
Member#: 393998
Actually H11 was taken the night before until I realized why the H9 didn't fit properly but did record the setting for the H9 shot.
I can try to do an overhead shot from middle of the car next time. There's an old empty lot not far from me so I'll probably shoot there. That should give people better idea on the spread as well. |
08-11-2014, 03:02 PM | #442 |
Member#: 372100
Vehicle:2013 Premium 5dr CVT DGM |
Quick question; how old were the H11's?
08-11-2014, 05:42 PM | #443 | |
Member#: 236305
That location you shot in already is really good though. You can compare a lot of the things off to the side like the pole, and grass, the concrete curb thing sticking up, even the tar stips on the road. Would be hard to beat that. It is "real world" use too. |
08-12-2014, 02:04 PM | #444 | |
Member#: 393998
Good question; it was in there since I bought the car. Some say it's 500 and up to 700 lumens brighter with the H9. It's VERY noticeable though either way. Haven't been flashed by any oncoming cars. YET
08-19-2014, 11:48 AM | #445 |
Member#: 399414
On a 2014 Wrx if I want to make the daytime running lights white light do I replace the 9005 high beam light for that?
09-08-2014, 11:22 AM | #446 |
Member#: 134222
Vehicle:2015 WRX Limited ISM |
Does anyone know if the added 10w over stock (55w vs H9's 65w) will cause issues over time with the LIN Battery Sensor in the new 15' model year subarus? It's the reason why I ripped out my HIDs today.
09-08-2014, 12:46 PM | #447 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
No issues with mine and the H9 conversion is one of the first things I did when I got the car back in May.
09-08-2014, 01:33 PM | #448 |
Member#: 134222
09-08-2014, 02:02 PM | #449 |
Trust no one
They're either Philips or Hellas, I had them lying around as spares from the GTO.
09-08-2014, 09:43 PM | #450 |
Member#: 236305
OSRAM H9 bulbs are cheap and in-stock at Auto-Zone most of the time.
Similar Threads | ||||
need to fix a DIY r134a A/C conversion | Niku-Sama | Service & Maintenance | 4 | 06-12-2009 08:50 PM |
cant seem to find a diy thread on how to | 949 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 06-06-2007 08:47 AM |
MAP to MAF conversion from UTEC??? Do it today with Xede. | turboICE | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 22 | 10-01-2003 06:44 PM |
auto to manual conversion with big torque expectations | kaneda3 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 17 | 07-21-2001 01:01 AM |
