07-31-2004, 05:47 AM | #1 |
Member#: 37059
Vehicle:03 WRX World Rally Blue |
Accessport boost psi reading high??
i just got my upgraded accessport and was using it to read the boost levels. In my oem boost gauge, it reads .1mpa max boost. This should equal to 14.5 psi right? But in my accessport, the max boost reads 15.5. Which reading is off?
Also, when the oem boost gauge shows .9 mpa, the accessport shows 14.7. Doesn't this sound wierd? Either the oem boos gauge reads 1-2 psi lower or the accessport is off and reads higher. Any thoughts? |
07-31-2004, 05:56 AM | #2 |
Member#: 6971
NWIC
Vehicle:2008 WRX STi SSM |
Yeah, I answered this on Cobbs forum for you. Your boost gauge reads low, the reading can vary depending on where you tee off for the gauge line. It doesn't sound weird at all, it sounds pretty normal.
Similar Threads | ||||
Boost gauge reading low PSI! | aug | Electrical & Lighting | 1 | 08-09-2008 06:28 PM |
AP V.1, What is the max boost psi it will read? | Bruce Wayne | AccessPort | 2 | 01-10-2008 11:28 PM |
boost gauge reading high | allanak | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 12-04-2003 08:43 PM |
stock boost gauge reads in mPa, how much psi is this? | wrxracer55 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 07-10-2003 07:30 PM |
Boost reading high psi in 1st gear | xtian67 | Newbies & FAQs | 0 | 02-18-2003 02:26 AM |
