07-02-2004, 05:43 PM | #1 |
Member#: 60522
EJ20 vs EJ25
EJ20 or EJ25 on a 01 RS?
I've been reading on turboing the RS. A lot of people say, just do a engine swap because for one, its a lot safer, and two, its way cheaper. Ya I agree with those two things. But I rather stick with my EJ25 and turbo it. The FAT and AVO kits say 4-6 psi is safe for the motor, as long as you don't go any higher than that. What kind of internal modifications do I need to make it safe to run higher boost? Cobb has a shortblock but they want almost $6,000.00 for it. I am just trying to make a list on what is needed to be boost safe. I just plan to use my car as a everyday driving car. Maybe once every two months I will run it at the tracks. My goal is to get at least 285bhp. |
07-02-2004, 05:56 PM | #2 |
Member#: 39936
Vehicle:99RS TWE&SCAT EJ257 Hydra+HMist+PPG+35R=DEATH |
ud need new internals pistons rods id do new valve springs
but u gotta remember for the small amount of torque ur gonna keep and the money ur gonna spend, u can get a wrx engine and get parts for it, run higher boost, and spend less i chose an ej257 for those reasons holds boost better and is still a half liter bigger than a wrx engine work being done myself w/ new springs was around 2gs but i got 350 for the shortblock so i was happy |
07-03-2004, 02:23 AM | #3 |
Member#: 60522
Ok, for those who are running high boost with their stock ej25 engines, what mods did you do to keep your engine from going to engine heaven?
07-04-2004, 09:53 AM | #4 |
Member#: 8533
Vehicle:2002 2.5 RS-T LudeSpeed S. III W/ FMIC |
Engine managment is most important.
I've been running 12psi for ~3 years now, stock motor, daily driven. My engine is still running, but the tranny is another story. I'm on #4 now after breaking my KAAZ full dog box 2 weeks ago . Being safe and saving your motor is all about good tuning. |
07-04-2004, 01:43 PM | #5 |
Member#: 17751
SCIC
Stop being stubborn and do a wrx swap. Then from there 285whp is easy. 285bhp is not even worth mentioning.
07-04-2004, 02:51 PM | #6 |
Member#: 39936
how did u break that on 12psi? 6k drops or something?
07-06-2004, 03:01 PM | #7 |
Member#: 8533
I'm sure lots of red line clutch-less power shifting did not help.
The truth is the tranny should have been able to take that kind of abuse. It was designed to be used in off road racing, and to get slammed from one gear to the next. The parts are on their way back to Japan now, and there is a very good chance that they are going to warrantee the replacement of the parts. So at least it's not a total loss, just a pain in the butt. |
07-06-2004, 04:58 PM | #8 |
Member#: 1277
Vehicle:1999 Minnam Stage 2 Cobb Stage3 engine, TEC3 |
for me i went with EJ25 with
close dect with Cast Iron Liners, 8.5:1 piston, crank, rod, camshaft, valves, spring, and stage 3 bb turbo but you might need $16-18k for this set up |
07-06-2004, 06:34 PM | #9 |
Member#: 39936
chai = money master
07-06-2004, 06:39 PM | #10 |
Member#: 60522
can anyone give me 16-18k? anyways, if i had 18k, i would sell my rs and get a sti.
07-06-2004, 09:07 PM | #11 |
Member#: 48990
Vehicle:98 Impreza RS RBP |
PunnKidd what engine management are you running? Link plus? or something else?
07-07-2004, 02:38 AM | #12 | |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
listen to these guys, don't try to half ass this, that's how things break, do a full swap you'll make 285 WHP and with the right turob you won't even realize that you have any kind of missing low end torque |
07-07-2004, 06:53 AM | #13 |
Member#: 39936
what jeremy said/me
07-08-2004, 08:17 AM | #14 |
Member#: 8533
yeah, I'm running a Link +.
I'll be switching back to my stock ECU just a soon as I can find the map sensor limiter in the ECU program. Then we'll all have a great management solution, ECU reflashing I've already reflashed it for fuel and timing, just can't find that damn MAP sensor limiter. |
Similar Threads | ||||
ej20 vs. ej25 in wrx | silverstreakwrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 08-28-2005 03:26 AM |
ej20 vs ej25 | toebotypera | Proven Power Bragging | 4 | 01-15-2005 02:44 AM |
Intake manifold EJ20 vs EJ25 ? | Dr Ken | Newbies & FAQs | 1 | 08-28-2003 04:22 PM |
EJ20 vs EJ25 (Turbo vs Turbo) | MagicMT | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 04-23-2001 11:52 AM |
EJ20 vs. EJ25 | Imprezanator | Technical Forum Archive | 4 | 09-17-2000 06:03 PM |
