02-20-2008, 04:01 PM | #1 |
Member#: 38829
NWIC
Vehicle:Not your usual 1997 Legacy GT |
Tire width on lowered BD Legacy; Rubbing?
I am looking at different 17" OE rims and considering buying a set for summer tires for my '97 GT Sedan. I've got the ION Performance lowering springs, which drop the front 1". I'm a little concerned about rubbing when going to a slightly wider tire. Anybody have any experience with this? What width are you running?
I'm thinking either 215/45R17 or 225/45R17 tires. I'd prefer for the 225s as it's closer to stock diameter, and obviously gives a slightly larger contact patch. I'm leaning towards General Exclaim UHPs. From the reviews I've read on tirerack.com, they seem like a very good summer tire at a great price point ($73/tire). Any thoughts on these? I'm used to running all-season tires year-round, and have used Dunlop SP Sport 5000s and currently using Kumho Ecsta ASX. I've been pleased with both tires. Thanks for any input! Aaron
02-20-2008, 04:05 PM | #2 |
Member#: 38829
NWIC
I just wanted to post some useful information for anyone else looking at upsizing their wheels. The following chart is from http://www.miata.net/garage/tirecalc.html and is a comparison of different sizes when going from a 16" tire to a 17" tire.
Specification____Sidewall_____Radius_____Diameter_ __Circumference_____Revs/Mile___Difference 205/55-16_________4.4in_____12.4in_______24.9in__________ 78.2in__________811_______0.0% 215/45-17_________3.8in_____12.3in_______24.6in__________ 77.3in__________819______-1.0% 225/45-17_________4.0in_____12.5in_______25.0in__________ 78.5in__________808_______0.4% 205/50-17_________4.0in_____12.5in_______25.1in__________ 78.8in__________804_______0.8% 215/50-17_________4.2in_____12.7in_______25.5in__________ 80.0in__________792_______2.4% Last edited by fastenova; 02-20-2008 at 04:12 PM. |
02-20-2008, 04:55 PM | #3 |
Member#: 5039
South East
Vehicle:2007 Outback XT Grey 5-speed (sold) |
If you are running near an ideal offset(+53-55mm) I think youre gonna be able to use the 225s. Thats not to severe a drop. Mine is dropped about 3/4" and Im on the 215/45s and feel certain it could take the 225s. I do have the fender lip trim removed though in the rears. The rears will be the problem BTW not the fronts.
ss |
02-20-2008, 04:59 PM | #4 |
Member#: 38829
NWIC
I don't understand why the rears would be the problem vs. the front? I am concerned about rubbing on the body/fender liner when turning on the front.
Should I be concerned about clearing the spring perch on the rear? Thanks, Aaron |
02-20-2008, 05:10 PM | #5 | |
Member#: 5039
South East
You should be concerned about it but there should be enough room. I know there would be on my car with even the +55 offset I am running. Higher offset moves the tire inward, lower outward. Usually the rubbing occurs at the fender lip on a lowered BD/BG/BK running a 225 or wider on a +48 or lower offset wheel. ss |
02-20-2008, 05:12 PM | #6 |
Member#: 5039
South East
And I should add I removed the fender lip trim when I was running a JDM STi suspension that dropped the car about 1.25" in the rear. Its no where near touching at the rear lip on this suspension(GR2s with JDM GT-B springs.)
ss |
02-20-2008, 05:14 PM | #7 |
Member#: 38829
NWIC
OK, good to know. I would be willing to roll the fender if that's what it takes.
So, now that the theoretical OK is there, anybody running this 225s or wider on their lowered Legacy? SS, do you happen to know the offset for stock '07-08wrx wheels? |
02-20-2008, 05:27 PM | #8 | |
Member#: 5039
South East
Mine are the 06s and are +55mm, did the wheels change for 07? If so I am not sure but +55 is a good bet. ss |
02-20-2008, 05:36 PM | #9 |
Member#: 5039
South East
Theres a pic of my car in this thread
http://forums.nasioc.com/forums/show....php?t=1445568 with the 17x7" +55m 06 WRX wheels with 215/45-17s. It looks like thats the same wheel the 07 WRXs use per Ebay. Dont know about the 08s. You can see the rear fender clearance fairly well. ss |
02-20-2008, 05:39 PM | #10 | |
Member#: 38829
NWIC
02-20-2008, 06:23 PM | #11 | |
Member#: 5039
South East
You know where I ran into trouble with the retrofit? Getting the case back together. I got it apart just fine but despite reheatings, clamps, etc. I couldnt get it to go back together correctly. I shelved it again. ss |
02-20-2008, 07:05 PM | #12 |
Member#: 38829
NWIC
Just to hijack my own thread, what projectors did you use? Ballasts? Mind giving me an idea of what they cost? I'm leaning toward the bi-xenon projectors used in a lot of BMWs, as I understand that the solenoid 'lump' for the shutter is smaller than on other bi-xenons, allowing for easier installation in the headlight housing. I know it's gonna be a couple month project, but since I've been living with the crappy OE lights for 6 years I don't mind.
02-20-2008, 07:41 PM | #13 | |
Member#: 5039
South East
ss |
02-21-2008, 10:10 AM | #14 | |
Member#: 831
E. Canada
Vehicle:03 Sonic YellowWRX 03 BH Titanium |
Car is lowered slightly. |
Max Tire Width on OEM 16" Rims | xynamax | Tire & Wheel | 4 | 03-03-2006 10:36 AM |
tire width on stock wheels | rally_on | Tire & Wheel | 5 | 11-28-2005 12:43 AM |
Max tire width on a 19x8.5 wheel | gswrx | Tire & Wheel | 5 | 04-16-2005 01:18 PM |
Max Tire width on STi w/stock BBS | grknss | Tire & Wheel | 13 | 01-06-2004 09:52 PM |
max tire width on rs | Max_Boost_7 | Brakes, Steering & Suspension | 3 | 11-22-2002 12:48 PM |
