07-18-2009, 09:51 PM | #1 |
Member#: 205537
Vehicle:2013 STI DGM |
08 2.5i headers?
I've been looking on ebay for uel headers but most of them don't say if they're are uel and I'm not sure if they will fit on my car without modifications. someone please help.
07-18-2009, 10:56 PM | #2 |
Member#: 182620
SWIC
Vehicle:07 sti DGM |
</a>
this an uel header for a n/a subaru off ebay. it bolts up to all n/a 2.5 and 2.2l subarus up to 05. 06 and up you need to buy the whole exhaust engine back to get the rumble, there a **** load of threads about this on nasioc and rs25.com. |
07-18-2009, 11:03 PM | #3 |
Member#: 205537
so it wont be possible to just change the headers and add a turbo xs cat back to it? I have searched nasioc and keep getting 05 and 06.
07-18-2009, 11:30 PM | #4 |
Member#: 190724
Vehicle:2008 2.5i Sedan Lightning Red |
for an 08 the only way to do it without any cutting and welding is by buying a cat-pipe from http://rallisportracing.com/
otherwise you'll need to have a custom cat pipe made for the car. |
07-18-2009, 11:44 PM | #5 |
Member#: 205537
i have a shop that can do it so with the headers and the existing exhaust could i modify it to make it fit without buying a cat pipe?
07-18-2009, 11:45 PM | #6 |
Member#: 182620
SWIC
you have to change the header, get a cat pipe like bcware says from rallysportracing.com or extend your 02 sensors. and get a catback that will fit your car. your looking at minimum of $1000 for an ok setup
07-18-2009, 11:52 PM | #7 |
Member#: 205537
i found the cat back and the headers which i can afford but the cat pipe i cant afford. the shop work i can afford since its free so with the headers and cat back could it be done in a shop?
07-18-2009, 11:56 PM | #8 |
Member#: 205537
if i do get the cat pipe bcware told me about will i pass inspection?
07-18-2009, 11:58 PM | #9 |
Member#: 182620
SWIC
its bolt on easy b.s. not like your doing internal work.
07-18-2009, 11:59 PM | #10 |
Member#: 190724
You could modify your existing cat pipe, but it would require cutting and lengthening and making a new flange, but it shouldn't be too hard.
Passing inspection is a maybe, because I've never known anyone to try it. You might contact the website owner; he seems like a very nice guy and answered questions for me in the past. I'm not sure about emissions, but the visual inspection should be fine. |
07-19-2009, 12:04 AM | #11 |
Member#: 205537
will what hes done on his 07 work on my 08 http://forums.nasioc.com/forums/show...ght=wrx+header
07-19-2009, 01:18 AM | #12 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
To answer the OP's questions about passing emissions: on an 07, if you alter the header or the cat pipe, you will almost certainly not pass emissions if the emissions test is an OBD-II scan.
07-19-2009, 02:45 AM | #13 | |
Member#: 201277
Vehicle:2008 08 QSM 5MT LGT QSM |
Headers: 165.00 shipped from ebay Fabbed mid pipe section : Tubbing $40 per 5 feet so say $80 total High Flow cat $70.shipped ( or chepaer off ebay or the net) labor at a shop and not a nat'l chain like Monroe maybe $40/ hour x 3-4. Thats well under a $1000 I got mine done TOTAL for UNDER $400 more like $377.00 ( that header, pipe, cat, O2 work, and labot) I have a 09 Legacy which is the same underneath as your impreza 08-09 but also very similar 06 forward. Shop around for your parts and find a good shop and keep in mind you can extend your own wires and you will have a sweet sounding setup with a lil money to get a nice dash piece that wiggles while you drive |
07-19-2009, 02:47 AM | #14 |
Member#: 71092
Where did you get EL headers on ebay shipped for $165? That's hundreds less than they've been going for. I call BS.
07-19-2009, 02:49 AM | #15 |
Member#: 190724
You can't get EL for 165, that has to be a UEL price.
07-19-2009, 02:50 AM | #16 |
Member#: 71092
Ah, so then it was $165 wasted?
07-19-2009, 02:50 AM | #17 |
Member#: 190724
Essentially, yes.
Would that be a failure due to codes being thrown? |
07-19-2009, 03:00 AM | #18 |
Member#: 71092
Yeah, it'll fail for one of two reasons. It'll either fail because it's got a stored DTC (with CEL illumintated) or it'll fail because the emissions test block reports Not Ready (if you've reset the ECU to clear the DTC or used RR/AP to delete the CEL).
07-19-2009, 03:04 AM | #19 |
Member#: 190724
would running a real cat prevent this (as opposed to a high flow cat)? I have not heard much feedback in regard to emissions from those that have installed headers.
07-19-2009, 11:37 AM | #20 |
Member#: 71092
No. Aftermarket headers let enough heat out that even stock cats keep working. Annoyingly, this I have proved.
07-19-2009, 02:13 PM | #21 |
Member#: 190724
Which brings us back to wrapping and coating the headers, but would moving the o2 sensors closer to the engine result in hotter gases?
I was doing a lot of searching last night on people with 05+ cars that can't mess with the rear o2 sensor and was wondering if the UEL design was pushing their o2 sensors much farther away than stock. Comparing these different designs we can see how the borla rep UEL headers have, by far, the largest surface area. The huge surface area of the borla reps is definitely going to result in much cooler exhaust gases by the time it reaches the o2 sensors. The wrx ebay header looks like a MUCH better design being much shorter and 4 to 1. Empirically I would think this design would produce better flow and hotter gases since one can slap a cat very close to the engine. The other photos are just a reference to show how much smaller the surface area of the stock headers is compared to the borla reps on top of being shielded. Any thoughts? |
07-19-2009, 03:58 PM | #22 |
Member#: 71092
Why does the 05 and older header get an exclamation point?
The WRX header is not a good one for us. Primary length is VERY important, and for most of what we're going to be doing, longer is better. |
07-19-2009, 04:28 PM | #23 | |
Member#: 201277
There are you UEL headers which I only refered to due to the picture of the eBay UEL header in the above post of which the OP was inquiring about Willaty like stated to you in the other thread blow it out your ass. Stop trying to make me out as a habitual false info giver. You know more about subbie then anyone Ive ever read about or met Ive read many of your posts about various issue Even use your info for MAFv scaling why do you make derogatory replies? |
07-19-2009, 05:59 PM | #24 | |
Member#: 71092
07-19-2009, 06:09 PM | #25 |
Member#: 182620
SWIC
dude you need to stop correcting people and live your own life.
Similar Threads | ||||
08 2.5i UEL Headers | Subarudave09 | Normally Aspirated Powertrain | 10 | 10-20-2010 06:25 PM |
WTB Borla Replica UEL Header for my 08 2.5i | shaowQ | SCIC Private Classifieds | 0 | 04-02-2010 12:42 PM |
OBX EL headers on 08 2.5i | dzrt_hrd | Normally Aspirated Powertrain | 24 | 03-18-2010 10:04 PM |
WTB: Stock 2.5i header, or trade for modified 2.5i header | blk6s | Private 'Wanted' Classifieds | 0 | 12-23-2009 04:27 PM |
UEL Headers that fit a 08 2.5i? | NAJAR | Impreza Forum | 1 | 04-05-2009 12:08 AM |
