10-30-2002, 11:50 AM | #1 |
Member#: 12464
Vehicle:1995 Legacy BD Black |
CEL = engine coolant temp. sensor
I had a CEL and it was caused by the engine coolant temp. sensor. I have a Hyanes book and it says it is under the passenger side intake manifold on the coolant pipe.
Am I looking in the right place? Has anyone had to replace one? And if so did you do it or have a mechanic? Thanx Ron
10-30-2002, 02:14 PM | #2 |
Member#: 17252
Vehicle:'06 WX8 59E |
I have recently replaced this sensor. It's threaded into the coolant crossover pipe,
a.k.a "water manifold" , under the no.3 intake runner, with the connector pointing nearly rearwads. It's hidden by wiring harnesses and hoses. Look straight down near the idle air controller on the right side of the throttle body. The socket size is 19 mm. My reply to your previous thread posted but did not bump the count. |
P0118 Engine Coolant Temp Sensor High Input | j.r | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 05-25-2009 06:17 PM |
wtb: coolant temp sensor for ej18 engine or Phase I | mxpunk | Tri-State Area Private Classifieds | 1 | 07-14-2008 12:04 PM |
Engine Coolant Temp Sensor ? | qwiktripn | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 04-13-2004 06:49 PM |
Engine Coolant Temp Sensor | scoobyimprza | Engine Management & Tuning | 3 | 11-14-2002 02:19 PM |
Engine coolant temp sensor check engine light? | rhdude | Mid Atlantic Impreza Club -- MAIC | 2 | 11-09-2002 02:42 AM |
