05-05-2010, 12:25 PM | #1 |
Vendor Sales Rating: (43)
Member#: 87358
TXIC
DW Fuel Injector Cleaning Service
Hello all!
Many of you are already running our injectors, some for quite awhile, thank Subie guys/gals! ...but, did you know, we also offer Injector Servicing, can be Subaru or not! ***FOR ALL NASIOC USERS, SPECIAL FORUM UPGRADE TO OUR FORUM DYNAMIC SERVICE FOR THE PRICE OF OUR BASIC SERVICE, AND FREE SHIPPING!!!!*** ****Make sure you write at the top of the service form that you are a member of NASIOC.com!!!**** DeatschWerks Injector Services Available on any gasoline fuel injector...OEM, Aftermarket, Sidefeed, and Topfeed. We have taken what we have learned from building precision high flow injectors and applied these same principles to develop the ultimate injector cleaning and flow testing system. THREE levels of service are available to suit your needs, but each service receives the same quality and attention to detail that we put into our own highflow injectors. Also, all injector services are performed on the same precision calibrated equipment that we use on our own injectors...so you know the results you get are dead on. Ordering Ordering injector services through DeatschWerks is quick and easy. Simply choose the injector service you want (see descriptions below). Print out and complete the PDF order form available on our website: DeatschWerks Injector Service Order Form. Then, package your injectors with the order form and send it to the address at the bottom of the form. Be sure to package your injectors in plastic to ensure no residual fuel is leaked during shipping! Feel free to contact me if you have any questions or need help with which service to choose. Basic Service - $19/Injector Looking for better gas mileage, smoother operation, and crisper acceleration? Installing used injectors and want to be sure they are clean and operating properly? Then the Basic Service is for you! PROCESS BENEFIT 3-step Ultrasonic Cleaning Optimum Atomization and Flow Replace O-rings, Filters, and Seals Ensure Leak Free Operation Check Coil Discover Coil Problems Leak Test @ 100psi Find Leaks at Pintle RPM Ramp Test - Exclusive DeatschWerks test! Pulse-Width Ramp Test - Exclusive DeatschWerks test! Spray Pattern Analysis Verify Proper Atomization Static Flow Test Check Balance of Flow Rates ID Etching, links each injector to results on report Lubricate and Bag, preserves optimum working condition System Calculations, min/max/avg flow and system balance Basic Report (1 page) Forum Special Dynamic Service - $19/Injector and FREE SHIPPING back to you! The BEST deal in town! PROCESS BENEFIT the Forum Special includes everything in the Basic Service plus ... Everything in the Dynamic Service minus the pre-test! Dynamic Service - $29/Injector Having an engine problem and suspect the fuel injectors? Tuning your car for more boost and want to yield the higher and safer whp? Then the Dynamic Service is for you! PROCESS BENEFIT the Dynamic Service includes everything in the Basic Service plus ... Flow-Rate Pretest, for before and after comparison Dynamic Flow Testing, simulates real driving conditions Fuel Pressure Calculations, valuable tool for FMU/AFPR users Performance Calculations, defines limits of fuel system Dynamic Report (2 page) Dynamic PLUS Service - $39/Injector Are you the picky type who demands only the best for their car? Are you a tuning your car for maximum power and efficiency? Then the Dynamic PLUS Service is for you! PROCESS BENEFIT the Dynamic PLUS Service includes everything in the Basic AND Dynamic Service plus ... Customer Defined Testing Parameters, you can choose testing pressure, duty cycles, rpms, etc. to build a complete custom test Advanced Coil Testing, loaded/unloaded and at various operating temps True Balancing and Blue Printing, bring atomization and flow to within 3% Lag Measurement, valuable tuning tool (upon request) 10-point Dynamic Test, maps injectors through all duty cycles Linearity Testing, graphs injector flow during entre range of duty cycles Dynamic PLUS Report (3 pages)
07-17-2010, 06:42 PM | #3 |
Member Sales Rating: (32)
Member#: 81095
Vehicle:2005 WRX EJ205 weed- whacker. OS self-tuned! |
Wow, awesome deal!!! Do you replace all 3 seals (o-ring, grommet and seal)? I assume the injector can come in bare, and will go out with all new seals installed?
08-05-2010, 07:55 AM | #7 |
Member#: 87358
TXIC
Rock on, sir! Thank you. We'll get them back out to you quickly.
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [b][u] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/b][/u] [B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B] |
08-23-2010, 10:14 AM | #9 |
Member#: 87358
TXIC
Great. Thanks peak. We'll get you taken care of.
__________________
09-24-2011, 08:09 PM | #11 |
Member#: 87358
TXIC
Yes, sir! This is an on-going offer.
__________________
09-26-2011, 04:03 PM | #12 |
Member Sales Rating: (15)
Member#: 202804
Vehicle:2002 PSM Sedan The 2.0L that could |
Silly question, but i'm interested in buying some used 740cc's from a forum member with only 7k miles or so. Would they really need to be cleaned? Also, how much of a rebate can I get for my Sti pink injectors?
Thanks |
09-26-2011, 05:06 PM | #13 |
Member#: 87358
TXIC
Hey Subian,
Thanks for the question. The need to have them serviced or not depends on a few things. If they are fresh out of a running car, I think you'd be fine...especially if the seller is including the flow report. If they have been sitting open to air for a few months, a service wouldn't be a bad idea since gasoline leaves deposits behind as it evaporates that could affect how the injectors function. If you are buying from someone that has a good reputation, has the flow report, and hasn't had them out of the car for too long. You should be fine.
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [b][u] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/b][/u] [B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B] Last edited by DeatschWerks; 09-27-2011 at 10:21 AM. |
09-27-2011, 10:20 AM | #15 |
Member#: 87358
TXIC
Oh, sorry Subian...I meant to answer that yesterday.
Currently, the STi "Pink" injectors are not eligible for the Core Rebate Program.
__________________
Injector Cleaning Service, need opinion | Inprogress | Texas Impreza Club Forum -- TXIC | 5 | 02-21-2008 01:02 PM |
Fuel Injector Cleaning and Poor Fuel Ecomomy | redbone | Service & Maintenance | 0 | 11-21-2007 11:03 AM |
Local Injector Cleaning Service? (bellevue area) | awd4ever | North West Impreza Club Forum -- NWIC | 3 | 11-10-2003 09:35 PM |
Fuel Injector cleaning truths... | ImprezaRSX | Hawaii Impreza Club Forum -- HIIC | 0 | 07-23-2002 05:14 AM |
