11-27-2007, 10:33 PM | #1 |
Member#: 121796
RMIC
Vehicle:2005 Blue WRX Sedan In Subaru I Trust! |
Suspension...
I am going to buy Cobb lowering springs and KYB AGX struts... if there are any obvious problems with either of those two products tell me.
NOW THE QUESTION... If a car is lowered, is it true that it can no longer be correctly aligned (thinking in comparison with correct standard factory alignment if not lowered) by a mechanic? If so, where? Sorry if the question is worded weird, just tired. Teddy
11-27-2007, 10:57 PM | #2 |
Member#: 139853
Vehicle:2002 wrx....its tsxy silver |
I've heard that before, but in the 4 lowered vehicles I have owned and had realigned, some more drastic than others, never was I told it couldn't be done. I spose its a possibility, but so long as the geometry remains...it should be no problem.
chris |
11-28-2007, 12:02 AM | #3 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
Obvious problem - AGXs are not available in a fitment for the 04+ Impreza. If you want to use them you will need spacers (available from Turn In Concepts - search 'TiC spacer') to match the rear struts to the 05 rear tophat/spring combination. Plenty of threads on this if you search the Suspension forum.
As to the alignment, depends what you mean by 'correctly' - lowering will make the camber go more negative than stock - the front can probably be brought back within stock specs using the stock adjuster HOWEVER the additional negative camber is almost always beneficial if you do anything other than straight line highway driving. The rear camber cannot be adjusted as-is and may need aftermarket camber bolts to regain stock settings - IF that's what you decide is 'correct'. If your priority is aesthetic, just get the toe zeroed and be happy. If your priority isn't aesthetic... then most folks would recommend springs with less of a drop anyway. |
11-28-2007, 01:16 AM | #4 |
Member#: 140163
Vehicle:03 STi hellaflunctional |
there are far better springs to be had
11-28-2007, 02:29 AM | #5 |
Member#: 165349
SCIC
Vehicle:2003 WRX Sedan W R Blue Pearl |
do konis make shocks for wrxs?
Similar Threads | ||||
stock Suspension | zweetz32 | MWSOC Private Classifieds | 5 | 06-05-2010 03:23 PM |
Need some suspension suggestions. | deftonez99 | Newbies & FAQs | 4 | 06-03-2010 02:49 PM |
2008 Impreza Suspension vs. Legacy suspension vs. Tribeca suspension | Kostamojen | Brakes, Steering & Suspension | 70 | 08-09-2007 01:18 PM |
Whats the difference between FHI ver5 suspension and STI ver 5 suspension? | MY99 2.5GT | Brakes, Steering & Suspension | 5 | 05-08-2001 05:20 AM |
wheel alignment after suspension suspension install | bluesube | Brakes, Steering & Suspension | 0 | 11-02-2000 03:23 PM |
