08-16-2012, 10:41 PM | #1 |
Member#: 43038
Vehicle:2002 Forester S Black |
Cat Converter Shot: Local Muffler Shop??
I just bought a 2002 Subaru Forester S with 153000 miles and the CEL was on when I pulled off the lot. The salesman told me to bring it back Monday and they would fix it. They replaced the 02 sensor but the CEL continued. I failed emissions and the code was P0420. The dealership has agreed they will replace the cat converter on the car. They said they will not replace with Subaru OEM due to cost.
There is a reputable shop in the area that installs Imco cats on cars. That is who will be replacing the cat. It will be a California Imco cat. Is this risky business or will a reputable shop typically do a good job? What about aftermarket universal cats? The Imco seems to be pretty good and they are made here in TN!
08-16-2012, 10:48 PM | #2 |
Member#: 146216
South East
Vehicle:2007 Impreza 2.5i SE Newport Blue Metallic |
If you can get your hands on a whole OEM pipe with cat for the car, that's always the easiest and you won't have to worry about the welds lasting. I would check to see if you can replace that section from the dealer or junkyard fairly inexpensively. An aftermarket cat should work, but sometimes they can still upset the computer if they're not quite tuned perfectly for the car or in the near exact placement. I also don't like muffler shop quality welds.
Also you should go ahead and change the O2 sensors out just to be squeaky clean. |
08-16-2012, 10:53 PM | #3 | |
Member#: 43038
08-18-2012, 10:01 PM | #4 | |
Member#: 312107
Vehicle:1998 LowFoz Glacier White |
08-18-2012, 10:11 PM | #5 |
Member#: 43038
The dealer did have a local/reputable muffler shop replace the cats free of charge and they did a good job. As of yet no rattles and the CEL is gone.
08-18-2012, 10:14 PM | #6 | |
Member#: 312107
