03-08-2005, 03:26 AM | #1 |
Member#: 79950
question for air fuel gauge and oxygen sensor
ok so lets say that i bought a single wire oxygen sensor and placed it in the uppipe egt sensor spot, would that be safe, and would it give me an accurate reading using a autometer gauge. cause right now im tapped off the rear sensor with a cel fix and its slow to respond and doesnt seem terribly accurate
03-08-2005, 08:24 AM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
The only accurate A/F setup will be one that uses a wideband sensor. What you're describing may be marginally better than tapping off the rear 02 but it's still essentially a waste of time and money.
03-08-2005, 02:28 PM | #3 |
Member#: 79950
attention o2 sensor will not fit in egt bung
yeah i bought an o2 sensor to put in the uppipe, it didnt work. i figured i could place the same sensor after the turbo btw its unheated and probably wouldnt work.
i went ahead and just left it as it was reading off the BLUE WIRE on the oxygen sensor. when read off the white it simly reads a constant lean. now it reads but it lags because its after the turbo so thats why its slow to respond. thats at least what i have come to the conclusion of. just thought id say. man this was alot of trouble for nothing. |
Similar Threads | ||||
tapping into 02 sensor for air fuel gauge? | hatrick32000 | Electrical & Lighting | 6 | 01-27-2008 10:22 PM |
boost and air fuel gauge and POD | SQC120 | Interior/Dressup/Audio & Security | 9 | 08-14-2006 06:06 PM |
Question about Air/Fuel gauge | Aleksey | Electrical & Lighting | 1 | 11-01-2005 11:43 AM |
Air Fuel Gauge and 2.2K ohm CEL fix... | fastlane | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 02-12-2003 04:45 PM |
Question about air/fuel gauge | MAD REX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 08-27-2002 08:31 PM |
