06-18-2002, 04:37 PM | #1 |
Member#: 12223
Vehicle:2005 WRX |
Air Fuel Question?
Is there a digital air fuel gauge that reads in numbers? Is there a way to get it to work because of the wrx is 5 volts and the gauage reads from 1 volt?
06-18-2002, 04:48 PM | #2 |
Member#: 14981
Vehicle:2002 WRX Sedan WRB TurboXS Stage 2.5 |
Hook it up to the rear o2 sensor
ECU pin B17 |
06-18-2002, 04:54 PM | #3 |
Member#: 12223
Vehicle:2005 WRX |
I have a resister wired there to stop the low cat cel. Will I still get accurate readings from it?
06-18-2002, 04:56 PM | #4 |
Member#: 14981
Do you have the resistor on B17 because you have no rear o2 sensor? Did you buy an exhaust with no cats?
If this is the case, you're S-O-L on the A/F gauge. Find one with its own wideband o2 sensor. |
06-18-2002, 04:57 PM | #5 |
Member#: 12223
Vehicle:2005 WRX |
Guess I need A wide band $$
air/fuel question | SubiWRX04 | Engine Management & Tuning | 11 | 03-18-2009 08:48 AM |
super noob Air/fuel question | stisp33d | Newbies & FAQs | 5 | 09-22-2004 04:38 PM |
air/fuel question | billyr2.5 | Normally Aspirated Powertrain | 0 | 05-18-2004 10:25 AM |
autometer air/fuel gauge question | bttune2.5rs | Normally Aspirated Powertrain | 3 | 02-12-2001 05:01 AM |
Installing an air/fuel gauge - quick questions | BoomerRS | Normally Aspirated Powertrain | 9 | 11-30-2000 05:30 PM |
